Home » Modeling » TMF (Xtext) » errors while exporting to Repository
errors while exporting to Repository [message #782343] Mon, 23 January 2012 10:16 Go to next message
I have a DSL working ok when I test with
I want to incorporate int main eclipse.
I go into "Deployable plug-ins and fragments", select all plug-ins (rpc, rpc.tests & rpc.ui) and then "Install into host,
Repository."
Operation fails:
Problem during export
Errors occurred during the export operation. The ant tasks generated log files
which can e found at /srv/devel/install/logs.zip
I do attach the complete zip file, but errors are all the same:
1. ERROR in /srv/devel/parser.WS/com.softin.rpc/src/com/softin/rpc/MyIntegerConverterImplementation.java (at line 10)
public Integer toValue(String string, INode node)
throws ValueConverterException {
The method toValue(String, INode) of type MyIntegerConverterImplementation must override a superclass method
Which is strange.
MyIntegerConverterImplementation.java is trivial:
package com.softin.rpc;
import org.eclipse.xtext.conversion.IValueConverter;
import org.eclipse.xtext.conversion.ValueConverterException;
import org.eclipse.xtext.nodemodel.INode;
public class MyIntegerConverterImplementation implements IValueConverter<Integer> {
return Integer.decode(string);
public String toString(Integer value) throws ValueConverterException {
return value.toString();
I also tried commenting out the offending "@Override" and the export seems to succeed, but the same errors pops up again when the editor is actually instantiated.
What am I doing wrong?
TiA
Mauro
  • Attachment: logs.zip
    (Size: 1.44KB, Downloaded 374 times)
Re: errors while exporting to Repository [message #782368 is a reply to message #782343] Mon, 23 January 2012 10:57 Go to previous messageGo to next message
Hi Mauro,
it looks like your export uses another compatibility level for the Java
compiler, e.g. 1.5 vs 1.6. Unfortunately I don't know why this could happen.
Sebastian
Am 23.01.12 16:16, schrieb Mauro Condarelli:
> I go into "Deployable plug-ins and fragments", select all plug-ins (rpc, rpc.tests& rpc.ui) and then "Install into host,
> Repository."
> Operation fails:
> Which is strange.
> @Override
> @Override
> TiA
> Mauro
Re: errors while exporting to Repository [message #782402 is a reply to message #782368] Mon, 23 January 2012 11:45 Go to previous messageGo to next message
Well if you happen to modify the settings in your project and don't keep
them in sync with your Required-Execution-Env in your MANIFEST.MF this
happens because the PDE-Build has no idea about the project-settings it
only knows about the MANIFEST information.
To resync them you need open your MANIFEST.MF-Overview and hit "update
the classpath settings" (maybe you want to set a higher before).
Tom
Am 23.01.12 16:57, schrieb Sebastian Zarnekow:
> Hi Mauro,
> happen.
> Regards,
> Sebastian
Re: errors while exporting to Repository [message #782518 is a reply to message #782402] Mon, 23 January 2012 16:47 Go to previous messageGo to next message
Thanks for the answers.
Unfortunately I still need some help
(please see the LAST error listing).
It may have happened because I created the workspace (containing a single xtext project rpc, rpc.tests and rpc.ui) on one machine (Win7-SunJava_1.7) and then I moved it to another one (ubuntu_11.04/OpenJDK_1.6) and proceeded to continue development there.
Unfortunately this doesn't appear to be true.
I proceeded to correct the error (I now have "JavaSE-1.6" consistently everywhere, but I had to manually edit several files), to regenerate the project (cleaning it and then re-running GenerateSIDL.mwe2).
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri '/srv/devel/parser.WS'
68 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.xbase.XbasePackage'
368 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
370 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
382 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
382 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
818 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning /srv/devel/parser.WS/com.softin.rpc/../com.softin.rpc/src-gen
821 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning /srv/devel/parser.WS/com.softin.rpc/../com.softin.rpc.ui/src-gen
957 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for com.softin.rpc.SIDL with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, SerializerFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, GeneratorFragment, FormatterFragment, LabelProviderFragment, OutlineTreeProviderFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment, Junit4Fragment, RefactorElementNameFragment, TypesGeneratorFragment, XbaseGeneratorFragment, CodetemplatesGeneratorFragment, CompareFragment
2635 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.softin.com/rpc/SIDL' from 'platform:/resource/com.softin.rpc/src-gen/com/softin/rpc/SIDL.genmodel'
5056 [main] INFO or.validation.JavaValidatorFragment - generating Java-based EValidator API
6408 [main] INFO text.generator.junit.Junit4Fragment - generating Junit4 Test support classes
6419 [main] INFO text.generator.junit.Junit4Fragment - generating Compare Framework infrastructure
6538 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
I see nothing wrong here.
