Home » Archived » Riena » Eclipse package for Riena
Eclipse package for Riena [message #1011623] Tue, 19 February 2013 18:09 Go to next message
I would like to test and check the Riena platform.. Smile
There is no predefined Eclipse Download package for Riena development, like other ones at eclipse.org/downloads...
It's a bit demotivating to spend "a lot of time" to find the right combination of eclipse/riena versions/correct update site links.. before seeing some sample application.
I tried Eclipse 4.2, 3.8 to install the Riena core plugin and the Toolbox, but there is everytime another error: Link, download etc.
http://wiki.eclipse.org/Riena_Getting_started
I would appreciate it, if one could provide a complete Eclipse Riena download package with Riena Plugin and Toolbox for a quick start.
Thanks in advance!
Kind regards,
Max Reeb
Re: Eclipse package for Riena [message #1011965 is a reply to message #1011623] Wed, 20 February 2013 10:51 Go to previous messageGo to next message
The link that you point to leads you to http://wiki.eclipse.org/Riena/E4
It has a detailed description (I think) for downloading Eclipse 4.3 and Riena in its current 5.0.0.M5 form.
For 3.8 we have http://wiki.eclipse.org/Riena/Downloads
I am not sure what kind of errors you get since you didnt specify them. But I'd like what the problems are.
You can either post them here or open a bug report on bugzilla http://bugs.eclipse.org
About the topic of a Riena-Eclipse IDE. The Riena Toolbox is only a small toolbox for Riena. Basically you can take any Eclipse IDE, installed Equinox, RCP and Riena into the Target Platform and then you can import samples or right your own code.
Normally you do that using P2 and Target Platform UI of the Eclipse IDE. There is also a "Download complete target platform" link on the page http://wiki.eclipse.org/Riena/Downloads. This contains the whole Target Platform (Equinox, RCP and Riena) Is that what you are looking for ?
let me know how we can help you
christian campo
Re: Eclipse package for Riena [message #1013102 is a reply to message #1011623] Fri, 22 February 2013 14:44 Go to previous messageGo to next message
thanks for the quick help!
1. I have now installed Eclipse 4.3.
2. Created a target platform (see also attached screenshot..)
-Equinox Target Components
-Eclipse RCP
-Eclipse RCP SDK
-Eclipse RCP Plug-in Developer Resources
-Riena Core Target Components
-Riena Samples Target Components
-Riena Target Components
3. Importet the Riena Client Example
4. Added SWT to the build path
5. Added automatically the required plugins within the run configuration.
Now I get the following error by starting the example: java.lang.NullpointerException
I have no idea, if there are missing additional components are I have used a wrong combination of versions..
Thanks in advance!
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments:  -application org.eclipse.riena.example.client.exampleapp
Command-line arguments:  -application org.eclipse.riena.example.client.exampleapp -data C:\Users\******\Desktop\Software\EclipseWorkspace\kepler/../runtime-New_configuration -dev file:C:/Users/*******/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/dev.properties -debug C:\Users\******\Desktop\Software\EclipseWorkspace\kepler\.metadata\.plugins\org.eclipse.pde.core\SWT ExampleApplication/.options -os win32 -ws win32 -arch x86 -clean -console -consolelog
!ENTRY org.eclipse.osgi 4 0 2013-02-22 20:37:47.139
!MESSAGE Could not find bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not find bundle: org.eclipse.equinox.console
	at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:211)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:298)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Starting application: 1133
Fri Feb 22 20:37:47 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867262 ms) in thread [main]:
		LogLevel(WARNING), Message(riena.core is not started. This may probably not work.)
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=73} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=74} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867212 ms) in thread [main]:
		LogLevel(INFO), Message(No configuration given!.)
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867262 ms) in thread [main]:
		LogLevel(INFO), Message(found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.RemoteServiceFactoryHessian@1ce669e)
Fri Feb 22 20:37:47 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867272 ms) in thread [main]:
		LogLevel(DEBUG), Message(OSGi NEW service registered id: org.eclipse.riena.monitor.common.IReceiver)
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.core.util.ContainerModel DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
		LogLevel(INFO), Message(!!! Riena is running in CLIENT mode !!!)
