Home » Archived » BIRT » Dynamic Page Break(How can I create a dynamic page break in Birt)
Dynamic Page Break [message #1014837] Tue, 26 February 2013 10:07 Go to next message
Can anyone help me? I am trying to create a dynamic page break in Birt 3.0. I am using a page break parameter and putting the following:
"if (BirtComp.equalTo(params["PageBreak"], true) && Total.count() != Total.runningCount()) {
this .getStyle().pageBreakAfter = "always";
On the script tab - drop down (On create). This is all on a label located on the table footer.
Is there something that I am missing?
Re: Dynamic Page Break [message #1014945 is a reply to message #1014837] Tue, 26 February 2013 17:06 Go to previous messageGo to next message
Can you look in the XML Source of your report design and paste the version info from the top few lines into here, so I know which BIRT version you're using. 3.0 is not a BIRT version. Even better, if you can create an example using the sample database, with your version and just attach it in here, that'd allow me to see everything you're doing and to test with the same file.
Re: Dynamic Page Break [message #1014950 is a reply to message #1014945] Tue, 26 February 2013 17:29 Go to previous messageGo to next message
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.16" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.0.v20080606 Build &lt;2.3.0.v20080618-0630></property>
Re: Dynamic Page Break [message #1014961 is a reply to message #1014950] Tue, 26 February 2013 18:18 Go to previous messageGo to next message
Thanks! Okay. So, what you're wanting to do is to accept a parameter to decide whether to page break at the end of a group or not? Or is this to simply page break after a table. Please let me know a little more detail and I'll make a sample report.
Re: Dynamic Page Break [message #1014964 is a reply to message #1014961] Tue, 26 February 2013 18:21 Go to previous messageGo to next message
Yes, I would like to page break at the end of a table. I have the script in a label at the end of a table and the pagebreak is set to "Auto". If I set the pagebreak to "Always" it works to break always, but sometimes my user would like to print it all together in pdf format. Thank you for your help.
Re: Dynamic Page Break [message #1014968 is a reply to message #1014837] Tue, 26 February 2013 19:00 Go to previous messageGo to next message
Take a look at the script in the onCreate of the table's footer row. If the checkbox parameter is selected, there is a page break. If it's not, there isn't. Let me know if this isn't quite what you're looking for.
Re: Dynamic Page Break [message #1015150 is a reply to message #1014968] Wed, 27 February 2013 10:24 Go to previous messageGo to next message
this is what I want to do, but even when I do all of that it does not work. I have the code and the pagebreak from the library, but when I reset the pagebreak to "Auto" so it will rely on the script, it does not page break at all. See attachment.
  • Attachment: Sample.jpg
    (Size: 90.77KB, Downloaded 1009 times)
  • Attachment: Doc1.docx
    (Size: 37.71KB, Downloaded 617 times)
Re: Dynamic Page Break [message #1015276 is a reply to message #1015150] Wed, 27 February 2013 21:23 Go to previous message
Can you recreate your issue with the sample database, so that I can run the report and test on it? Thanks!
Previous Topic:soap calls viewerservlet
Next Topic:How to fix y-axis values in chart
Current Time: Sun Jul 27 08:13:55 EDT 2025
Powered by FUDForum. Page generated in 0.05803 seconds