This leads to a working executable if I run "Launch Runtime Eclipse" (as before!).
When I run the "Export Wizard" (checked rpc & rpc.ui; Install into host. Repository.; pointer to empty dir) I only get the expected "You will need to restart Eclipse..." message (I select "Restart Now").
Everything seems ok, but if I open an example file for my SDL I get: "could not open the editor: An unexpected exception was thrown.";
details are:
at org.eclipse.xtext.ui.editor.folding.DefaultFoldingStructureProvider.handleProjectionEnabled(DefaultFoldingStructureProvider.java:100)
at org.eclipse.xtext.ui.editor.folding.DefaultFoldingStructureProvider$ProjectionChangeListener.projectionEnabled(DefaultFoldingStructureProvider.java:186)
at org.eclipse.jface.text.source.projection.ProjectionViewer.fireProjectionEnabled(ProjectionViewer.java:489)
at org.eclipse.jface.text.source.projection.ProjectionViewer.enableProjection(ProjectionViewer.java:537)
at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1441)
at org.eclipse.xtext.ui.editor.XtextEditor.installFoldingSupport(XtextEditor.java:471)
at org.eclipse.xtext.ui.editor.XtextEditor.createPartControl(XtextEditor.java:453)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2756)
at org.eclipse.ui.ide.IDE.openEditorOnFileStore(IDE.java:1155)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:107)
at org.eclipse.ui.internal.ide.actions.OpenLocalFileAction.run(OpenLocalFileAction.java:76)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
And the following on the command line where I started eclipse:
1 [main] ERROR org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback - Was configured with another client or not configured at all.
java.lang.IllegalStateException: Was configured with another client or not configured at all.
at org.eclipse.xtext.ui.editor.DirtyStateEditorSupport.removeDirtyStateSupport(DirtyStateEditorSupport.java:336)
at org.eclipse.xtext.ui.editor.AbstractDirtyStateAwareEditorCallback.beforeDispose(AbstractDirtyStateAwareEditorCallback.java:38)
at org.eclipse.xtext.ui.editor.CompoundXtextEditorCallback.beforeDispose(CompoundXtextEditorCallback.java:69)
at org.eclipse.xtext.ui.editor.XtextEditor.dispose(XtextEditor.java:501)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:705)
Which seemds interesting, but I'm really out of my depth here :(
Please help!
Mauro
> Tom
>> Hi Mauro,
>> happen.
>> Regards,
>> Sebastian
Re: errors while exporting to Repository [message #782537 is a reply to message #782518] Mon, 23 January 2012 17:47 Go to previous messageGo to next message
UPDATE:
I created another xtext project on this machine (from scratch, in a brand new workspace) and I immediately get the following three errors:
Description Resource Path Location Type
Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. com.softin.rpc Build path JRE System Library Problem
Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. com.softin.rpc.tests Build path JRE System Library Problem
Build path specifies execution environment J2SE-1.5. There are no JREs installed in the workspace that are strictly compatible with this environment. com.softin.rpc.ui Build path JRE System Library Problem
Anyways, if I copy over just the grammar (.xtext) and code generation files (.xtend) everything seems to work fine and I can create a new .sidl file and edit it (after eclipse restart, of course).
But if I include also the three converter files (MyIntegerConverterImplementation.java, MyStringConverterImplementation.java and MyValueConverterService.java) and re-run the Export Wizard with the same parameters it complains (Errors occurred...) with exactly the same errors.
This IMHO means the fact I created the old project in another machine is not relevant.
If it matters: I'm using the "Complete Eclipse Indigo Distribution" from xtext.itemis.com (http://download.itemis.com/distros/eclipse-SDK-3.7.1-Xtext-2.2.1-linux-gtk.tar.gz), augmented with CDT-SDK.
I can send over the complete project if it is useful.
Thanks again
Mauro
Re: errors while exporting to Repository [message #785229 is a reply to message #782537] Sat, 28 January 2012 12:42 Go to previous messageGo to next message
I still need to solve this.
Can someone help, please?
Mauro
> UPDATE:
> Thanks again
> Mauro
Re: errors while exporting to Repository [message #785260 is a reply to message #785229] Sat, 28 January 2012 13:51 Go to previous messageGo to next message
isnt that a waring resulting from this entry in your manifest.mf s
Bundle-RequiredExecutionEnvironment: J2SE-1.5
[Updated on: Sat, 28 January 2012 13:55] by Moderator
Re: errors while exporting to Repository [message #785391 is a reply to message #785260] Sat, 28 January 2012 18:41 Go to previous messageGo to next message
Il 28/01/2012 19:51, Christian Dietrich ha scritto:
> isnt that a waring resulting from this enty in your manifest.mf s
In some regards You are right, but:
1) I didn't write that value, the xtext New Project wizard did, so I'm
forced to think something is wrong there.
