Very odd issue with multiple schemaLocations [message #1015558] |
Fri, 01 March 2013 03:57  |
I'm creating XSD based Ecore models and serialize them. To get proper
schema locations, I have set the URI of the resource owning the XSD
model to point to the path where the schemas are. Saving with
XMLResource.OPTION_SCHEMA_LOCATION = Boolean.TRUE worked fine so far.
The serialized result looks like this (line breaks added for better
readability):
xmlns:common="http://www.abc.com/product/0.3.0/common"
xmlns:main="http://www.abc.com/product/0.3.0/main"
xsi:schemaLocation="
../../../../model/com.abc.model/bin/xsd/Common-v0.3.0.xsd
../../../../model/com.abc.model/bin/xsd/Main-v0.3.0.xsd"
All fine so far. But now I moved the XML file one level down in the
directory hierarchy. To match that I added one "../" to the
schemaLocation. But now the XML file no longer validates, claiming that
the Common-v0.3.0.xsd cannot be located anymore!
If I remove the first schema location (common), it works again!
That brings me to the next question: is it actually correct to have
multiple schemaLocations like this? Main.xsd will imply pulling in
Common.xsd anyway.
Please note that I am aware that the validation is done by WST and not
EMF, but since the XML was serialized by EMF, I thought I ask here first.
Thanks for any tipps or pointers!
Marius
Re: Very odd issue with multiple schemaLocations [message #1015630 is a reply to message #1015558] |
Fri, 01 March 2013 08:00  |
Marius,
Comments below.
On 01/03/2013 9:57 AM, Marius Gröger wrote:
> Hello,
What path did you use?
> Saving with
> readability):
It's in your bin folder? Is this supposed to work once you've deployed
your model?
You might try using this in your resource factory:
result.getDefaultSaveOptions().put(XMLResource.OPTION_URI_HANDLER, new
URIHandlerImpl.PlatformSchemeAware());
Assuming you've specified the location as platform:/plugin/ (although it
doesn't look like you have done that).
What's "it"?
> Common.xsd anyway.
In general schemaLocations are specified to be "hints" to the XML
processor. Processors can choose to ignore them and can choose to use
any mechanism for locating schemas.
If you want WST to validate your XML, you're probably better off to use
their catalog mechanism to specify where your namespace's schema should
be found, rather than specifying it in each instance.
> Marius
FUDForum. Page generated in 0.35037 seconds
