How to change the method selectionChanged(IAction action, ISelection selection) [message #1014744] |
Tue, 26 February 2013 06:35  |
I'm doing a project using the Plug-in papyrus Marte in eclipse, I add a popup menu
named "named import platform" using commands and Handlers in the view of the Model
Explorer when creating a papyrus Model.
I want to change the method selectionChanged(IAction action, ISelection selection) to
be used by commands and handlers not with actions.
public void selectionChanged(IAction action, ISelection selection) {
// the action is enabled only on UML packages stereotyped
// GaAnalysisContext
action.setEnabled(false);
// set the current selection
IStructuredSelection sselection = (IStructuredSelection) selection;
mySelection = sselection;
// look for selected Element
Object e = ((IStructuredSelection) selection).getFirstElement();
// set the editing domain
editDomain = EditorUtils.getTransactionalEditingDomain();
System.err.println(editDomain);
if (e instanceof IUMLNamedElementEditPart) {
Element element = ((IUMLNamedElementEditPart) e).getUMLElement();
if (element instanceof Package
&& element
.isStereotypeApplied(((Package) element)
.getApplicableStereotype("MARTE::MARTE_AnalysisModel::GQAM::GaAnalysisContext"))) {
if ((Package) element.getEAnnotation("annotation") != null) {
action.setEnabled(true);
selectedPackage = (Package) element;
else if (e instanceof ModelElementItem) {
EObject eObj = ((ModelElementItem) e).getEObject();
if (eObj instanceof Package
&& ((Package) eObj)
.isStereotypeApplied(((Package) eObj)
// if (((Package)eObj).getEAnnotation("annotation")!=null){
selectedPackage = (Package) eObj;
If you have some link or if you can advise me I would appreciate.
Thanks in advance.
Best Regards
Re: How to change the method selectionChanged(IAction action, ISelection selection) [message #1014801 is a reply to message #1014744] |
Tue, 26 February 2013 08:36  |
Command handlers get the selection from the HandlerUtil utility API.
For example,
ISelection HandlerUtil::getCurrentSelection(ExecutionEvent event)
Is this what you're asking?
Christian
On 2013-02-26 11:35:32 +0000, Mariem Makni said:
> popup menu
> of the Model
> selection) to
> && element
> && ((Package) eObj)
> Thanks in advance.
> Best Regards
FUDForum. Page generated in 0.04695 seconds
