Home » Modeling » Papyrus » How to import a RegisteredLibrary using the method getRegisteredLibraries ()(How to import a RegisteredLibrary using the method getRegisteredLibraries ())
How to import a RegisteredLibrary using the method getRegisteredLibraries () [message #1014484] Mon, 25 February 2013 17:41 Go to next message
I am using Eclipse-SDK-4.3M5 Kepler and papyrus kepler.
I would like to use the Command/Handler to add a popup menu using commands and
Handlers in the view of the Model Explorer when creating a papyrus Model.
This popup menu has a menu that allows you to import a platform from a list, but the
problem is when I use the method getRegisteredLibraries () to Get
the registered library(platform), it doesnt'work and it doesn't import the platform
I used: RegisteredLibrary [] = platform RegisteredLibrary.getRegisteredLibraries ();
I'd appreciate any help on this. Thanks,
Best Regards,
Re: How to import a RegisteredLibrary using the method getRegisteredLibraries () [message #1016512 is a reply to message #1014484] Wed, 06 March 2013 12:51 Go to previous messageGo to next message
Your platform file (platform.uml) should be registered in a plugin installed in your Eclipse, using the extension point: org.eclipse.papyrus.uml.extensionpoints.UMLLibrary. It should also be added in your binary build of your installed plugin.
You can have a look on sysml profile plugin to have some example: org.eclipse.papyrus.sysml
Cheers
Remi
Re: How to import a RegisteredLibrary using the method getRegisteredLibraries () [message #1016728 is a reply to message #1016512] Thu, 07 March 2013 08:54 Go to previous message
Hi Remi,
Thanks a lot for your answer Smile
Previous Topic:Problem of reverse engineering with Modisco & Papyrus
Next Topic:Update site installation errors
Current Time: Wed Jul 23 06:49:26 EDT 2025
Powered by FUDForum. Page generated in 0.05597 seconds
