Generating ER Diagrams from UML [message #1012811] |
Fri, 22 February 2013 04:08  |
Is there a way to generate E/R diagram & DDL using Teneo or any other Eclipse Modeling Project Tool from a UML diagram created in another Eclipse modeling tool- Papyrus. Papyrus supports XMI export.
I can import the diagram created in Papyrus to Erwin. I was looking for an eclipse plugin which would work integrated with Papyrus & EMF to take XMI/UML as an input and help generate an ER diagram and DDL for it.
Teneo's description looks promising - but does it support XMI/EMF ? I tried out the plugin DBeaver- but it doesnt seem to allow XMI import.
It would be great to move from UML to detailed ER diagram to DDL via one tool.
Re: Generating ER Diagrams from UML [message #1014128 is a reply to message #1014078] |
Mon, 25 February 2013 03:09  |
Hi Roshni,
There is no direct menu option to do such things.
What Teneo offers is an ecore --> hbm --> ddl transformation. But you have to write some code for this (but not much,
like 20 lines or so).
gr. Martin
On 02/25/2013 06:38 AM, roshni rajagopal wrote:
> Thanks Martin,
> But can I start with a UML class diagram in Eclipse Modeling Tools or Eclipse Papyrus, and then convert that class
> diagram to an E/R diagram? Maybe by marking some classes as ORM persistable or some other sterotype?
> I dont want a bottom approach where i code something, and generate a diagram /DDL. Is a top down approach starting from
> a UMl diagram to ER diagram to DDL possible using Eclipse Modeling tools?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.07328 seconds
