Home » Modeling » EMF » [Teneo] Strange behaviour when switching EntityNameStrategy(EntityInterfaceNameStrategy gives No annotated model element present error)
[Teneo] Strange behaviour when switching EntityNameStrategy [message #1007949] |
Fri, 08 February 2013 07:11  |
Hi Martin,
Sorry to keep asking questions - I do try to hunt arround to find answers and debug problems myself, but I'm a bit at a loss with this one. As always, the example that follows is a much simplified version as to what the real code we have does. (I understand that as the code looks, no-one would really do this - but the case we have, it sort of occurs like this).
It is more on the EntityNameStrategy, if I run the following code using the QualifyingEntityNameStrategy then it will work OK and generates the Hibernate mapping as expected.
public class RobTest extends TestCase
private Class useThisEntityNameStrategy = EntityInterfaceNameStrategy.class;
// private Class useThisEntityNameStrategy = QualifyingEntityNameStrategy.class;
public void test1() throws Exception
EPackage.Registry.INSTANCE.put(OrdermodelPackage.eNS_URI, OrdermodelPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put(NestedPackage.eNS_URI, NestedPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put(GdcompPackage.eNS_URI, GdcompPackage.eINSTANCE);
// First Case
HbDataStore hbDataStore = HbHelper.INSTANCE.createRegisterDataStore("TempDataStore");
final ExtensionManager extensionManager = hbDataStore.getExtensionManager();
extensionManager.registerExtension(EntityNameStrategy.class.getName(), useThisEntityNameStrategy.getName());
String mapping = null;
try
mapping = HbHelper.INSTANCE.generateMapping(new EPackage[]{OrdermodelPackage.eINSTANCE},
hbDataStore.getProperties(), extensionManager);
catch (Exception e)
throw e;
// Second Case
HbDataStore hbDataStore2 = HbHelper.INSTANCE.createRegisterDataStore("TempDataStore");
final ExtensionManager extensionManager2 = hbDataStore2.getExtensionManager();
extensionManager2.registerExtension(EntityNameStrategy.class.getName(), useThisEntityNameStrategy.getName());
String mapping2 = null;
try
mapping2 = HbHelper.INSTANCE.generateMapping(new EPackage[]{GdcompPackage.eINSTANCE,
NestedPackage.eINSTANCE}, hbDataStore2.getProperties(), extensionManager2);
catch (Exception e)
throw e;
System.out.println("First Mapping:" + mapping);
System.out.println("Second Mapping:" + mapping2);
However, if I switch the EntityNameStrategy to instead use EntityInterfaceNameStrategy, then when it does the second call to HbHelper.INSTANCE.generateMapping() I get an exception thrown:
java.lang.IllegalArgumentException: No annotated model element present for: Wheel for type EClass has its epackage been registered with Teneo?
at org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedModelImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:347)
at org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedModelImpl.getPAnnotated(PAnnotatedModelImpl.java:289)
at org.eclipse.emf.teneo.mapping.strategy.impl.EntityInterfaceNameStrategy.toEntityName(EntityInterfaceNameStrategy.java:84)
at org.eclipse.emf.teneo.mapping.strategy.StrategyUtil.getEntityName(StrategyUtil.java:63)
at org.eclipse.emf.teneo.mapping.strategy.impl.ClassicSQLNameStrategy.getEntityName(ClassicSQLNameStrategy.java:392)
at org.eclipse.emf.teneo.mapping.strategy.impl.ClassicSQLNameStrategy.getForeignKeyName(ClassicSQLNameStrategy.java:110)
at org.eclipse.emf.teneo.annotations.mapper.BaseEFeatureAnnotator.createFK(BaseEFeatureAnnotator.java:64)
at org.eclipse.emf.teneo.annotations.mapper.OneToOneReferenceAnnotator.annotate(OneToOneReferenceAnnotator.java:99)
at org.eclipse.emf.teneo.hibernate.annotations.HbOneToOneReferenceAnnotator.annotate(HbOneToOneReferenceAnnotator.java:48)
at org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator.annotate(EFeatureAnnotator.java:197)
at org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.annotate(EClassAnnotator.java:242)
at org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotator.annotate(HbEClassAnnotator.java:55)
at org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.annotate(EClassAnnotator.java:101)
at org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator.processPackage(AnnotationGenerator.java:167)
at org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator.map(AnnotationGenerator.java:135)
at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:159)
at org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingBuilder.buildMapping(PersistenceMappingBuilder.java:71)
at org.eclipse.emf.teneo.hibernate.HbHelper.generateMapping(HbHelper.java:197)
I have attached a copy of the test program - from the testing that I have done - you can use pretty much any set of eCores to reproduce this one (as long as the 2 eCores are different).
It has really got me a little stumped why changing the EntityNameStrategy would have such an impact on this.
My investigation has shown up that if I change the HbHelper.INSTANCE.createRegisterDataStore() call to take different strings - then the problem goes away - however that would be a little tricky for us - and it still seems strange that changing the EntityNameStrategy would cause this problem in the first place.
I would love to have your expert advice on this one please Martin.
Rob
Attachment: RobTest.java
(Size: 2.40KB, Downloaded 341 times)
Re: [Teneo] Strange behaviour when switching EntityNameStrategy [message #1008276 is a reply to message #1007949] |
Sun, 10 February 2013 17:47   |
Hi Rob,
Can you send me example ecores for which this fails? Note that if you pass in TempDataStore to both calls to HbHelper,
then the second call will return the same instance as the first call.
gr. Martin
On 02/08/2013 01:11 PM, Rob Mising name wrote:
> Hi Martin,
> // First Case
> try
> catch (Exception e)
> throw e;
> // Second Case
> try
> catch (Exception e)
> throw e;
> Thanks
> Rob
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Strange behaviour when switching EntityNameStrategy [message #1011071 is a reply to message #1008413] |
Mon, 18 February 2013 14:47   |
Hi Rob,
I did some testing with your models and testcase.
The reason that this fails is that the hbDataStore2 is the same instance as the hbDataStore (as the same name is used to
register it). So the extensionmanager is the same and the EntityNameStrategy instance is therefore also the same.
The EntityInterfaceNameStrategy class caches the internal annotated model, but in the second pass a different annotated
model is being used, however the EntityInterfaceNameStrategy still has hold of the old annotated model, resulting in
invalid cache searches.
A solution is to use a different name for the second retrieval of the datastore:
HbDataStore hbDataStore2 = HbHelper.INSTANCE.createRegisterDataStore("TempDataStore2");
Or maybe clear the internal cache somehow, but it all seems somewhat theoretical.
At least now you know why it fails and how this can be prevented.
gr. Martin
On 02/12/2013 12:53 PM, Rob Mising name wrote:
> Hi Martin,
> Sorry for the delay - eCore files attached.
> Thanks
> Rob
The Netherlands
Current Time: Mon Jul 21 07:08:14 EDT 2025
Powered by FUDForum. Page generated in 0.05145 seconds
