Home » Archived » Jubula » Why jubula hangs waited for unlimited time while checking for the text is correct or not?
Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1012714] Thu, 21 February 2013 23:57 Go to next message
Why jubula waiting for Unlimited time while checking for the text is correct or not.
Shocked .Is there any one who can help me out in this problem
[Updated on: Fri, 22 February 2013 00:20] by Moderator
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1012752 is a reply to message #1012714] Fri, 22 February 2013 02:21 Go to previous messageGo to next message
Sorry, but with the amount of information you provided it's next to impossible to even make a guess what the problem might be.
- Achim
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1012797 is a reply to message #1012752] Fri, 22 February 2013 03:38 Go to previous messageGo to next message
I am going to paste the structure of my test cases as this same test case is working fine with the other test suites as i am reusing it again and agian.If i have 10 test cases than some times it is coming at step 6 sometimes it is coming at step 9 so u could not guess when it will come.I have also given the test suites structure
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1014557 is a reply to message #1012714] Mon, 25 February 2013 22:22 Go to previous messageGo to next message
Hi achim ;
I have pasted all the information can you help me to find out the problem
[Updated on: Mon, 25 February 2013 22:22] by Moderator
Re: Why jubula hangs waited for unlimited time while checking for the text is correct or not? [message #1015002 is a reply to message #1014557] Wed, 27 February 2013 02:53 Go to previous message
Rajesh - please add test result reports that demonstrate the structure and the problem.
Previous Topic:What should I do to use column title in SelectEntryByTextpath _specifyColumn)
Next Topic:How to switch between 2 aut in windows 7?
Current Time: Thu Nov 06 19:49:15 EST 2025
Powered by FUDForum. Page generated in 0.03137 seconds
