[CDO] Cannot connect to my repository (following some samples) [message #1015386] |
Thu, 28 February 2013 07:58  |
I cannot connect to a CDO server running in localhost. I have followed the instructions of two examples, but no one works for me:
http://www.rcp-vision.com/?p=1285&lang=en
http://wiki.eclipse.org/CDO/Net4j_Authentication
I'm using authentication on my CDO server.
I tried the following code, using also the commented variants:
// Get and prepare the container
IPluginContainer container = IPluginContainer.INSTANCE;
// Net4jUtil.prepareContainer(container);
// TCPUtil.prepareContainer(container);
// CDONet4jUtil.prepareContainer(container);
// Create credentials
PasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider(
"Administrator", "0000");
container.addPostProcessor(new ConnectorCredentialsInjector(
"127.0.0.1:2036", credentialsProvider));
// Get connector
IConnector connector;
connector = TCPUtil.getConnector(container, "127.0.0.1:2036");
// connector = (IConnector) container.getElement(
// "org.eclipse.net4j.connectors", connectionType,
// "127.0.0.1:2036");
// Create configuration
CDONet4jSessionConfiguration sessionConfiguration = CDONet4jUtil
.createNet4jSessionConfiguration();
sessionConfiguration.setConnector(connector);
sessionConfiguration.setRepositoryName(repository);
// Try to open the session
CDOSession session = sessionConfiguration.openNet4jSession();
Using as address "127.0.0.1:2036", I always get an error when getting the connector (TCPUtil.getConnector...): org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate TCPClientConnector[127.0.0.1:2,036]
Anybody can help please? I don't know what's happening. Of course, the server is running...
Marc
[Updated on: Thu, 28 February 2013 07:58] by Moderator
Re: [CDO] Cannot connect to my repository (following some samples) [message #1015524 is a reply to message #1015386] |
Fri, 01 March 2013 00:40   |
Am 28.02.2013 13:58, schrieb Marc Gil:
> works for me:
> I tried the following code, using algo the commented variants:
> // Get connector
That's probably because the acceptor on the server side needs to be configured with an INegotiator. There's an example
in org.eclipse.net4j.tests.TCPConnectorTest
public void testNegotiationSuccess() throws Exception
threadPool = Executors.newCachedThreadPool();
LifecycleUtil.activate(threadPool);
bufferPool = Net4jUtil.createBufferPool();
LifecycleUtil.activate(bufferPool);
randomizer = new Randomizer();
randomizer.activate();
userManager = new UserManager();
userManager.activate();
userManager.addUser(USER_ID, PASSWORD);
challengeNegotiator = new ChallengeNegotiator();
challengeNegotiator.setRandomizer(randomizer);
challengeNegotiator.setUserManager(userManager);
challengeNegotiator.activate();
provideTransport();
selector.activate();
acceptor.setStartSynchronously(true);
acceptor.setSynchronousStartTimeout(TIMEOUT);
acceptor.getConfig().setBufferProvider(bufferPool);
acceptor.getConfig().setReceiveExecutor(threadPool);
acceptor.getConfig().setNegotiator(challengeNegotiator);
acceptor.setSelector(selector);
acceptor.setAddress("0.0.0.0"); //$NON-NLS-1$
acceptor.setPort(PORT);
acceptor.activate();
credentialsProvider = new PasswordCredentialsProvider(CREDENTIALS);
LifecycleUtil.activate(credentialsProvider);
responseNegotiator = new ResponseNegotiator();
responseNegotiator.setCredentialsProvider(credentialsProvider);
responseNegotiator.activate();
connector.getConfig().setBufferProvider(bufferPool);
connector.getConfig().setReceiveExecutor(threadPool);
connector.getConfig().setNegotiator(responseNegotiator);
connector.setSelector(selector);
connector.setHost("localhost"); //$NON-NLS-1$
connector.setPort(PORT);
connector.activate();
connector.waitForConnection(DEFAULT_TIMEOUT);
InternalChannel clientChannel = connector.openChannel();
assertEquals(USER_ID, clientChannel.getUserID());
IConnector serverConnector = acceptor.getElements()[0];
IChannel serverChannel = serverConnector.getElements()[0];
assertEquals(USER_ID, serverChannel.getUserID());
System.out.println(serverChannel);
If you pull the acceptor out of an IManagedContainer you can configure it with an
org.eclipse.net4j.util.security.ResponseNegotiatorInjector.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Cannot connect to my repository (following some samples) [message #1015526 is a reply to message #1015442] |
Fri, 01 March 2013 00:46  |
Am 28.02.2013 16:37, schrieb Marc Gil:
> Finally I get I by doing the following:
> // Enable logging and tracing
> OMPlatform.INSTANCE.setDebugging(true);
> OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
> OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
> // Prepare container
> IManagedContainer container = ContainerUtil.createContainer();
> Net4jUtil.prepareContainer(container); // Register Net4j factories
> TCPUtil.prepareContainer(container); // Register TCP factories
> CDONet4jUtil.prepareContainer(container); // Register CDO factories
This last call is not needed if you explicitely open your CDOSession through a CDOSessionConfiguration (and not through
the IManagedContainer).
> container.activate();
> // Create connector
> IConnector connector = TCPUtil.getConnector(container,
> getAddressConnection()); //$NON-NLS-1$
> CDONet4jSessionConfiguration configuration = CDONet4jUtil
> configuration.setConnector(connector);
> configuration.setRepositoryName(repository); //$NON-NLS-1$
> user, password);
> configuration.setCredentialsProvider(credentialsProvider);
> // Open session
> CDOSession session = configuration.openNet4jSession();
> transaction = session.openTransaction();
> return session;
> It seems similar than the other code, but just creating the credentials after creating the connector, and assigning it
> to the session configuration instead of to the connector.
> Is it correct?
Yes, this CDO authentication is newer and (in some ways) more powerful for CDO applications than the older Net4j
authentication.
Cheers
/Eike
FUDForum. Page generated in 0.08550 seconds
