Home » Modeling » OCL » [OCLinEcore] Invariant evaluation only after validation of another invariant
[OCLinEcore] Invariant evaluation only after validation of another invariant [message #1014783] Tue, 26 February 2013 08:11 Go to next message
I have several constraints on an object of my meta-model but for some of them, the invariant should be evaluated only if another invariant was evaluated positively (didn't produce an error).
In fact, I first evaluate certain condition and if they are not fulfilled, I don't want to evaluate another invariant (it doesn't make sense in the situation).
Is it possible to do something like that ?
Cédric
Re: [OCLinEcore] Invariant evaluation only after validation of another invariant [message #1014796 is a reply to message #1014783] Tue, 26 February 2013 08:32 Go to previous messageGo to next message
Hi Cedric
No, but thanks for reminding me of this use case.
A previous discussion suggested a special dependency syntax. After a bit
more thought it seemed that making a constraint available as a
property/operation would allow a dependent constraint to be written as
inv SimpleConstraint: ...
inv ComplexConstraint: SimpleConstraint implies ...
you could do this manually now by
def checkSimpleConstraint() : Boolean = ...
inv SimpleConstraint: checkSimpleConstraint()
inv ComplexConstraint: checkSimpleConstraint() implies ...
which argues for no change needed. Just requires a smarter evaluator to
do a little Common Subexpression Elimination to detect the dependencies.
Enhancement request raised as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401786.
Ed Willink
On 26/02/2013 13:11, Cedric Moonen wrote:
> Hello,
> was evaluated positively (didn't produce an error). In fact, I first
> Cédric
Re: [OCLinEcore] Invariant evaluation only after validation of another invariant [message #1014807 is a reply to message #1014796] Tue, 26 February 2013 08:55 Go to previous message
Hi Ed,
Thanks for your quick reply, as usual Smile
I could indeed have an additional operation returning a boolean checking the simple constraint.
Cédric
Previous Topic:OCL in XMI instances of Ecore
Next Topic:[OCLinEcore] Evalutaion difference beween OCL console and invariant in the model
Current Time: Wed Jul 23 10:47:48 EDT 2025
Powered by FUDForum. Page generated in 0.04057 seconds