Fri Feb 22 20:37:47 CET 2013 DEBUG [Worker-0] org.eclipse.riena.core.cache.GenericObjectCache DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
		LogLevel(DEBUG), Message(creating new GenericObjectCache instance)
		LogLevel(DEBUG), Message(setTimeout = 60000)
		LogLevel(DEBUG), Message(setMinSize = 1)
		LogLevel(DEBUG), Message(setTimeout = 999999000)
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
Fri Feb 22 20:37:47 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867292 ms) in thread [main]:
		LogLevel(DEBUG), Message(OSGi NEW service registered id: org.eclipse.riena.security.common.authentication.IAuthenticationService)
Fri Feb 22 20:37:47 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.Activator$StartupBundleListener Riena is running in stage '<unknown>'.
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=75} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=76} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.security.ui' succesful.
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.ui.ridgets.swt.optional' succesful.
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache put = DummyPrincipal , java.security.Permissions@d480ea (
 (java.lang.RuntimePermission navi)
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache processQueue
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Platform Instance Location: file:/C:/Users/TalayE1/Desktop/Software/EclipseWorkspace/runtime-New_configuration/
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Found directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client is not a directory.
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Created instance area directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigation.subapplication, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigate.form, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.sharedViews, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.uiProcesses, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.playground, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.filters, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.logcollector, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache get = DummyPrincipal
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.mgkundennummer[level=MODULEGROUP sequence=1]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.mgkundennummer, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.exceptiontest.mg[level=MODULEGROUP sequence=1]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.exceptiontest.mg, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.subModule.contentFilter[level=SUBMODULE sequence=1]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.subModule.contentFilter, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.activatedeactivate.mg[level=MODULEGROUP sequence=2]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.activatedeactivate.mg, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module onePersonSubModule[level=SUBMODULE sequence=2]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=onePersonSubModule, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.selectablesubmodule.modulegroup[level=MODULEGROUP sequence=100]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.selectablesubmodule.modulegroup, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client\simplestore
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore in development mode, trying to clean-up store.
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=77} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=78} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.monitor.client' succesful.
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Fri Feb 22 20:37:48 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=79} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=80} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=81} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=82} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=83} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=84} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=85} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=86} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=87} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=88} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=89} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=90} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=91} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=92} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=93} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=94} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=95} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=96} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=97} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=98} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=99} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/HandlerContainer/handlers/*], service.id=100} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=101} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=2147483647, service.id=102} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=103} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=104} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=105} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=106} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.eclipse.ui.IWorkbench}={service.id=107} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=108} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=109} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=110} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=111} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=112} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=113} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=114} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=115} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=116} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=117} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/*], service.id=118} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=119} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=120} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=121} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=122} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=123} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Contribution/object/*], service.id=124} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/GenericTile/horizontal/*], service.id=125} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/containerData/*], service.id=126} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=127} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=128} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=129} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=130} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=131} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=132} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=133} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=134} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=135} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=136} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=137} ServiceEvent REGISTERED
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-02-22 20:37:49.310
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
	at org.eclipse.riena.navigation.ui.controllers.ApplicationController.updateLabel(ApplicationController.java:117)
	at org.eclipse.riena.navigation.ui.controllers.ApplicationController.afterBind(ApplicationController.java:112)
	at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdvisor.doInitialBinding(ApplicationViewAdvisor.java:392)
	at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdvisor.postWindowOpen(ApplicationViewAdvisor.java:242)
	at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(WorkbenchWindow.java:1229)
