Home » Modeling » TMF (Xtext) » Put error mark at right EStructuralFeature
Put error mark at right EStructuralFeature [message #1011999] Wed, 20 February 2013 12:00 Go to next message
I have a custom validation fucntion that validates the entire docuemtn against a json schema.
The json schema validator return the path to element in the document it found an error against.
if you have this json doc
"test1": "test1",
"test2": {
    "test1": "test1",
    "test2": []
The validator returns something like this "/test1/test2 should be a sting"
I am now trying to have xtext put the error mark on the right line.
I just go over the root eobject and find the right member for the json path.
But if I pass this eobject.eContainingFeature() to error() I get the folowing error:
ERROR org.eclipse.xtext.validation.CompositeEValidator  - Error executing EValidator
java.lang.IllegalArgumentException: The sources EClass 'Object' does not expose the feature 'Generic.name'
	at org.eclipse.xtext.validation.FeatureBasedDiagnostic.<init>(FeatureBasedDiagnostic.java:33)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.createDiagnostic(AbstractDeclarativeValidator.java:427)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.acceptError(AbstractDeclarativeValidator.java:400)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.error(AbstractDeclarativeValidator.java:381)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.error(AbstractDeclarativeValidator.java:369)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.error(AbstractDeclarativeValidator.java:357)
	at com.nuance.voconhint.validation.JsonJavaValidator.validateSchema(JsonJavaValidator.java:43)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator$MethodWrapper.invoke(AbstractDeclarativeValidator.java:109)
	at org.eclipse.xtext.validation.AbstractDeclarativeValidator.internalValidate(AbstractDeclarativeValidator.java:291)
	at org.eclipse.xtext.validation.AbstractInjectableValidator.validate(AbstractInjectableValidator.java:62)
	at org.eclipse.xtext.validation.CompositeEValidator.validate(CompositeEValidator.java:126)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:159)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
	at org.eclipse.xtext.validation.CancelableDiagnostician.validate(CancelableDiagnostician.java:36)
	at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:120)
	at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:108)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:79)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
	at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
	at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
The eobject that I pass to error() is an Array (as described in the grammar),
it is not a Generic eobject but why should it be?
Object:
	{Object} '{'
		(members+=Member)?
		(',' members+=Member)*
Member:
	Generic | ...;
Generic:
	key=STRING ':' name=Value;
Value:
	Object | STRING | Array | Boolean | Null | NUMBER;
Array:
	{Array} '[' (values+=Value)? (',' values+=Value)* ']';
If I try to take the eContainer() of the "error object" it puts the error mark on /test1 instead of on /test2.
How can I get tight EStructuralFeature from the
Re: Put error mark at right EStructuralFeature [message #1012547 is a reply to message #1011999] Thu, 21 February 2013 14:19 Go to previous messageGo to next message
if your object does not have a name so why do you attach the error the the name feature then?
so in your case if you want to mark name then you have to pass a Generic as object
(use the method org.eclipse.xtext.validation.AbstractDeclarativeValidator.error(String, EObject, EStructuralFeature, int)
instead - use -1 as index)
Re: Put error mark at right EStructuralFeature [message #1015168 is a reply to message #1012547] Wed, 27 February 2013 11:01 Go to previous messageGo to next message
Sorry for the post bump.
The issue here seems that I have a validation function that gets called when an Object changes and this validation functions validates the entire file not just the eobject that gets passed to it.
Because of that it expect the structural feature to be a Generic but in this validation function it can be any eobject type that can be in the grammar.
The pseudo code of the validation function is something like this:
@Check
validateRootObject(Object obj)
  if (obj.eContainer != null)
    return;
  String text = NodeModelUtils.getTokenText(NodeModelUtils.findActualNodeFor(object));
  EObject errorObj = validateAll(text);
  if (errorObj != null) {
    error(put error on the place where errorObj is in the editor);
Maybe I am using the validation function wrong.
Is there a way I can use any eobject to put an error mark in place or alternatively a way to add error marks to the editor without going through the validation functions?
Re: Put error mark at right EStructuralFeature [message #1015195 is a reply to message #1015168] Wed, 27 February 2013 12:36 Go to previous message
i am not quite sure what your problem is. if your a looking for a kind of holzhammer and do not
want to mark a specific feature you can try
error ("bad", errorObj.eContainer(), errorObj.eContainingFeature(), -1);
but i still would prefer
error ("bad", errorObj, Yourpackage.Literals.SOME_SPECIFIC_FEATURE, -1);
Previous Topic:Adding a toolbar item to an xtext editor (org.eclipse.ui.editorActions is depcreated in 4.2 eclipse
Next Topic:XtextEditor with folding disabled by default
Current Time: Sun Jul 20 23:20:08 EDT 2025
Powered by FUDForum. Page generated in 0.06077 seconds
