Home » Modeling » TMF (Xtext) » Bug with EcoreGeneratorFragment in xtext 2.4M5?
Bug with EcoreGeneratorFragment in xtext 2.4M5? [message #1015560] Fri, 01 March 2013 04:04 Go to next message
I'm trying to work on a language based on xbase and another metamodel I wrote, which refers to JavaVMTypes.
My language refers to things from Xtypes and JavaVMTypes.
When the EcoreGeneratorFragment is executed I get this error:
	at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.hasExtendedMetaData(GenPackageImpl.java:4417)
	at org.eclipse.emf.codegen.ecore.genmodel.impl.GenPackageImpl.initialize(GenPackageImpl.java:2807)
	at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelImpl.initialize(GenModelImpl.java:2317)
	at org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment.getSaveAndReconcileGenModel(EcoreGeneratorFragment.java:666)
	at org.eclipse.xtext.generator.ecore.EcoreGeneratorFragment.generate(EcoreGeneratorFragment.java:220)
	at org.eclipse.xtext.generator.CompositeGeneratorFragment.generate(CompositeGeneratorFragment.java:92)
	at org.eclipse.xtext.generator.LanguageConfig.generate(LanguageConfig.java:113)
	at org.eclipse.xtext.generator.Generator.generate(Generator.java:361)
	at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:128)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
	at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
	at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
	at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:35)
	at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
I did a bit of debug, and the problem is that on line 4437 of GenPackageImpl, when looking for the ePackage of the references, at one point the eCrossReference is, I don't know why, a proxy to a EClass of JavaVMTypes and not a direct reference as with the other references.
And this proxy seems to return null for getEPackage(), which results on the NPE happening later.
Maybe something is wrong in my code, so I'm going to check again, but I'm not sure that behaviour is wanted when such a situation happens :)
Thanks!
Re: Bug with EcoreGeneratorFragment in xtext 2.4M5? [message #1015563 is a reply to message #1015560] Fri, 01 March 2013 04:07 Go to previous messageGo to next message
I found the problem, in the ecore file referencing JavaVMTypes, I got something like that:
<eStructuralFeatures xsi:type="ecore:EReference" name="typeParameters" upperBound="-1"
        eType="ecore:EClass platform:/plugin/org.eclipse.xtext.common.types/model/JavaVMTypes.ecore#//JvmTypeParameter"
        containment="true"/>
instead of:
        eType="ecore:EClass platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.ecore#//JvmTypeParameter"
Anyway, the error is maybe not normal?
Re: Bug with EcoreGeneratorFragment in xtext 2.4M5? [message #1015565 is a reply to message #1015563] Fri, 01 March 2013 04:09 Go to previous messageGo to next message
did you try to add a uri map from platform:/plugin/..... to platform:/resource ...... to the StandaloneSetup?
~Christian
Re: Bug with EcoreGeneratorFragment in xtext 2.4M5? [message #1015579 is a reply to message #1015565] Fri, 01 March 2013 04:29 Go to previous messageGo to next message
Yes, I think that would work too, but I am more worried about the way the error is reported and the fact that it happens, than I am worried about how to solve it (since I could solve it :)
Thank you!
Re: Bug with EcoreGeneratorFragment in xtext 2.4M5? [message #1016095 is a reply to message #1015563] Mon, 04 March 2013 18:43 Go to previous messageGo to next message
Am 01.03.13 10:07, schrieb Victor Mising name:
> upperBound="-1"
> eType="ecore:EClass
> instead of:
> upperBound="-1"
> eType="ecore:EClass
Where did you find the reference to platform:/plugin? Is it in your own
Ecore package or in one file that is shipped with Xtext?
Nevertheless, you may want to register a URI mapping in order to fix that.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: Bug with EcoreGeneratorFragment in xtext 2.4M5? [message #1016129 is a reply to message #1016095] Tue, 05 March 2013 02:52 Go to previous message
It was in my own ecore file, so I just changed it directly in the file Smile
I think it arrived here automatically by using the simple EMF editor...
Previous Topic:Scoping
Next Topic:QNames with dots in segments
Current Time: Mon Jul 21 05:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.06666 seconds