	at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1264)
	at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1225)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
	at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
	at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1664)
	at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2145)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
	at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
	at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
	at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:735)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:643)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:729)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:694)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:679)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:982)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:941)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:79)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.riena.navigation.ui.swt.application.SwtApplication.createView(SwtApplication.java:69)
	at org.eclipse.riena.navigation.ui.application.AbstractApplication.start(AbstractApplication.java:70)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) started without retry
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) started without retry
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) ended (nothing to send)
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) ended (nothing to send)
Fri Feb 22 20:38:02 CET 2013 DEBUG [Worker-4] org.eclipse.riena.monitor.client.SimpleStore Store Cleaner started
Fri Feb 22 20:38:02 CET 2013 DEBUG [Worker-4] org.eclipse.riena.monitor.client.SimpleStore Store Cleaner ended
Fri Feb 22 20:37:49 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@70c242 Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-22 20:38:36.882
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@1b104d7 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@f8ae79, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 175, y: 215, width: 1024, height: 768)
!STACK 0
!ENTRY org.eclipse.riena.core 4 0 2013-02-22 20:38:36.894
!MESSAGE exception handler class org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox#handleException() throws an exception
!STACK 0
	at org.eclipse.riena.ui.swt.MessageBox.show(MessageBox.java:82)
	at org.eclipse.riena.internal.ui.ridgets.swt.MessageBoxRidget.show(MessageBoxRidget.java:91)
	at org.eclipse.riena.internal.ui.ridgets.swt.MessageBoxRidget.show(MessageBoxRidget.java:83)
	at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox.showMessageBox(ExceptionMessageBox.java:66)
	at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox.access$0(ExceptionMessageBox.java:51)
	at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox$1.run(ExceptionMessageBox.java:39)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
	at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer$SyncExecutor.execute(SwtUISynchronizer.java:245)
	at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer.executeOnDisplay(SwtUISynchronizer.java:195)
	at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer.execute(SwtUISynchronizer.java:77)
	at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer.syncExec(SwtUISynchronizer.java:55)
	at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox.handleException(ExceptionMessageBox.java:36)
	at org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager.handleException(SimpleExceptionHandlerManager.java:105)
	at org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager.handleException(SimpleExceptionHandlerManager.java:99)
	at org.eclipse.riena.navigation.ui.swt.views.ApplicationAdvisor$1.handle(ApplicationAdvisor.java:75)
	at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(WorkbenchErrorHandlerProxy.java:36)
	at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:189)
	at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:231)
	at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:305)
	at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:160)
	at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:100)
	at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:86)
	at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:205)
	at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:178)
	at org.eclipse.equinox.log.internal.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
	at org.eclipse.equinox.log.internal.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
	at org.eclipse.equinox.log.internal.LoggerImpl.log(LoggerImpl.java:54)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLogFactory$1.log(EclipseLogFactory.java:53)
	at org.eclipse.e4.ui.internal.workbench.WorkbenchLogger.log(WorkbenchLogger.java:111)
	at org.eclipse.e4.ui.internal.workbench.WorkbenchLogger.error(WorkbenchLogger.java:52)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.handleException(PartRenderingEngine.java:688)
	at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75)
	at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44)
Fri Feb 22 20:38:36 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager exception handler class org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox#handleException() throws an exception
!STACK 0
Fri Feb 22 20:38:36 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@1b104d7 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@f8ae79, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 175, y: 215, width: 1024, height: 768)
	at org.eclipse.equinox.internal.app.EclipseAppHandle.run(
Re: Eclipse package for Riena [message #1013156 is a reply to message #1013102] Fri, 22 February 2013 17:50 Go to previous messageGo to next message
I could solve now one of the problems:
"!MESSAGE Could not find bundle: org.eclipse.equinox.console"
by adding some more bundles
-org.apache.felix.gogo.command
-org.apache.felix.gogo.runtime
-org.apache.felix.gogo.shell
-org.eclipse.equinox.console
2.
Secondly I have changed the SWT 4.3 plugin by the 4.2.1.
There are still some errors...
Configuration location:
    file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/
Configuration file:
    file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/config.ini loaded
Install location:
    file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/
Framework located:
    file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.osgi_3.9.0.v20130128-202223.jar
Framework classpath:
Splash location:
    C:\Users\***\Desktop\Software\EclipseWorkspace\kepler\org.eclipse.riena.example.client\splash.bmp
Debug options:
    file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/.options loaded
Time to load bundles: 350
Starting application: 1200
osgi> Fri Feb 22 23:44:50 CET 2013 INFO [main] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=95} ServiceEvent REGISTERED
Fri Feb 22 23:44:50 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=96} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090850 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090800 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090850 ms) in thread [main]:
		LogLevel(INFO), Message(found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.RemoteServiceFactoryHessian@18e8541)
Fri Feb 22 23:44:51 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090860 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.core.util.ContainerModel DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 DEBUG [Worker-0] org.eclipse.riena.core.cache.GenericObjectCache DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=97} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.Activator$StartupBundleListener Riena is running in stage '<unknown>'.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=98} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.security.ui' succesful.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Fri Feb 22 23:44:51 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.ui.ridgets.swt.optional' succesful.
