Logging for WebViewerExample [message #1015466] |
Thu, 28 February 2013 11:19  |
I'm trying to use the sample WebViewerExample to run BIRT reports on a server. I've deployed the new webapp to tomcat and I can reach the front page which lists the version number. When I go to run a report, it stays at the "Processing, please wait...." screen without ever loading/running the report. This same report runs in the BIRT Report Designer.
I looked in the logs folder under the WebViewerExample webapp and I found a lot of 0 byte files. Is that the correct folder for logging? Is there any way to configure it to log somewhere else? Are the logs being saved somewhere else?
Thanks!
Note - I attached a screenshot of the "Processing, please wait...." dialog box that BIRT hangs on.
FUDForum. Page generated in 0.04529 seconds
