Home » Modeling » EMF » Problems with serializing/deserializing eOpposites
Problems with serializing/deserializing eOpposites [message #1016145] |
Tue, 05 March 2013 04:14  |
Hi all/Ed,
I have the following serialized model objects:
<myNS:P id="0ae41484-cdc8-497e-99aa-ee594be6a7cc" />
<myNS:PG id="fe50804f-d464-4b97-b3bd-e6a63d5427a0">
<pg href="0ae41484-cdc8-497e-99aa-ee594be6a7cc"/>
</myNS:PG>
Model:
EClass P:
- id : EString (id = true)
- pg : PG 0..1 (eOpposite)
EClass PG
- p : P 0..* (containment = false, eOpposite)
If I deserialize the XMI, the P instance has no reference to PG, i.e. its eOpposite reference P.pg is null. But, PG.p's EList contains a reference to P.
Shouldn't the eOpposite be set automatically when the Resource is loaded? Or do I have to make sure the eOpposite is serialized on both sides in the XMI?
Re: Problems with serializing/deserializing eOpposites [message #1016166 is a reply to message #1016145] |
Tue, 05 March 2013 05:24   |
Erdal,
Comments below.
On 05/03/2013 10:14 AM, Erdal Karaca wrote:
> Hi all/Ed,
> </myNS:PG>
> Model:
> EClass P:
> EClass PG
> reference to P.
Are both the sides proxy resolving and non-transient? I don't see the
serialized reference from P to PG which suggests that side (pg) has been
marked transient. That's only valid if p is non-proxy resolving, i.e.,
doesn't support cross document references. But if that's the case, it
wouldn't be populated with a proxy and it wouldn't be possible for pg
not to be set.
Yes and no. If they're populated with proxies, they're set separately
and must both be serialized. If they're populated directly, they'd
definitely both end up being set because the model always does that
under the covers.
> the XMI?
Yes if they can in general be cross document references (then both sides
must be non-transient), no if p is non-proxy resolving (and is never a
cross document reference).
Does your model validate?
Re: Problems with serializing/deserializing eOpposites [message #1016179 is a reply to message #1016166] |
Tue, 05 March 2013 06:22   |
Hi Ed,
For both (eOpposite) refs "Resolve Proxies" is set to true and "Transient" is set to false.
The model validates.
Thanks!
Ed Merks wrote on Tue, 05 March 2013 11:24Erdal,
Comments below.
> Hi all/Ed,
> </myNS:PG>
> Model:
> EClass P:
> EClass PG
> reference to P.
not to be set.
under the covers.
> the XMI?
[Updated on: Tue, 05 March 2013 06:23] by Moderator
Re: Problems with serializing/deserializing eOpposites [message #1016180 is a reply to message #1016179] |
Tue, 05 March 2013 06:24   |
Hi Ed,
Thanks!
Comments below.
> Hi all/Ed,
> </myNS:PG>
> Model:
> EClass P:
> EClass PG
> reference to P.
not to be set.
under the covers.
> the XMI?
Current Time: Fri Jul 18 22:27:01 EDT 2025
Powered by FUDForum. Page generated in 0.05116 seconds