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Platform Instance Location: file:/C:/Users/TalayE1/Desktop/Software/EclipseWorkspace/runtime-New_configuration/
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Found directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client is not a directory.
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Created instance area directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache put = DummyPrincipal , java.security.Permissions@1be8711 (
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache processQueue
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigation.subapplication, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigate.form, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.sharedViews, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.uiProcesses, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.playground, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.filters, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.logcollector, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache get = DummyPrincipal
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.mgkundennummer[level=MODULEGROUP sequence=1]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.mgkundennummer, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.exceptiontest.mg[level=MODULEGROUP sequence=1]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.exceptiontest.mg, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.subModule.contentFilter[level=SUBMODULE sequence=1]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.subModule.contentFilter, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.activatedeactivate.mg[level=MODULEGROUP sequence=2]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.activatedeactivate.mg, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module onePersonSubModule[level=SUBMODULE sequence=2]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=onePersonSubModule, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.selectablesubmodule.modulegroup[level=MODULEGROUP sequence=100]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.selectablesubmodule.modulegroup, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client\simplestore
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore in development mode, trying to clean-up store.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=99} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.monitor.client' succesful.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=100} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=101} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=102} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=103} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=104} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=105} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=106} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=107} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=108} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=109} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=110} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=111} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=112} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=113} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=114} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=115} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=116} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=117} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=118} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=119} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=120} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=121} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/HandlerContainer/handlers/*], service.id=122} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=123} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=2147483647, service.id=124} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=125} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=126} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=127} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=128} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.eclipse.ui.IWorkbench}={service.id=129} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=130} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=131} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=132} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=133} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=134} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=135} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=136} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=137} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=138} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=139} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/*], service.id=140} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=141} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=142} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=143} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=144} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=145} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Contribution/object/*], service.id=146} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/GenericTile/horizontal/*], service.id=147} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/containerData/*], service.id=148} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=149} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=150} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=151} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=152} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=153} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=154} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=155} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=156} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=157} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=158} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=159} ServiceEvent REGISTERED
!SESSION 2013-02-22 23:44:49.559 -----------------------------------------------
Command-line arguments:  -application org.eclipse.riena.example.client.exampleapp -data C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\kepler/../runtime-New_configuration -dev file:C:/Users/TalayE1/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/dev.properties -debug C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\kepler\.metadata\.plugins\org.eclipse.pde.core\SWT ExampleApplication/.options -os win32 -ws win32 -arch x86 -clean -console -consolelog
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-02-22 23:44:52.692
!STACK 0
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) started without retry
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) started without retry
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) ended (nothing to send)
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) ended (nothing to send)
Fri Feb 22 23:44:52 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@fe0ce9 Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-22 23:44:56.693
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@f6398 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@dbbe8b, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 200, y: 240, width: 1024, height: 768)
!STACK 0
!ENTRY org.eclipse.riena.core 4 0 2013-02-22 23:44:56.693
!STACK 0
Fri Feb 22 23:44:56 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager exception handler class org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox#handleException() throws an exception
!STACK 0
Fri Feb 22 23:44:56 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@f6398 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@dbbe8b, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 200, y: 240, width: 1024, height: 768)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown
Re: Eclipse package for Riena [message #1014357 is a reply to message #1013156] Mon, 25 February 2013 11:49 Go to previous messageGo to next message
Hi Max,
I noticed one thing while setting the Riena target platform. These components appear twice in the list (your step 2):
* Riena Core Target Components
* Riena Target Components
Though they have the same names, they are different. Make sure, you select only the ones that include "e4" in their identifier (e.g. org.eclipse.riena.build.feature.core.sdk.e4.feature.group). You can check the identifier usind the "Properties..." button below the list and going to "General Information". See the screen shot.
You are launching the launch configuration "SWT ExampleApplication". Note that there is also a launch configuration "SWT ExampleApplication E4".
