Home » Language IDEs » ServerTools (WTP) » TCP monitor SOAP requests
TCP monitor SOAP requests [message #101312] Mon, 09 May 2005 08:25 Go to next message
Hello all
I've created a web service and a web service client that calls a method from
the web service
To test my web service client i right click the file select Run and
Argumenst tab - type in some parameters and click apply
I then debug my java
What i want t happen is to see the SOAP request/response from my client
java - can someone tell me how i see this
I'm following an example from here
http://www.developertutorials.com/tutorials/xml/better-soap- interfaces/page5.html
Thanks for any help
Re: TCP monitor SOAP requests [message #101438 is a reply to message #101312] Mon, 09 May 2005 10:42 Go to previous messageGo to next message
Use a proxy, for instance tcpmon (part of the AXIS package).
HTH,
Frank
Re: TCP monitor SOAP requests [message #101501 is a reply to message #101438] Mon, 09 May 2005 11:46 Go to previous messageGo to next message
That's what i have but i don't see any movement
Do i need to set anything in the client ?
"Frank Fischer" <ff@semoe.de> wrote in message
news:d5ntat$7m3$1@news.eclipse.org...
> HTH,
> Frank
Re: TCP monitor SOAP requests [message #101586 is a reply to message #101501] Mon, 09 May 2005 12:14 Go to previous messageGo to next message
The endpoint URL in the client should contain the montior's port number.
Rupam
> > HTH,
> > Frank
Re: TCP monitor SOAP requests [message #172700 is a reply to message #101312] Thu, 29 June 2006 11:51 Go to previous messageGo to next message
Originally posted by: mbo.shift-think.net
Hi there
have you had any success in on this? I am having the same issues
currently...
Michael
plork123 schrieb:
> Hello all
> the web service
> Thanks for any help
Re: TCP monitor SOAP requests [message #172799 is a reply to message #172700] Fri, 30 June 2006 10:28 Go to previous message
I'm not sure I understand how you create the Web service and Web service
client. If you are using the Web Service wizard in WTP to create the Web
service and Web service client, you can select the "Monitor Web service"
checkbox on the first page of the wizard to bring up the TCP/IP monitor
automatically. Then if you had move the client scale to "Test", sample JSPs
would be generated to test your Web service. When you invoke the Web
service in the sample JSP, the TCP/IP monitor view would come up
automatically and you can see your SOAP request.
If I have misunderstood your set up, please elaborate on what you did to
create the Web service and Web service client and what kind of problem you
ran into.
Kathy Chan
"Michael Boeni" <mbo@shift-think.net> wrote in message
news:44A3F6E4.70102@shift-think.net...
> Hi there
> currently...
> Cheers,
> Michael
> plork123 schrieb:
> > Hello all
from
> > the web service
> > Thanks for any help
Previous Topic:Simple Webservices server
Next Topic:Use other project source in web project question
Current Time: Thu Sep 04 00:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.03128 seconds
