Home » Modeling » Papyrus » Could not initialize services
Could not initialize services [message #1014741] Tue, 26 February 2013 06:29 Go to next message
I am experiencing a strange error occurring when I add a stereotype, belonging to a profile I created, to a property. If I save the model, close it and open it again I get this error.
I tried it many times and I am pretty sure the problem is related to such stereotype. I am using Juno with Papyrus 0.9.1
org.eclipse.papyrus.infra.core.services.ServiceMultiException: Multiple exceptions
----- exceptions : ----------
org.eclipse.papyrus.infra.services.markerlistener.MarkersMonitorService : java.util.ConcurrentModificationException
org.eclipse.papyrus.infra.services.markerlistener.MarkersMonitorService : Bad state for service 'org.eclipse.papyrus.infra.services.markerlistener.MarkersMonitorService'. Expected 'initialized' found 'error'.
	at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startRegistry(ServicesRegistry.java:431)
	at org.eclipse.papyrus.infra.core.editor.CoreMultiDiagramEditor.init(CoreMultiDiagramEditor.java:513)
	at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:324)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:288)
	at sun.reflect.GeneratedMethodAccessor111.invoke(Unknown Source)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
	at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:839)
	at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
	at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
	at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
	at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
	at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:579)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:315)
	at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:985)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3079)
	at org.eclipse.ui.internal.WorkbenchPage.access$22(WorkbenchPage.java:3003)
	at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2985)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2981)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2940)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2931)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
	at org.eclipse.papyrus.infra.onefile.providers.PapyrusModelActionProvider$1.run(PapyrusModelActionProvider.java:139)
	at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
	at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
	at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.papyrus.infra.core.services.ServiceException: java.util.ConcurrentModificationException
	at org.eclipse.papyrus.infra.core.services.internal.ServiceEntry.initService(ServiceEntry.java:119)
	at org.eclipse.papyrus.infra.core.services.internal.StartStartupEntry.initService(StartStartupEntry.java:61)
	at org.eclipse.papyrus.infra.core.services.ServicesRegistry.initServices(ServicesRegistry.java:915)
	at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startRegistry(ServicesRegistry.java:436)
	... 98 more
Caused by: java.util.ConcurrentModificationException
	at org.eclipse.emf.common.util.AbstractEList$EIterator.checkModCount(AbstractEList.java:756)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:704)
	at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
	at org.eclipse.papyrus.infra.services.markerlistener.MarkersMonitorService.checkMarkers(MarkersMonitorService.java:129)
	at org.eclipse.papyrus.infra.services.markerlistener.MarkersMonitorService.init(MarkersMonitorService.java:92)
	at org.eclipse.papyrus.infra.core.services.internal.ServiceEntry.initService(ServiceEntry.java:113)
	... 101 more
Re: Could not initialize services [message #1014767 is a reply to message #1014741] Tue, 26 February 2013 07:33 Go to previous messageGo to next message
Hello Andrea,
This bug has been fixed in 0.9.2 (Which will be released on Friday). If you need it fixed now, you can use one of the developer update sites:
http://download.eclipse.org/modeling/mdt/papyrus/updates/milestones/0.9/SR2_RC4/main //SR2 Release Candidate
http://download.eclipse.org/modeling/mdt/papyrus/updates/nightly/juno/main //Papyrus Juno nightly builds
Camille
Re: Could not initialize services [message #1014787 is a reply to message #1014767] Tue, 26 February 2013 08:18 Go to previous message
thank you very much
Previous Topic:Showing stereotypes on properties
Next Topic:How to change the method selectionChanged(IAction action, ISelection selection)
Current Time: Sat Jul 26 10:23:57 EDT 2025
Powered by FUDForum. Page generated in 0.04821 seconds