In the launch configuration dialog, check "Include optional dependencies when computing required plug-ins". It should work then.
Please reply, if you have more errors or questions.
Jordan
  • Attachment: shot.png
    (Size: 158.23KB, Downloaded 440 times)
Re: Eclipse package for Riena [message #1014487 is a reply to message #1014357] Mon, 25 February 2013 17:46 Go to previous messageGo to next message
Hello Jordan,
many thanks for the hints!
I started with completely new eclipse installation.
1. Unpack eclipse-SDK-4.3M5a-win32.zip
2. Create a target platform rienaE4 with the right E4 plugins (Screen shot)
3. Create a source project from plugin org.eclipse.riena.example.client
4. Add required plugins for launch configuration SWT ExampleApplication E4.launch
--> The example project itself is now error free.
==> But there are still some problems by starting the example project. Sad
Thx!
Max
Mon Feb 25 23:27:54 CET 2013 INFO [Start Level Event Dispatcher] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=78} ServiceEvent REGISTERED
Mon Feb 25 23:27:54 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274824 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Start Level Event Dispatcher] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=79} ServiceEvent REGISTERED
Mon Feb 25 23:27:54 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.Activator$StartupBundleListener Riena is running in stage '<unknown>'.
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274777 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274824 ms) in thread [Start Level Event Dispatcher]:
		LogLevel(INFO), Message(found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.RemoteServiceFactoryHessian@89cc5e)
Mon Feb 25 23:27:54 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274824 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.core.util.ContainerModel DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 DEBUG [Worker-0] org.eclipse.riena.core.cache.GenericObjectCache DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
		LogLevel(WARNING), Message(riena.core is not started. This may probably not work.)
Mon Feb 25 23:27:54 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.riena.security.ui' is already ACTIVE.
Mon Feb 25 23:27:54 CET 2013 WARNING [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup required bundle: 'org.eclipse.equinox.log' not found.
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations Platform Instance Location: file:/C:/Users/***/Desktop/Software/EclipseWorkspace/runtime-org.eclipse.riena.navigation.ui.e4.product/
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations Found directory at C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\org.eclipse.riena.monitor.client is not a directory.
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations Created instance area directory at C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\org.eclipse.riena.monitor.client
Mon Feb 25 23:27:55 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore at C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\org.eclipse.riena.monitor.client\simplestore
Mon Feb 25 23:27:55 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore in development mode, trying to clean-up store.
Mon Feb 25 23:27:55 CET 2013 INFO [Start Level Event Dispatcher] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=80} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.monitor.client' succesful.
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent STARTED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent STARTLEVEL CHANGED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[comp,component,dis,disAll,disable,disableAll,en,enAll,enable,enableAll,list,ls], osgi.command.scope=equinox, service.id=81} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[ns,pt], osgi.command.scope=equinox, service.id=82} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[activeApps,apps,lockApp,schedApp,startApp,stopApp,unlockApp,unschedApp], osgi.command.scope=equinox, service.id=83} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[controlstats], osgi.command.scope=equinox, service.id=84} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[logLevel], osgi.command.scope=equinox, service.id=85} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.command.Converter}={service.id=86} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.EquinoxCommandProvider}={service.ranking=2147483647, osgi.command.function=[exit,shutdown,sta,start,sto,stop,i,install,up,up,up,update,update,update,un,uninstall,s,status,se,services,p,p,packages,packages,bundles,b,bundle,gc,init,close,r,refresh,exec,fork,h,headers,pr,props,setp,setprop,ss,t,threads,sl,setfwsl,setbsl,setibsl,requiredBundles,classSpaces,profilelog,getPackages,getprop,diag,enableBundle,disableBundle,disabledBundles], osgi.command.scope=equinox, service.id=87} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.HelpCommand}={service.ranking=2147483647, osgi.command.function=[help], osgi.command.scope=equinox, service.id=88} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.ManCommand}={osgi.command.function=[man], osgi.command.scope=equinox, service.id=89} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.DisconnectCommand}={osgi.command.function=[disconnect], osgi.command.scope=equinox, service.id=90} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.threadio.ThreadIO}={service.id=91} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.telnet.TelnetCommand}={osgi.command.function=[telnet], osgi.command.scope=equinox, service.id=93} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.command.CommandProcessor}={service.id=92} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.command.Converter}={service.id=94} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Builtin}={osgi.command.function=[format,getopt,new,set,tac,type], osgi.command.scope=gogo, service.id=95} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Procedural}={osgi.command.function=[each,if,not,throw,try,until,while], osgi.command.scope=gogo, service.id=96} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Posix}={osgi.command.function=[cat,echo,grep], osgi.command.scope=gogo, service.id=97} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Telnet}={osgi.command.function=[telnetd], osgi.command.scope=gogo, service.id=98} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Shell}={osgi.command.function=[gosh,sh,source], osgi.command.scope=gogo, service.id=99} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.ApplicationLauncher}={service.id=100} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=101} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=102} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=103} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache put = DummyPrincipal , java.security.Permissions@eb67e8 (
