Home » Modeling » TMF (Xtext) » Xtext: Couldn't resolve reference to JvmType 'String'
Xtext: Couldn't resolve reference to JvmType 'String' [message #1012559] Thu, 21 February 2013 14:45 Go to next message
I already posted it on Stackoverflow but was hoping to reach more experts here Smile
For our master project at university we created multiple DSLs using Xtext. One of the DSLs is a model entity DSL which allows the user to create a class with properties and methods.
We reuse Xbase because, of course, we want the methods to have a real programming language without reinventing the wheel:
grammar ... with org.eclipse.xtext.xbase.Xbase
generate ...
EntityModel:
    'package' importedNamespace=QualifiedName
    implementation=Entity;
Entity:
    'entity' name=ValidID '{'
        features+=Feature*
Feature:
    LocalVariable | ...;
LocalVariable:
    'var' (isStatic?='static')? name=ValidID ':' type=JvmTypeReference;
For some reason, even though the type of the LocalVariable is set to JvmTypeReference, when using String (in an actual implementation), it will always show the error
package com.example
Entity foo {
    var bar: String
We already tried using a ImportedNamespaceAwareLocalScopeProvider which in getImportedNamespaceResolvers adds java.lang.* like that:
List<ImportNormalizer> implicitImports = super.getImportedNamespaceResolvers(context, ignoreCase);
List<ImportNormalizer> javaLangImports = singletonList(new ImportNormalizer(QualifiedName.create("java", "lang"), true, ignoreCase));
implicitImports.addAll(javaLangImports);
return implicitImports;
Even thought that method is called a lot of times, the imports still don't work. When inspecting the EObject context parameter, it sometimes returns java.lang.String (which I guess is for the JvmTypeReference but it still displays an error.
In the RuntimeModule the new scope provider is configured like that:
public void configureIScopeProviderDelegate(com.google.inject.Binder binder) {
    binder.bind(org.eclipse.xtext.scoping.IScopeProvider.class).annotatedWith(com.google.inject.name.Names.named(org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.NAMED_DELEGATE)).to(MasterDSLImportedNamespaceAwareLocalScopeProvider.class);
In the Workflow we configured
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
fragment = xbase.XbaseGeneratorFragment {}
fragment = types.TypesGeneratorFragment {}
The rest of the project is quite complex already (4 Xtext DSLs in one project and multiple generators). But except for completely different DSLs, they use almost the same workflow and RuntimeModule configuration. Another DSL also uses JvmTypeReference and also doesn't find e.g. boolean or anything else.
The question of course is: are we doing something wrong or is there something else we have to do. It used to work when we had a significantly smaller project but after some major changes suddenly this stopped working.
The model implementations (*.model) can be highlighted and everything but those imports just won't work Sad
Also, some parts of XExpression (like !=) are highlighted as not being recognized from the parser.
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1012565 is a reply to message #1012559] Thu, 21 February 2013 15:09 Go to previous messageGo to next message
please note: the model project (with you my.mydsl file within) has to be a java project. needed libs (e.g. xbase.lib) have to be on the classpath
then it will work out of the box without any mods.
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1012579 is a reply to message #1012565] Thu, 21 February 2013 15:46 Go to previous messageGo to next message
It is a Java project (or alternatively uses a custom project wizard) and I already checked that it includes the Java rt.jar (and manually included the xtend library). But still, it doesn't work anymore. Is it possible that I accidentally overwrote configuration (maybe there is some important property you are not supposed to change? Wink which prevents the whole runtime from recognizing the classpath or something?
I forgot to mention that we're using Xtext 2.3. Can using Java 7 be the problem?
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1012741 is a reply to message #1012579] Fri, 22 February 2013 01:48 Go to previous messageGo to next message
Hi hard to say I'd try to create a new project and adopt your changes
step by step to see what causes the problem
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1013036 is a reply to message #1012741] Fri, 22 February 2013 11:38 Go to previous messageGo to next message
The problem is, that we're using 3 DSLs in a single project and separate projects for generators so by now our project is quite huge and I'm kind of afraid to recreate all the projects Wink
BTW. is there a right way of having multiple (4) DSLs and a single project for that? We're using one workflow with multiple Generator components ("component = Generator"). Or would have be using multiple projects be easier (two times two DSLs are depending on one another)?
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1013038 is a reply to message #1013036] Fri, 22 February 2013 11:42 Go to previous messageGo to next message
is there a specific reason to do so? it is supported but usually not done.
what kind of dependency is this "depending to each other"?
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1013040 is a reply to message #1013038] Fri, 22 February 2013 11:49 Go to previous messageGo to next message
Have have different DSLs for different parts of our project (UI, BL, Model, Config DSLs) and the Config DSL defines the entrance point via a reference to the BL DSL. The UI DSL has a reference to the code-behind BL DSL as well as Handler-Functions in the BL.
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1013043 is a reply to message #1013040] Fri, 22 February 2013 11:53 Go to previous messageGo to next message
so the dependency is on metamodel level only? if so a manually maintained may help to split up.
but as i said before: i think it should work with one project too.
~Christian
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1013284 is a reply to message #1013043] Sat, 23 February 2013 02:42 Go to previous messageGo to next message
Thanks for the help. We also prefer the single project to keep it "simple" Wink
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1015151 is a reply to message #1012559] Wed, 27 February 2013 10:25 Go to previous messageGo to next message
Does it work with
var bar: java.lang.String
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1101006 is a reply to message #1015151] Tue, 03 September 2013 18:46 Go to previous messageGo to next message
hi all,
I got the same problem when using the EmbeddedEditor. the content assist for the JvmTypeReference in the EmbeddedEditor doesn't work as well although it works in the normal editor.
any idea?
thanks in advance for the advise.
cheers,
Ferry
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1101189 is a reply to message #1101006] Wed, 04 September 2013 01:42 Go to previous messageGo to next message
Do you have a backing java project. The content assist uses jdt to
propose.
Re: Xtext: Couldn't resolve reference to JvmType 'String' [message #1101663 is a reply to message #1101189] Wed, 04 September 2013 15:49 Go to previous message
If still no solution to the original point, here's the few lines where I did something very similar in my delegate scope provider which extends ImportedNamespaceAwareLocalScopeProvider.
It looks like the same idea as you have but is slightly different
static val JAVA_LANG = QualifiedName::create("java","lang")
static val builtinList = newArrayList(
		 new ImportNormalizer(JAVA_LANG, true, false)
override List<ImportNormalizer> getImplicitImports(boolean ignoreCase) {
	    return builtinList
This is xtend and you may have Java but I did have it in Java originally in Xtext 2.3 and it worked there.
Previous Topic:Unique identifiers across XText resources
Next Topic:View Toolbar
Current Time: Fri Jul 25 22:05:42 EDT 2025
Powered by FUDForum. Page generated in 0.71460 seconds
