Home » Language IDEs » PHP Development Tools (PDT) » Eclipse Juno + Remote System Explorer + PDT = no default proposals
Eclipse Juno + Remote System Explorer + PDT = no default proposals [message #1014292] Mon, 25 February 2013 09:28 Go to next message
Hello there,
I'm using Eclipse Juno with Remote System Explorer and the PHP extension PDT. I'm working on an external machine over SSH (with RSE) and a really big problem is that Eclipse doesn't show any proposals ("No Default Proposals").
A Google search didn't help, because the solutions didn't work with Juno (e.g. "click right -> Build Path -> Configure Build Path" doesn't show a "Build Path" dialog).
Do you have a solution for me?
Thank you and best regards,
konze
Re: Eclipse Juno + Remote System Explorer + PDT = no default proposals [message #1014554 is a reply to message #1014292] Mon, 25 February 2013 22:11 Go to previous messageGo to next message
FYI,
TM and RSE FAQ - Eclipsepedia
For PDT, which is based on the WST editor framework, this should work properly since the Europa Fall Maintenance release (28 Sep 2007). It would work as follows:
Create a new local PDT project (initially empty)
New > Folder > Advanced > Link to Folder in File System > Deselect default, select RSE File System > Browse to Remote Folder
Re: Eclipse Juno + Remote System Explorer + PDT = no default proposals [message #1014775 is a reply to message #1014554] Tue, 26 February 2013 07:51 Go to previous message
Thank you
Previous Topic:Unit Testing
Next Topic:Focus a custom widget Composite when i <tab> through the children of a main Composite
Current Time: Wed Jul 23 07:39:02 EDT 2025
Powered by FUDForum. Page generated in 0.05337 seconds