 (java.lang.RuntimePermission navi)
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache processQueue
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigation.subapplication, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigate.form, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.sharedViews, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.uiProcesses, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.playground, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.filters, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.logcollector, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache get = DummyPrincipal
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.mgkundennummer[level=MODULEGROUP sequence=1]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.mgkundennummer, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.exceptiontest.mg[level=MODULEGROUP sequence=1]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.exceptiontest.mg, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.subModule.contentFilter[level=SUBMODULE sequence=1]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.subModule.contentFilter, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.activatedeactivate.mg[level=MODULEGROUP sequence=2]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.activatedeactivate.mg, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module onePersonSubModule[level=SUBMODULE sequence=2]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=onePersonSubModule, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.selectablesubmodule.modulegroup[level=MODULEGROUP sequence=100]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.selectablesubmodule.modulegroup, instanceId=null]
Mon Feb 25 23:27:56 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=104} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=105} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=106} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=107} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=108} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=109} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=110} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=111} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=112} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=113} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=114} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=115} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=116} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=117} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=118} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=119} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=120} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=121} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=122} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=123} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=124} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=125} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=126} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=127} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=128} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=129} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=130} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=131} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=132} ServiceEvent REGISTERED
!SESSION 2013-02-25 23:27:54.028 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments:  -product org.eclipse.riena.e4.launcher.product
Command-line arguments:  -product org.eclipse.riena.e4.launcher.product -data C:\Users\***\Desktop\Software\EclipseWorkspace\kepler/../runtime-org.eclipse.riena.navigation.ui.e4.product -dev file:C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication E4/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-02-25 23:27:56.339
!STACK 0
java.lang.ExceptionInInitializerError
	at org.eclipse.riena.ui.swt.utils.UIControlsFactory.createInfoFlyout(UIControlsFactory.java:764)
	at org.eclipse.riena.e4.launcher.rendering.ApplicationView.createInfoFlyout(ApplicationView.java:169)
	at org.eclipse.riena.e4.launcher.rendering.RienaWBWRenderer.rienaCreateContents(RienaWBWRenderer.java:579)
	at org.eclipse.riena.e4.launcher.rendering.RienaWBWRenderer.createWidget(RienaWBWRenderer.java:452)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:893)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:627)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.RuntimeException: Could not load org.eclipse.riena.ui.swt.facades.SWTFacadeRCP
	at org.eclipse.riena.ui.swt.facades.FacadeFactory.newFacade(FacadeFactory.java:53)
	at org.eclipse.riena.ui.swt.facades.SWTFacade.<clinit>(SWTFacade.java:47)
	... 29 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.riena.ui.swt.facades.SWTFacadeRCP
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.riena.ui.swt.facades.FacadeFactory.newFacade(FacadeFactory.java:46)
	... 30 more
Mon Feb 25 23:27:56 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@141b736 Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
	... 29 more
	... 30 more
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=STOPPING, eclipse.application.type=main.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application.0, application.descriptor=org.eclipse.e4.ui.workbench.swt.E4Application, service.id=63} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=org.eclipse.equinox.app.stopped, eclipse.application.type=main.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application.0, application.descriptor=org.eclipse.e4.ui.workbench.swt.E4Application, service.id=63} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=, application.visible=false, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.equinox.app.error, application.launchable=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.equinox.app_1.3.100.v20120522-1841.jar, service.id=61} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=Internal Model Topic Generator, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.e4.ui.workbench.swt.GenTopic, application.launchable=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.0.v20130124-145547.jar, service.id=60} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=E4 Application, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application, application.launchable=true, eclipse.application.default=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.0.v20130124-145547.jar, service.id=59} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=org.eclipse.riena.example.client.application, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.riena.example.client.exampleapp, application.launchable=true, application.locked=false, application.location=initial@reference:file:../../../../org.eclipse.riena.example.client/, service.id=62} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=org.eclipse.equinox.app.stopped, eclipse.application.type=main.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application.0, application.descriptor=org.eclipse.e4.ui.workbench.swt.E4Application, service.id=63} ServiceEvent UNREGISTERING
