Home » Language IDEs » Java Development Tools (JDT) » Unhandled exception caught in event loop.
Unhandled exception caught in event loop. [message #98154] Tue, 23 September 2003 04:20 Go to next message
Originally posted by: werner.keplinger.fh-hagenberg.at
I want to create an object of a class, that is not on the classpath.
Executed in a normal main-method the code snippet below works perfectly to
achieve that, however when it is executed in the run-method of an
IObjectActionDelegate I get the following error message: "Unhandled
exception caught in event loop.".
What is the reason for that error message? How can it be avoided ?
Werner
//===code
snippet===================================================== =========
String absoluteClassFileLocation = ...;
String packageName = ...;
String className= ...;
File classFile = new File(absoluteClassFileLocation);
URLClassLoader classloader = URLClassLoader.newInstance(new URL[]
classFile.toURL()});
Class c = classloader.loadClass(packageName + "." + className);
try {
Constructor constructor = c.getConstructor(new Class[] {
String.class });
Object o = constructor.newInstance(new Object[] {"aString" });
} catch (Exception e) {
e.printStackTrace();
Re: Unhandled exception caught in event loop. [message #98169 is a reply to message #98154] Tue, 23 September 2003 10:18 Go to previous messageGo to next message
Originally posted by: richkulp.NO--SPAM.us.ibm.com
Take a look in the .metadata/.log file. The full stack trace should be
in there.
Rich
Re: Unhandled exception caught in event loop. [message #101328 is a reply to message #98169] Sat, 04 October 2003 19:32 Go to previous message
Got too bored with that. Finally logged a bug,
if you want to vote ;-)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44188
Steve
Previous Topic:stupid simple question about indention
Next Topic:Using Sun's deadlock detection utility (i.e., ctrl-break on console)
Current Time: Sat Sep 06 04:26:52 EDT 2025
Powered by FUDForum. Page generated in 0.03103 seconds
