Home » Modeling » ATL » Using external parameters in ATL
Using external parameters in ATL [message #1013333] Sat, 23 February 2013 06:01 Go to next message
Hi!!
I am trying to use external parameters with ATL transformations. I am followed the help at ATL_Howtos.
I have also downloaded the org.eclipse.m2m.atl.projectors.xml plugin developed for Juno from docatlanmod.emn.fr and located it in the Eclipse installation folder. In particular, I have trying to copy it to the droppings and plugins folders, even to the ATL proyect folder in my workspace, but it does not work.
I get the error:
Error loading platform:/resource/ATLProyect/InputModels/parameters.xml: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found. (platform:/resource/ATLProyect/InputModels/parameters.xml, 1, 13)
Could anybody help me?
Thanks in advance!!
Bea
Re: Using external parameters in ATL [message #1013336 is a reply to message #1013333] Sat, 23 February 2013 06:12 Go to previous messageGo to next message
Looks like a bad XML file; nothing to do with ATL.
It's always worth using the Sample (Reflective) Ecore Editor to check
whether your files are useable.
Ed Willink
On 23/02/2013 11:01, Bea Perez wrote:
> Hi!!
> I get the error:
> Error loading
> 'null' not found.
> Thanks in advance!!
> Bea
Re: Using external parameters in ATL [message #1013338 is a reply to message #1013336] Sat, 23 February 2013 06:18 Go to previous messageGo to next message
Thanks Ed Willink!!
I am trying with the simple parameters XML file available at http://wiki.eclipse.org/ATL_Howtos#How_can_I_tune_the_XML_output_of_ATL:
<parameters>
<param name="param1" value="valueX"/>
<param name="param2" value="valueY"/>
</parameters>
Any clue?
Re: Using external parameters in ATL [message #1013342 is a reply to message #1013338] Sat, 23 February 2013 06:34 Go to previous messageGo to next message
I have no familiarity with the example, but XML files start with:
<xml ...
Ed Willink
On 23/02/2013 11:18, Bea Perez wrote:
> Thanks Ed Willink!!
> <parameters>
> </parameters>
> Any clue?
Re: Using external parameters in ATL [message #1013347 is a reply to message #1013342] Sat, 23 February 2013 06:51 Go to previous messageGo to next message
Yes, I have tried with something as:
<parameters>
</parameters>
but nothing...
Re: Using external parameters in ATL [message #1013356 is a reply to message #1013347] Sat, 23 February 2013 07:33 Go to previous messageGo to next message
I suggest that you learn about basic XML files before trying to tune them.
Ed Willink
> <parameters>
> </parameters>
> but nothing...
Re: Using external parameters in ATL [message #1013834 is a reply to message #1013333] Sun, 24 February 2013 07:41 Go to previous messageGo to next message
Op 23-02-13 12:01, Bea Perez schreef:
> Hi!!
> I get the error:
> Thanks in advance!!
> Bea
EMF is trying to load the XML file instead of ATL's XML injector. Note that
you can only use ATL injectors from within Ant scripts.
Dennis
Re: Using external parameters in ATL [message #1014168 is a reply to message #1013834] Mon, 25 February 2013 04:35 Go to previous message
As said by Dennis, you first need to inject your XML file as an XML model (i.e.; a model that conforms to an XML metamodel).
In order to do this, an XML injector is available from http://docatlanmod.emn.fr/ATL/Plugins/org.eclipse.m2m.atl.projectors.xml_0.4.0.jar (built with/for Eclipse Juno but should work with other versions) and can be launched via ATL Ant scripts or programmatically.
If needed, the sources of this plugin are also available from http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.modisco/incubation/trunk/am3/plugins/trunk/org.eclipse.m2m.atl.projectors.xml/
Hugo
Previous Topic:model merging
Next Topic:setValue on reference tag values of stereotyped elements
Current Time: Thu Jul 24 23:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.06587 seconds