!ENTRY org.eclipse.osgi 4 0 2013-02-25 23:27:56.355
!MESSAGE Application error
!STACK 1
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:729)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:700)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:694)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:679)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:982)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:941)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:79)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	... 29 more
	... 30 more
Mon Feb 25 23:27:56 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@508be Application error
	... 29 more
	... 30 more
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.ApplicationLauncher}={service.id=100} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=-2147483648, service.id=1} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=131} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=132} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=126} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=124} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=113} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=125} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=127} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=123} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=119} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=122} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=130} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=117} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=118} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=107} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=108} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=109} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=110} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=111} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=112} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=114} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=106} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=128} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=129} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=101} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=116} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=104} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=105} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=121} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=115} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=120} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STOPPED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.monitor.common.IReceiver}={service.url=ttp://localhost:8080/hessian/CollectibleReceiverWS, service.protocol=hessian, service.id=68} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.authentication.IAuthenticationService}={service.url=ttp://localhost:8080/hessian/AuthenticationService, service.protocol=hessian, service.id=74} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=79} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=103} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[controlstats], osgi.command.scope=equinox, service.id=84} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.osgi.framework.console.CommandProvider}={service.id=75} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.ui.testing.TestableObject}={component.name=org.eclipse.ui.testing.TestableObject, component.id=0, service.id=35} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.e4.core.contexts.IContextFunction}={service.context.key=org.eclipse.e4.core.services.statusreporter.StatusReporter, component.name=org.eclipse.e4.ui.workbench.swt.statusReporter, component.id=1, service.id=36} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.e4.core.contexts.IContextFunction}={service.context.key=org.eclipse.e4.ui.workbench.swt.modeling.EMenuService, component.name=org.eclipse.e4.ui.workbench.swt.menuService, component.id=2, service.id=37} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=80} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.session.ISessionHolder}={service.id=69} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.hooks.ICallHook}={service.id=70} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.ISubjectHolder}={service.id=71} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.authorization.IPermissionCache}={service.ranking=-100, service.id=72} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.authorization.ISentinelService}={service.ranking=-100, service.id=73} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=102} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=78} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration No configuration given!.
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.IRemoteServiceRegistry}={service.ranking=-100, service.id=65} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.hooks.ICallHook}={service.id=66} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.progressmonitor.IRemoteProgressMonitorRegistry}={service.id=67} ServiceEvent UNREGISTERING
An error has occurred. See the log file
C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\.metadata\.log.
Re: Eclipse package for Riena [message #1015327 is a reply to message #1014487] Thu, 28 February 2013 04:02 Go to previous messageGo to next message
the Eclipse Riena example still doesn't works for me.
I have created a screencast of my installing procedure.
materialordner.de/UKy6Y7oPKfj0tUDZc6O1ywFCODvYJ0St.html
What I am doing wrong?
Thanks in advance!
Kind regards,
Max Reeb
Re: Eclipse package for Riena [message #1015339 is a reply to message #1015327] Thu, 28 February 2013 04:35 Go to previous message
Hi Max,
in the step where you "add required plug-ins" to the launch configuration, also check the "include optional dependencies" checkbox below the bundles list.
5:28 in your screencast.
Jordan
Previous Topic:checkbox -> togglebutton
Next Topic:Dynamically load an riena plugin after login
Current Time: Sat Jul 26 19:18:55 EDT 2025
Powered by FUDForum. Page generated in 0.05658 seconds
