Home » Modeling » EMF » Proper way to update UI from EContentAdapter
Proper way to update UI from EContentAdapter [message #1011970] Wed, 20 February 2013 11:04 Go to next message
I have an econtent adapter that is essentially causing the refresh of numerous tables. While it is theoretically possible to filter all notifications down to the exact notifications that should cause a refresh on the tables, it would be extraordinarily difficult and time-consuming as we have a massive model, and many different events and changes that could possibly trigger a refresh. Also, what often happens is a single "user-event" (like clicking state->new in our application), triggers 4 objects being created behind the scenes, all of which look very similar from the notification standpoint and therefore makes it difficult to filter out. I'm wondering if there is a good way to do some sort of "delayed job" so that the 4 notifications only cause a single refresh. For example, something similar to:
 public void notifyChanged(final Notification notification)
     super.notifyChanged(notification);
     public void run() {
         if(matchesFilters(notification)) {
              //some sort of check to see if we recently had another event that would have triggered a refresh?
              if(!schedulingJob) {
                  scheduleDelayedJob();
Unfortunately I have little experience in jobs and things like that, so it would be very helpful if someone could give assistance in what the proper way of doing this is.
Re: Proper way to update UI from EContentAdapter [message #1011974 is a reply to message #1011970] Wed, 20 February 2013 11:08 Go to previous messageGo to next message
Or as another example, if someone just hits control-N 20 times in our application very rapidly, it will rapidly create 20 new states, and we would just want to update the UI at the end of those 20 notifications, not refresh 20 times.
Re: Proper way to update UI from EContentAdapter [message #1011978 is a reply to message #1011970] Wed, 20 February 2013 11:11 Go to previous message
Jonathan,
Comments below.
> similar to:
> @Override
> public void run() {
> if(matchesFilters(notification)) { //some sort of
In
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvider.notifyChanged(Notification)
you can see it uses a
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvider.ViewerRefresh
to do something like that.
Are you using an EditingDomain to support undo? In that case, listening
to the command stack would be much easier. That's how the generated
editor updates the properties view...
Previous Topic:[EMF Compare] Migration from version 1.3 to 2.1
Next Topic:[Teneo] Errors when deploying teneo 2.0.1 + hibernate 4 in JBoss 7
Current Time: Wed Jul 23 12:36:16 EDT 2025
Powered by FUDForum. Page generated in 0.07350 seconds
