org.w3c.dom.css; version=2.0.0 ? [message #1007619] |
Wed, 06 February 2013 13:22  |
I am using Eclipse 4.2 for RCP/RAP with Java 1.7 from Oracle on Windows 7.
It seems that some of the e4 ui plugins depend upon org.w3.dom.css; version=2.0.0.
Where can I find this?
How do I tell Eclipse to "use it"?
Thank you.
P.S. This is a restatement of a prior question based upon advice I receive on posting questions to this newsgroup.
Re: org.w3c.dom.css; version=2.0.0 ? [message #1007874 is a reply to message #1007664] |
Thu, 07 February 2013 15:37   |
Hi Tom,
I get the same error when I use the wizard
File, New, Other, Eclipse 4, Eclipse 4 Application Project
then launch the product
Thank you.
Here is the output:
!SESSION 2013-02-07 12:36:46.762 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product com.example.trying.product
Command-line arguments: -product com.example.trying.product -data C:\e4RCP\workspace/../runtime-com.example.trying.product -dev file:C:/e4RCP/workspace/.metadata/.plugins/org.eclipse.pde.core/com.example.trying.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2013-02-07 12:36:47.763
!MESSAGE Product com.example.trying.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2013-02-07 12:36:47.849
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.850
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.e4.ui.services_0.10.2.v20120726-172631.jar was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.services 2 0 2013-02-07 12:36:47.850
!MESSAGE Missing imported package org.w3c.dom.css_2.0.0.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.10.2.v20120802-184737.jar was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-02-07 12:36:47.851
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.851
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.e4.ui.css.swt_0.10.2.v20120821-165957.jar was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt 2 0 2013-02-07 12:36:47.851
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.852
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.e4.ui.workbench.renderers.swt_0.10.2.v20120814-175454.jar was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt 2 0 2013-02-07 12:36:47.852
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624.jar was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt.theme 2 0 2013-02-07 12:36:47.853
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.853
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.e4.ui.css.core_0.10.2.v20120806-171245.jar was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.core 2 0 2013-02-07 12:36:47.853
!ENTRY org.eclipse.osgi 2 0 2013-02-07 12:36:47.883
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.884
!MESSAGE Bundle org.eclipse.e4.ui.css.swt_0.10.2.v20120821-165957 [1] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt 2 0 2013-02-07 12:36:47.884
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.core_0.9.0.
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.885
!MESSAGE Bundle org.eclipse.e4.ui.workbench.swt_0.10.2.v20120802-184737 [22] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-02-07 12:36:47.885
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench_0.10.0.
!MESSAGE Missing required bundle org.eclipse.e4.ui.services_0.1.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-02-07 12:36:47.886
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt_0.9.0.
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt.theme_0.9.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.swt 2 0 2013-02-07 12:36:47.887
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.887
!MESSAGE Bundle org.eclipse.e4.ui.services_0.10.2.v20120726-172631 [35] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.services 2 0 2013-02-07 12:36:47.887
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.888
!MESSAGE Bundle org.eclipse.e4.ui.workbench.renderers.swt_0.10.2.v20120814-175454 [42] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt 2 0 2013-02-07 12:36:47.888
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench_0.9.0.
!MESSAGE Missing required bundle org.eclipse.e4.ui.services_0.9.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt 2 0 2013-02-07 12:36:47.889
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench.swt_0.9.0.
!SUBENTRY 2 org.eclipse.e4.ui.workbench.renderers.swt 2 0 2013-02-07 12:36:47.890
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.890
!MESSAGE Bundle org.eclipse.e4.ui.css.core_0.10.2.v20120806-171245 [43] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.core 2 0 2013-02-07 12:36:47.890
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.891
!MESSAGE Bundle org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624 [51] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.css.swt.theme 2 0 2013-02-07 12:36:47.891
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.swt_0.9.1.
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-07 12:36:47.892
!MESSAGE Bundle org.eclipse.e4.ui.workbench_0.10.3.v20120822-140642 [52] was not resolved.
!SUBENTRY 2 org.eclipse.e4.ui.workbench 2 0 2013-02-07 12:36:47.892
!MESSAGE Bundle com.example.trying_1.0.0.qualifier [60] was not resolved.
!SUBENTRY 2 com.example.trying 2 0 2013-02-07 12:36:47.893
!MESSAGE Missing required bundle org.eclipse.e4.ui.services_0.10.2.
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench_0.10.3.
!MESSAGE Missing required bundle org.eclipse.e4.ui.workbench.swt_0.10.2.
!SUBENTRY 2 com.example.trying 2 0 2013-02-07 12:36:47.894
!MESSAGE Missing required bundle org.eclipse.e4.ui.css.core_0.10.2.
!ENTRY org.eclipse.osgi 4 0 2013-02-07 12:36:47.898
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
FUDForum. Page generated in 0.12077 seconds
