Home » Modeling » EMF » [CDO] Adding CDO authentication to offline example
[CDO] Adding CDO authentication to offline example [message #1014850] |
Tue, 26 February 2013 10:34  |
We're using the CDO offline/clone example as a base for our application, but we're trying to add file based CDO authentication (http://wiki.eclipse.org/CDO/Net4j_Authentication#Property-File_based_Authentication).
All examples I can find online have a cdo-server.xml, but the example doesn't. It's creating a repository through code..
How can we add the authentication part to the server side? This is our code which starts the repository:
JdbcDataSource dataSource = new JdbcDataSource();
dataSource.setURL("jdbc:h2:db/server");
IMappingStrategy mappingStrategy = CDODBUtil.createHorizontalMappingStrategy(true, true);
IDBAdapter dbAdapter = new H2Adapter();
IDBConnectionProvider dbConnectionProvider = DBUtil.createConnectionProvider(dataSource);
IStore store = CDODBUtil.createStore(mappingStrategy, dbAdapter, dbConnectionProvider);
Map<String, String> props = new HashMap<String, String>();
props.put(IRepository.Props.OVERRIDE_UUID, REPOSITORY_NAME);
props.put(IRepository.Props.SUPPORTING_AUDITS, "true");
props.put(IRepository.Props.SUPPORTING_BRANCHES, "true");
props.put(IRepository.Props.ID_GENERATION_LOCATION, "CLIENT");
IRepository repository = createRepository(node, store, props);
repository.setInitialPackages(ModelPackage.eINSTANCE);
CDOServerUtil.addRepository(IPluginContainer.INSTANCE, repository);
I assume the UserManager has to be created here somehow..?
Thanks in advance.
Re: [CDO] Adding CDO authentication to offline example [message #1014880 is a reply to message #1014850] |
Tue, 26 February 2013 11:30   |
Am 26.02.2013 16:34, schrieb Ricky de Klerck:
Authentication is set up in the session manager of a repository. Please note that
InternalSessionManager.setUserManager() has been deprecated as of CDO 4.2 in favour of ISessionManager.setAuthenticator():
299275: Flexible Approach for an Authentication Mechanism
https://bugs.eclipse.org/bugs/show_bug.cgi?id=299275
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Adding CDO authentication to offline example [message #1015523 is a reply to message #1015391] |
Fri, 01 March 2013 00:34   |
Am 28.02.2013 14:16, schrieb Ricky de Klerck:
> I've enhanced our application with an Authenticator:
> public void start(Node node)
> IRepository repository = createRepository(node);
> // add authenticate to sessionmanager
> final ISessionManager sessionManager = repository.getSessionManager();
> sessionManager.setAuthenticator(new CustomAuthenticator());
> node.setObject(IRepository.class, repository);
> IAcceptor acceptor = createAcceptor(node);
> node.setObject(IAcceptor.class, acceptor);
> String browserPort = node.getSetting(BROWSER_PROPERTY);
> if (browserPort != null && browserPort.length() != 0)
> CDOServerBrowser browser = (CDOServerBrowser)IPluginContainer.INSTANCE.getElement(
> "org.eclipse.emf.cdo.server.browsers", "default", browserPort);
> node.setObject(CDOServerBrowser.class, browser);
> The clients passes a PasswordCredentialsProvider:
> PasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider("test", "test");
> CDONet4jSessionConfiguration configuration;
> IConnector connector = Net4jUtil.getConnector(IPluginContainer.INSTANCE, "tcp", serverAddress);
> configuration = CDONet4jUtil.createNet4jSessionConfiguration();
> configuration.setConnector(connector);
> configuration.setCredentialsProvider(credentialsProvider);
> But when the authentication failes I receive a SecurityException on the server side thrown by the Authenticator. This
> exception is not caught anywhere else and is not visible in the client.. The client receives a TimeoutException.. How
> can I solve this? I want the SecurityException to appear in the client.
That's strange because we test that in org.eclipse.emf.cdo.tests.SessionTest:
public void testWithAuthenticationWrongCredentials() throws Exception
UserManager userManager = new UserManager();
userManager.activate();
userManager.addUser(USER_ID, PASSWORD1);
getTestProperties().put(RepositoryConfig.PROP_TEST_AUTHENTICATOR, userManager);
getRepository("authrepo5");
getTestProperties().put(SessionConfig.PROP_TEST_CREDENTIALS_PROVIDER,
new PasswordCredentialsProvider(new PasswordCredentials(USER_ID, PASSWORD2)));
try
openSession("authrepo5");
fail("SecurityException expected");
catch (SecurityException expected)
// SUCCESS
The test passes. Is it possible that you provide me with code that I can execute to reproduce the problem?
Cheers
/Eike
Current Time: Wed Jul 23 05:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.04861 seconds
