Home » Newcomers » Newcomers » Eclipse not removing moved files from CVS repository
Eclipse not removing moved files from CVS repository [message #100985] Sat, 10 September 2005 00:46 Go to next message
Originally posted by: neil.JAMMConsulting.com
Hello:
I am using eclise 3.1 on Windows XP and am migrating an existing project
from NetBeans to eclipse.
I have CVS running on an external server with a repository of files.
When I move a file from one directory to another and then commit
the changes, I end up with both copies in the repository.
Shouldn't eclipse remove the file from the old location in the
repository?
Neil
Neil Aggarwal, JAMM Consulting, (214)986-3533, www.JAMMConsulting.com
FREE! Valuable info on how your business can reduce operating costs by
17% or more in 6 months or less! http://newsletter.JAMMConsulting.com
Re: Eclipse not removing moved files from CVS repository [message #101063 is a reply to message #100985] Sat, 10 September 2005 10:22 Go to previous messageGo to next message
Hello:
I took a closer look, actually, it removed the files, but the directories
are still there. I think I need to do a release on the directories.
Is there a way to do that from eclipse?
Neil
"Neil Aggarwal" <neil@JAMMConsulting.com> wrote in message
news:dftoe8$c0q$1@news.eclipse.org...
> Hello:
> repository?
> Neil
Re: Eclipse not removing moved files from CVS repository [message #101330 is a reply to message #101063] Mon, 12 September 2005 12:14 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
Neil Aggarwal wrote:
> Hello:
CVS does not really manage directories, only files. There is an option
under Preferences > Team > CVS > Files and Folders (tab) to Prune empty
directories - make sure it is checked.
HTH,
Eric
Re: Eclipse not removing moved files from CVS repository [message #102500 is a reply to message #101330] Fri, 16 September 2005 11:31 Go to previous messageGo to next message
Eric:
Thanks for the lead, but it is already checked. Any ideas why it is not
doing so?
Neil
"Eric Rizzo" <eclipse3@rizzoweb.com> wrote in message
news:dg49lq$f2t$1@news.eclipse.org...
>> Hello:
> HTH,
> Eric
Re: Eclipse not removing moved files from CVS repository [message #140708 is a reply to message #102500] Tue, 28 February 2006 06:57 Go to previous message
>>>>> "Neil Aggarwal" <neil@JAMMConsulting.com>:
> not doing so?
Do you have any non-versioned files in these directories? Prune
doesn't work for directories that have files in them.
Previous Topic:xyz-feature does not have a valid license agreement
Next Topic:Can't delete text in source file!
Current Time: Sun Jun 08 15:04:52 EDT 2025
Powered by FUDForum. Page generated in 0.08527 seconds
