Home » Modeling » EMF » [Teneo] Possible to set fetch="subselect" on a multi-value EAttribute?
[Teneo] Possible to set fetch="subselect" on a multi-value EAttribute? [message #1015940] |
Mon, 04 March 2013 05:48  |
I've been experimenting with the potential performance benefits of setting @Fetch(value=FetchMode.SUBSELECT) @OneToMany(fetch=EAGER) on my multi-value EReferences (i.e. where upperBound!=1). As expected, this results in a single select query for this type, rather than one per object in the containing collection.
To give a concrete example: Order contains many OrderLines (has an EReference called orderLines with upperbound=-1). This (normal behaviour) results in a single query to fetch all OrderLines for a given Order. Then, OrderLine contains a single OrderItem (an EReference called orderItem, upperbound=1). These are fetched (normal behaviour) as part of the same query that fetched the OrderLines, via an inner join.
Next, I have OrderItem containing many ItemEvents (an EReference called itemEvents, upperBound=-1). Normally, this would result in one select query per OrderItem to fetch its associated ItemEvents. This is where my FetchMode.SUBSELECT comes into play; I've set this on OrderItem.itemEvents and this correctly causes all ItemEvents to be selected via single select query that has an 'in' clause referring to a sub-query that fetches all the OrderItems.
Represented in 'ASCII-UML', this looks like:
Order <>--> [0..*] OrderLine <>--> [1] OrderItem <>--> [0..*] ItemEvent
Everything so far is fine and as expected. However, if I go another layer deeper into my containment tree, ItemEvent has a multi-value EAttribute called 'metadata' of type String. These are stored in a table of their own, with a foreign key referring to the containing ItemEvent. This exhibits the 'N+1 problem', in that a separate select query is used to fetch the metadata for each ItemEvent. I'd like to solve this by setting FetchMode.SUBSELECT here too; i.e. cause a single select query on the metadata table (with an 'in' clause to get all entries for all ItemEvents).
Adding this to the hierarchy gives us:
Order <>--> [0..*] OrderLine <>--> [1] OrderItem <>--> [0..*] ItemEvent <>--> [0..*] Metadata
If I look at the hibernate mapping for OrderItem.itemEvents, it has a 'list' declared like this:
<list name="itemEvents" fetch="subselect" lazy="false" cascade="all,delete-orphan">
<one-to-many entity-name="com.example.ordermodel.ItemEvent"/>
</list>
Looking at ItemEvent.metadata, it's something like this:
<list name="metadata" table="`ITEMEVENTMETADATA`" lazy="false" cascade="all,delete-orphan">
<key foreign-key="FK_METADATA" update="true">
<column name="`ITEMEVENT_METADATA_ID`" not-null="true" unique="false"/>
</key>
<list-index column="`ITEMEVENT_METADATA_IDX`"/>
<element type="java.lang.String" not-null="false" unique="false">
<column not-null="false" unique="false" name="`METADATA`" length="400"/>
</element>
</list>
If I understand correctly, hibernate would allow fetch="subselect" to be declared on this list element too, causing all metadata to be retrieved with a single query. However, I'm not sure how to prompt Teneo to cause that. I don't think I can put @Fetch(value=FetchMode.SUBSELECT) there, as this fails with:
org.eclipse.emf.teneo.annotations.parser.AnnotationParserException: The eclass: HbAnnotatedEAttribute does not have an efeature for Fetch
So, my questions are:
1) Is my assumption correct that hibernate would allow fetch='subselect' here and that it would give the desired effect?
2) If so, can I prompt Teneo to cause this?
Many thanks in advance for any help.
Ben.
Re: [Teneo] Possible to set fetch="subselect" on a multi-value EAttribute? [message #1015982 is a reply to message #1015940] |
Mon, 04 March 2013 08:28   |
Hi Ben,
Seems to be a missing feature in annotation processing. Can you enter a bugzilla for this? With this annotation enabled
it should be possible to add subselects fetching also for many-eattributes.
gr. Martin
On 03/04/2013 11:48 AM, Ben Tenne wrote:
> </list>
> </key>
> </element>
> </list>
> efeature for Fetch
> Regards,
> Ben.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Possible to set fetch=&quot;subselect&quot; on a multi-value EAttribute? [message #1016013 is a reply to message #1015987] |
Mon, 04 March 2013 10:29  |
Hi Ben,
Here are some tips:
- create your own subclass of the ManyAttributeMapper, set it to be used using the teneo extensionmanager:
http://wiki.eclipse.org/Teneo/Hibernate/Extensions
- override the processManyAttributeMapper method, call it in the super class, after the super call check this object:
getHbmContext().getCurrent() (it returns a simple dom element representation)
- then from that object you can find the created list element, and add your own fetch attribute.
gr. Martin
On 03/04/2013 02:57 PM, Ben Tenne wrote:
> Thanks Martin.
> Raised here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=402321
> In the meantime, could you possibly point me in the direction of how I could go about hacking this capability in
> (temporarily, for experimental purposes)? In my case, it would be adequate to _always_ set fetch="subselect" for _all_
> multiplicity-many EAttributes.
> Regards,
> Ben.
The Netherlands
Current Time: Fri Jul 25 06:15:19 EDT 2025
Powered by FUDForum. Page generated in 0.04687 seconds
