Home » Modeling » OCL » CompleteOCL standalone validation of uml model
CompleteOCL standalone validation of uml model [message #1011884] |
Wed, 20 February 2013 07:24  |
Hi all,
I´m trying to do a OCL-validation of a umlmodel in a standalone application. I tried to do this with the CompleteOCLEObjectValidator and all works fine for validating constraints with functions included in oclstdlib or with attributes of my model, such as "self.name = 'SysMLmodel'". But if i try to validate a constraint using a function that is not in the oclstdlib,e.g "self.allOwnedElements()" the result is always "OCL validation result of 'PackImport' is invalid". I debugged this an thats because of no Implementation of "allOwnedElements" is found. I´m using indigo..
Here is my code:
public class TestValidator extends CompleteOCLEObjectValidator{
public TestValidator(EPackage ePackage, URI oclURI) {
super(ePackage, oclURI);
// TODO Auto-generated constructor stub
public static void main(String[] args){
CompleteOCLStandaloneSetup.doSetup();
OCLstdlibStandaloneSetup.doSetup();
EssentialOCLStandaloneSetup.doSetup();
OCLstdlib.install();
UMLPackage uml = UMLPackage.eINSTANCE;
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(SysmlPackage.eNS_URI, SysmlPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(BlocksPackage.eNS_URI, BlocksPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(resourceSet.getResourceFactoryRegistry().DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
URI uri = URI.createFileURI("D:/.../model.uml");
EPackage.Registry.INSTANCE.put("D:/.../model.uml",UMLPackage.eINSTANCE);
URI ocluri = URI.createFileURI("D:/.../test.ocl");
Resource resource = resourceSet.createResource(uri);
try {
resource.load(null);
System.out.println("Model: load complete");
} catch (IOException e) {
e.printStackTrace();
Model m = (Model) EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.MODEL);
org.eclipse.ocl.uml.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.uml.UML2Pivot.initialize(null);
String oclDelegateURI2 = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI2,
new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI2,
new OCLSettingDelegateFactory.Global());
EValidator.ValidationDelegate.Registry.INSTANCE.put(oclDelegateURI2,
new OCLValidationDelegateFactory.Global());
CompleteOCLEObjectValidator val = new TestValidator(UMLPackage.eINSTANCE,ocluri);
EValidator.Registry.INSTANCE.put(UMLPackage.eINSTANCE,val);
EValidator.Registry.INSTANCE.put(SysmlPackage.eINSTANCE,val);
Diagnostic diag = Diagnostician.INSTANCE.validate(m);
System.out.println(diag.getMessage());
for(Diagnostic object : diag.getChildren()){
System.err.println(object.getMessage());
How do I get the functions, like allOwnedElements(), registered in my Application?
best regards,
Basti
Re: CompleteOCL standalone validation of uml model [message #1011937 is a reply to message #1011884] |
Wed, 20 February 2013 09:38   |
HI
Support for UML with the new-pivot based OCL that goes hand-in-hand with
the Xtext tooling is steadily improving.
The additional MDT/UML2 utility functions were not available in the Juno
release. If you use the Kepler M5 download you should have more joy; I
hope. Otherwise I've got some debugging to do.
If you're prepared to install the Kepler M5 versions of EMF, UML2,
Xtext, OCL etc you can probably continue to use Indigo.
Ed Willink
On 20/02/2013 14:23, Ba sti wrote:
> Hi all,
> Here is my code:
> Quote:
>> try {
>> Model m = (Model)
> Application?
> best regards,
> Basti
Current Time: Sat Jul 26 23:26:20 EDT 2025
Powered by FUDForum. Page generated in 2.24010 seconds
