Home » Archived » BIRT » Rotate Text or Label (vertical text)(How to rotate a static text field (e.g. Text or Label)?)
Rotate Text or Label (vertical text) [message #1015325] Thu, 28 February 2013 03:56 Go to next message
Hey everyone,
I'm looking for a way to display vertical text in a report with BIRT 4.2.1. I read some posts in different forums, but couldn't find a way to get it working. I also found the birt controls lib, but it's not supported in version 4.2.1 (only 2.3.2 and 2.5.2).
What I need is a static text item (no data set) that is displayed as part of a grid or next to it.
Is there any way to get that done without saving the text as a picture?
Thanks in advance!
Bianca
Re: Rotate Text or Label (vertical text) [message #1015458 is a reply to message #1015325] Thu, 28 February 2013 11:01 Go to previous messageGo to next message
Have you tried the birt controls lib in 4.2? I was pretty certain it still worked.
Re: Rotate Text or Label (vertical text) [message #1015542 is a reply to message #1015458] Fri, 01 March 2013 03:19 Go to previous messageGo to next message
Hi Michael,
thanks for answering so fast!
I tried to put the jar's in the plugin folder and restart the designer, but couldn't see the objects.
Did I miss anything?
Bianca
Re: Rotate Text or Label (vertical text) [message #1015594 is a reply to message #1015542] Fri, 01 March 2013 05:16 Go to previous messageGo to next message
Ok, it's working now. Installing via Update Manager solved the problem. (There are 3 jar's, but only two of them where in the downloads section of the home page.)
I still have some problems using the controls fpr my report. Is it somehow possible to changed the resolution of the generated image? I have the same problem, when I insert an image that I generated myself. The resolution is to low to look good in the report.
Bianca
Re: Rotate Text or Label (vertical text) [message #1015725 is a reply to message #1015594] Fri, 01 March 2013 17:41 Go to previous messageGo to next message
Take a look at this:
http://www.eclipse.org/birt/phoenix/project/notable2.5.php#jump_16
Re: Rotate Text or Label (vertical text) [message #1015904 is a reply to message #1015725] Mon, 04 March 2013 03:54 Go to previous messageGo to next message
Thanks a lot! That solved the problem I had using the images I generated myself. I still have some trouble with the controls, but that's not that urgent right now. I will have a look at that a little later.
Thank you so much!
Best Regards,
Bianca
Re: Rotate Text or Label (vertical text) [message #1016106 is a reply to message #1015904] Tue, 05 March 2013 00:37 Go to previous messageGo to next message
You're welcome. Let us know whenever you have questions! Smile
Re: Rotate Text or Label (vertical text) [message #1181446 is a reply to message #1016106] Mon, 11 November 2013 11:04 Go to previous message
Hello everybody,
I have the same problem but I can't find the birt-controls-lib for Birt 4.2. I tried
birt.controls.lib.ui_2.5.2.1.jar but it doesn't work.
Does anyone have any idea where to find it?
Thank you for your help,
Melina
Previous Topic:Font gets substituted in PDF
Next Topic:Need help to setup workspace to build BIRT
Current Time: Sun Jul 27 01:59:29 EDT 2025
Powered by FUDForum. Page generated in 0.06695 seconds
