Home » Eclipse Projects » EGit / JGit » How to list files affected in a commit ?[SOLVED]
How to list files affected in a commit ?[SOLVED] [message #684954] Thu, 16 June 2011 10:21 Go to next message
Hi People,
I'm currently using JGit and i'm trying to simply list all commits and their respectives changedSet (files modified in each revision).
Although i've managed to browse each "RevCommit", i'm still unable to retrieve this list of files...
Does someone has an idea ?!
Thank you very much
Cédric
Edit : i didn't find any thread in this forum dealing with this concern. if it's the case, i'm sorry for this duplication
[Updated on: Thu, 16 June 2011 14:37] by Moderator
Re: How to list files affected in a commit ? [message #685037 is a reply to message #684954] Thu, 16 June 2011 13:36 Go to previous messageGo to next message
This example is basically what you want and should work as long as there is a parent. I handle the first commit differently by parsing the tree, but perhaps you can supply a null for the parent tree in this code. Not sure.
And there may be better ways to do this. As you've discovered, finding docs/samples on JGit can be tough. Peeking at the JGit unit tests and other JGit projects is very useful.
RevWalk rw = new RevWalk(repository);
ObjectId head = repository.resolve(Constants.HEAD);
RevCommit commit = rw.parseCommit(head);
RevCommit parent = rw.parseCommit(commit.getParent(0).getId());
DiffFormatter df = new DiffFormatter(DisabledOutputStream.INSTANCE);
df.setRepository(repository);
df.setDiffComparator(RawTextComparator.DEFAULT);
df.setDetectRenames(true);
List<DiffEntry> diffs = df.scan(parent.getTree(), commit.getTree());
for (DiffEntry diff : diffs) {
    System.out.println(MessageFormat.format("({0} {1} {2}", diff.getChangeType().name(), diff.getNewMode().getBits(), diff.getNewPath()));
Re: How to list files affected in a commit ? [message #685048 is a reply to message #685037] Thu, 16 June 2011 14:02 Go to previous messageGo to next message
Thank you so much James ! It'es working well now ! Smile
You're right, it's not that easy to understand the API without any exemple.
In case you can help me again, i'm looking for a manner to access to a particular version of a file. That is, using your code, in more of getting the changeSet of files, i'd like to retrieve or "re-create" the content of this file. I think there's a way to do so. Do you know smth about it ?
Thank you again !
Cédric
[Updated on: Thu, 16 June 2011 14:29] by Moderator
Re: How to list files affected in a commit ? [message #685061 is a reply to message #685048] Thu, 16 June 2011 14:36 Go to previous messageGo to next message
i've found the solution, and so i share it Smile
(i can't share links since i'm new in the forum, so i've removed http)
stackoverflow.com/questions/4777453/looping-over-commits-for-a-file-with-jgit
Re: How to list files affected in a commit ? [message #1014676 is a reply to message #685037] Tue, 26 February 2013 04:11 Go to previous messageGo to next message
Hey, I also tried your code, it works fine for all the commits but not the initial one, since the initial commit does not have any parent commits, so the code gives an error message. Could you tell me how you solved this problem? thanks.
Re: How to list files affected in a commit ?[SOLVED] [message #1016031 is a reply to message #684954] Mon, 04 March 2013 11:18 Go to previous message
I think you should identify the code that throws the error, and apply a simple null checking to avoid the errors. I'm not sure what happens with the initial commit, but i think it must have a null parent.
Then, to get the initial files, simply find the working copy of the repo at this commit.
Previous Topic:egit upgrade fails due to conflicting dependency
Next Topic:Stash Apply
Current Time: Wed Jul 23 09:30:58 EDT 2025
Powered by FUDForum. Page generated in 0.09658 seconds
