Home » Archived » Hudson » New Features for Hudson 3.1(Discussion Thread)
New Features for Hudson 3.1 [message #997583] Tue, 08 January 2013 08:20 Go to next message
All, Now that Hudson 3.0.0 is out of the door we need to focus on what to prioritize for 3.1.0 which is the next feature bearing release on the plan.
We already have some ideas in the Project Plan document but here's you opportunity to speak up and influence the features and prioritization.
If you have any desires why not log them as enhancements in Bugzilla and then reference them from this thread.
We'll also be having an open discussion on this topic in the next community meeting. That meeting is open to all and the next one will take place on Monday the 21st January.
More details are available in the wiki.
[Updated on: Tue, 08 January 2013 08:23] by Moderator
Re: New Features for Hudson 3.1 [message #1005455 is a reply to message #997583] Fri, 25 January 2013 09:04 Go to previous messageGo to next message
Hello Duncan,
We would like to help you make Hudson a better product and benefit from it Smile. We are administrating Hudson in an enterprise environment: hundreds of jobs, over one hundred users, dozens of slaves. I hope you find provided list useful and make a good use of it. I followed your recommendation and created either bug or enhancements ticket in bugzilla for every entity from the list. Once again, please listen to your users and pay attantion to provided list since it required substantial amount of time to prepare it and we all could benefit from it.
Enhancements:
1) Bug 399082 - Display pending changes not included into the build
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399082
2) Bug 399084 - Possibility to define job snapshot dependencies
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399084
3) Bug 399059 - Active Directory plugin should have option to skip global catalog requests
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399059
4) SVN plugin should be able to use TRAC as a repository browser
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399061
5) Option to export/import single job
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399063
6) Bug 399064 - Configure column on view page
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399064
7) Bug 393044 - Allow default view at user/role level
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393044
8 ) Bug 399047 - Configure Project link from finished build page
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399047
9) Bug 395475 - Delete old workspace after job get renamed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=395475
10) Bug 399057 - Manage number of information displayed by the Log Recorders
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399057
11) View jobs that inherits aettings from particular template
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399080
12) Bug 393046 - Manage tabs visibility in roles
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393046
13) Bug 393047 - Manage nodes visibility in roles
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393047
Bugs:
14) Bug 393040 - Svn push does not trigger any job - please fix pushing system, using pooling with so many jobs is network overkill
https://bugs.eclipse.org/bugs/show_bug.cgi?id=393040
15) Bug 399040 - Hudson disk-usage plugin breaks project build history layout
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399040
16) Bug 399043 - Timeline on BuildTimeTrend page does not work
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399043
17) Test Result Trend are sometimes disappearing
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399048
18) Problem with saving project changes with cascading feature
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399069
19) Frequently SVN checkout fails on SVN externals - please find proper solution - its a nightmare
Valid workaround is provided here http://www.eclipse.org/forums/index.php/t/440544/
[Updated on: Fri, 25 January 2013 09:09] by Moderator
Re: New Features for Hudson 3.1 [message #1005486 is a reply to message #1005455] Fri, 25 January 2013 11:04 Go to previous messageGo to next message
Hi Krzysztof, thanks for the list. We will certainly consider these in the upcoming releases.
Re: New Features for Hudson 3.1 [message #1014257 is a reply to message #1005486] Mon, 25 February 2013 08:10 Go to previous messageGo to next message
A few new ideas from my team you might be interested in
20) Add time to the build logs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401691
21) Problem with usability Role-based Authorization Strategy plugin
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401524
22) Installing slave as windows service does not work
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401530
23) Display content of config.xml from administration panel
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401656
24) After renaming node, references from all jobs are lost to this node
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401683
25) Create "Last successful aritacts column" in the view
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401687
26) Aborted and disabled projects are represented by the same gray circle
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401690
Regards!
Re: New Features for Hudson 3.1 [message #1014993 is a reply to message #1014257] Wed, 27 February 2013 02:38 Go to previous messageGo to next message
Poll SCM supports https protocal?
Re: New Features for Hudson 3.1 [message #1015180 is a reply to message #1014257] Wed, 27 February 2013 11:44 Go to previous message
K.Z, thanks for these enhancement requests. We are working on 3.0.1 (manly bug fixes to stabilize 3.0.0) which we expect to release around middle of march and then consider these fr 3.1.
Previous Topic:Migration to 3.0 - copyArtifacts problem
Next Topic:Hudson 3.0.0 + Maven 3
Current Time: Sat Jul 26 20:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.03289 seconds
