Home » Language IDEs » Java Development Tools (JDT) » Eclipse Automated Testing Framework
Eclipse Automated Testing Framework [message #100911] Fri, 03 October 2003 06:24 Go to next message
Originally posted by: rsudra.hotmail.com
Dear all,
I have been taking a look at how Eclipse (and our own plugins) can be tested
using the automated testing framework. I have been looking at some of the
test code as I want to see how the framework is used to test package
methods, and how it achieves this considering that the test plugin and the
target plugin are loaded using separate classloaders.(and therefore no
visibility). I haven't stumbled on any examples yet, could anyone point some
out?
I have been able to solve this problem using reflection but I wanted to see
how the eclipse engineers do it, or do they just test only public methods.
Bear in mind that I do not want to test private methods, just public and
package ones.
Raj
Re: Eclipse Automated Testing Framework [message #101138 is a reply to message #100911] Fri, 03 October 2003 16:04 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
We generally only test public classes and methods. However, you can
have multiple plugins that define the same package to access
package-private members across plugins. In rare cases we'll embed a
public "back door" method in a non-API package that exposes certain data
structures for testing.
Rajeev Sudra wrote:
> Dear all,
> out?
> package ones.
> Thanks
> Raj
Re: Eclipse Automated Testing Framework [message #101352 is a reply to message #101138] Sat, 04 October 2003 20:26 Go to previous messageGo to next message
On Fri, 03 Oct 2003 16:04:04 -0400, John Arthorne <John_Arthorne@oti.com_>
wrote:
> We generally only test public classes and methods. However, you can have
> multiple plugins that define the same package to access package-private
> members across plugins. In rare cases we'll embed a public "back door"
> method in a non-API package that exposes certain data structures for
> testing.
Accessing cross-plugins package-private members was broken in 2.1.1.
It seems to work now in 3.0 M3, (I just did a quick check).
So I would recommend an ugly kludge in 2.1.1, i.e. to have a
method like :
public static void makeAccessible( Class c ) {
Field[] lf = c.getDeclaredFields();
for( int i = 0; i < lf.length; i++ )
if( (lf[ i ].getModifiers() & Modifier.PUBLIC) != 0 )
lf[ i ].setAccessible( true );
Method[] lm = c.getDeclaredMethods();
if( (lm[ i ].getModifiers() & Modifier.PUBLIC) != 0 )
lm[ i ].setAccessible( true );
(Of course in your TEST plugin, not in release code ;-)
And to call it from your test cases.
When you will migrate to 3.0 just remove this method and its references.
Steve
Re: Eclipse Automated Testing Framework [message #103183 is a reply to message #101352] Fri, 10 October 2003 15:42 Go to previous messageGo to next message
Well, I actually misanswered. It is possible to do this across Eclipse
projects in your workspace, but since each Eclipse plugin has its own
classloader, they cannot share package visible members.
> I mistested. M3 still have the issue. There is a bug logged:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=37647
Re: Eclipse Automated Testing Framework [message #103356 is a reply to message #103183] Sat, 11 October 2003 23:27 Go to previous message
I misunderstood what you misanswered ;-)
Anyway, I fully agree with the fact that plugins must have
separate class loaders, but it would be great
that for testing purpose only we could bypass this scheme.
I logged an enhancement request :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44709
Feel free to vote ;-)
Steve
Previous Topic:How do I change default workspace location?
Next Topic:how to enable assertions
Current Time: Tue Jul 22 00:54:02 EDT 2025
Powered by FUDForum. Page generated in 0.23603 seconds
