Home » Modeling » OCL » CompleteOCL standalone validation of uml model
CompleteOCL standalone validation of uml model [message #1011884] Wed, 20 February 2013 07:24 Go to next message
Hi all,
I´m trying to do a OCL-validation of a umlmodel in a standalone application. I tried to do this with the CompleteOCLEObjectValidator and all works fine for validating constraints with functions included in oclstdlib or with attributes of my model, such as "self.name = 'SysMLmodel'". But if i try to validate a constraint using a function that is not in the oclstdlib,e.g "self.allOwnedElements()" the result is always "OCL validation result of 'PackImport' is invalid". I debugged this an thats because of no Implementation of "allOwnedElements" is found. I´m using indigo..
Here is my code:
public class TestValidator extends CompleteOCLEObjectValidator{
public TestValidator(EPackage ePackage, URI oclURI) {
super(ePackage, oclURI);
// TODO Auto-generated constructor stub
public static void main(String[] args){
CompleteOCLStandaloneSetup.doSetup();
OCLstdlibStandaloneSetup.doSetup();
EssentialOCLStandaloneSetup.doSetup();
OCLstdlib.install();
UMLPackage uml = UMLPackage.eINSTANCE;
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(SysmlPackage.eNS_URI, SysmlPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(BlocksPackage.eNS_URI, BlocksPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(resourceSet.getResourceFactoryRegistry().DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
URI uri = URI.createFileURI("D:/.../model.uml");
EPackage.Registry.INSTANCE.put("D:/.../model.uml",UMLPackage.eINSTANCE);
URI ocluri = URI.createFileURI("D:/.../test.ocl");
Resource resource = resourceSet.createResource(uri);
try {
resource.load(null);
System.out.println("Model: load complete");
} catch (IOException e) {
e.printStackTrace();
Model m = (Model) EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.MODEL);
org.eclipse.ocl.uml.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.uml.UML2Pivot.initialize(null);
String oclDelegateURI2 = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI2,
new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI2,
new OCLSettingDelegateFactory.Global());
EValidator.ValidationDelegate.Registry.INSTANCE.put(oclDelegateURI2,
new OCLValidationDelegateFactory.Global());
CompleteOCLEObjectValidator val = new TestValidator(UMLPackage.eINSTANCE,ocluri);
EValidator.Registry.INSTANCE.put(UMLPackage.eINSTANCE,val);
EValidator.Registry.INSTANCE.put(SysmlPackage.eINSTANCE,val);
Diagnostic diag = Diagnostician.INSTANCE.validate(m);
System.out.println(diag.getMessage());
for(Diagnostic object : diag.getChildren()){
System.err.println(object.getMessage());
How do I get the functions, like allOwnedElements(), registered in my Application?
best regards,
Basti
Re: CompleteOCL standalone validation of uml model [message #1011937 is a reply to message #1011884] Wed, 20 February 2013 09:38 Go to previous messageGo to next message
HI
Support for UML with the new-pivot based OCL that goes hand-in-hand with
the Xtext tooling is steadily improving.
The additional MDT/UML2 utility functions were not available in the Juno
release. If you use the Kepler M5 download you should have more joy; I
hope. Otherwise I've got some debugging to do.
If you're prepared to install the Kepler M5 versions of EMF, UML2,
Xtext, OCL etc you can probably continue to use Indigo.
Ed Willink
On 20/02/2013 14:23, Ba sti wrote:
> Hi all,
> Here is my code:
> Quote:
>> try {
>> Model m = (Model)
> Application?
> best regards,
> Basti
Re: CompleteOCL standalone validation of uml model [message #1012315 is a reply to message #1011937] Thu, 21 February 2013 05:31 Go to previous messageGo to next message
thanks for your reply!
While trying to install these new versions, i got serveral conflicts like this one:
Software currently installed: Eclipse SDK 3.7.2.M20120208-0800 (org.eclipse.sdk.ide 3.7.2.M20120208-0800)
Only one of the following can be installed at once:
Equinox Launcher 1.3.0.v20130125-144918 (org.eclipse.equinox.launcher 1.3.0.v20130125-144918)
Equinox Launcher 1.2.0.v20110502 (org.eclipse.equinox.launcher 1.2.0.v20110502)
How can i update the current versions, so eclipse is able to install the new features?
Basti
Re: CompleteOCL standalone validation of uml model [message #1012323 is a reply to message #1012315] Thu, 21 February 2013 05:50 Go to previous messageGo to next message
You trimmed the opaque error report and so I can't tell which tool has
an Indigo problem.
On 21/02/2013 10:31, Ba sti wrote:
> Hi, thanks for your reply!
> like this one:
> Only one of the following can be installed at once: Equinox
> 1.2.0.v20110502)
> the new features?
> Regards,
> Basti
Re: CompleteOCL standalone validation of uml model [message #1012389 is a reply to message #1012323] Thu, 21 February 2013 08:21 Go to previous message
Now I´m using the Kepler M5 release and with that, my Application works fine..
Thanks for your help!
Previous Topic:Limitations of OCL
Next Topic:OCL for XCore
Current Time: Wed Jul 23 11:50:18 EDT 2025
Powered by FUDForum. Page generated in 0.24189 seconds
