Home » Eclipse Projects » Eclipse 4 » Control over close button on Part tab
Control over close button on Part tab [message #1015249] Wed, 27 February 2013 16:39 Go to next message
I have a part that encapsulates a task. When you are setting up the task, and when it is displaying the task results, I wish the part to be closeable. When the task is running, I want the part either not to be closeable, or else to have the ability to interrupt, and possibly abort the close request. (I.e. pop up an "Are you sure?" dialog, and respond.)
I thought by setting MPart.setClosable() I could, at least, enable/disable the close state. But it seems to have no effect once the part is rendered.
And I can't find any API that lets me hook into the closing process.
Any suggestions?
Re: Control over close button on Part tab [message #1015581 is a reply to message #1015249] Fri, 01 March 2013 04:32 Go to previous messageGo to next message
Does this help? http://www.eclipse.org/forums/index.php/m/848560/
Re: Control over close button on Part tab [message #1015663 is a reply to message #1015581] Fri, 01 March 2013 10:13 Go to previous message
Well, the code there words as advertised. But there are two problems:
1) The handler does not seem to be called unless the tab for the part is in focus.
If I just click on the "X", my handlers does not get called. If I click first on the tab title, then the "X", it does get called.
[Actually, it's more complex than that. I'm not sure what it is anymore.]
2) This doesn't give me any control over the close button. I can see when the user tries to close it. I can even pop up a message that asked them if they really want to do that. But, if they don't, I don't see any way to stop the close from happening.
Is there a way to mark an event as "consumed"? Or otherwise abort it?
I looked to see if I could change NEW_VALUE, but there is no way to set the property.
I tried just going back and setting Visible=true on the model part, but that didn't work. Either immediately or after a pause.
I tried just throwing an exception to crash out the event processing (!), but you've done the right thing and catch all exceptions.
How can I abort a close?
(pure e4, no compatability layer stuff needed, BTW)
Previous Topic:Reset perspective though command for perspective created by application model not showing any part i
Next Topic:E4 - Bind handler to regular SWT button (considering canExecute)
Current Time: Sat Jul 26 23:32:45 EDT 2025
Powered by FUDForum. Page generated in 0.06348 seconds