2) (worse!) even if I manually correct this and manually change all
references to "Bundle-RequiredExecutionEnvironment: JavaSE-1.6" (which
*is* present in my installation) I get runtime errors stating: "toValue
should override an existing function..."
In the weekend I will retry to start from scratch in a new installation
writing down everything I do.
Hopefully this will scare away the bug ;)
Otherwise I will post again.
Rregards
Mauro
Re: errors while exporting to Repository [message #785715 is a reply to message #785391] Sun, 29 January 2012 05:51 Go to previous messageGo to next message
when changing to Bundle-RequiredExecutionEnvironment: JavaSE-1.6 (and Java Compilance Level in Eclipse set to 1.6) it works for me using the itemis distro.
~Christian
Re: errors while exporting to Repository [message #1011615 is a reply to message #785715] Tue, 19 February 2013 17:40 Go to previous messageGo to next message
I keep getting the same kind of message as Mauro when trying to open my editor after having installed the plugin:
org.eclipse.xtext.parser.ParseException: java.lang.Error: Unresolved compilation problem:
	The method toValue(String, INode) of type DOUBLEValueConverter must override a superclass method
DOUBLEValueConverter is my value converter class for decimal literals:
package it.unibo.xtext.myvalueconv;
import org.eclipse.xtext.conversion.impl.AbstractLexerBasedConverter;
public class DOUBLEValueConverter extends AbstractLexerBasedConverter<Double> {
	public DOUBLEValueConverter() {
		super();
	public Double toValue(String string, INode node)
		if (string == null)
			return null;
		try {
			return Double.parseDouble(string);
		}catch (NumberFormatException e){
			throw new ValueConverterException(e.getMessage(), node, e);
How come the message says that I should override the method that I overrode? Is it because of generics?
The bundles were configured for J2SE 1.5, but switching to 1.6 and rebuilding everything didn't do the trick.
Any suggestions?
EDIT: I keep getting the same error even removing the @Override annotation from the "toValue" method...
[Updated on: Wed, 20 February 2013 04:32] by Moderator
Re: errors while exporting to Repository [message #1011813 is a reply to message #1011615] Wed, 20 February 2013 04:56 Go to previous messageGo to next message
I think it's because toValue comes from the interface IValueConverter
thus it is an abstract method and Java 5 does not accept @Override
annotation for abstract methods...
you should make sure to set the compiler settings in your workspace to
use J2SE 1.5 so that you are notified about these errors in your
developer workspace so that you can fix them and export the plugins
again and reinstall them...
hope this helps
Lorenzo
> compilation problem: The method toValue(String, INode) of type
> super();
> @Override
> if (string == null)
> return null;
> try {
> Any suggestions?
HOME: http://www.lorenzobettini.it
Re: errors while exporting to Repository [message #1011876 is a reply to message #1011813] Wed, 20 February 2013 07:08 Go to previous messageGo to next message
Lorenzo Bettini wrote on Wed, 20 February 2013 10:56
hope this helps
Lorenzo
Thanks for your suggestion, but I tried removing the @Override annotation too (which should remove the problem altogether in Java 5) and it didn't change anything...
Re: errors while exporting to Repository [message #1012064 is a reply to message #1011876] Wed, 20 February 2013 15:18 Go to previous messageGo to next message
>> hope this helps
>> Lorenzo
mh... you mean you removed the @Override from
super();
and you still get this error
that makes no sense :)
it means it's still using the old code
Re: errors while exporting to Repository [message #1014266 is a reply to message #1012064] Mon, 25 February 2013 08:23 Go to previous messageGo to next message
I got it working using the plugin export wizard instead of the update site I created.
Will try again on a clean machine and report here.
Re: errors while exporting to Repository [message #1403424 is a reply to message #1012064] Wed, 23 July 2014 11:25 Go to previous messageGo to next message
First of all, thank you very much.
Thanks to your hints, I fixed the generation of the update site by fixing the warning which says that the project is configured to use J2SE-1.5 library. This is made by doing the following:
  1. In the MANIFEST.MF, I changed the execution environment to JavaSE-1.6 instead
  2. Because that didn't fix the warning, I also checked the project's Build Path's libraries and found out that it was still referring to J2SE-1.5 so I changed it as well to the same library
  3. I still found some warnings on the ui project, the warning was that the xtext-gen source folder was not included in the MANIFST-INF as well. SO I added it too to the list.
Note: I'm using xtext version 2.4.1 on Eclipse 3.4.1 (due to some constrains)
Unfortunately, I ran into another type of error after installing the plugin to Eclipse and trying to create a new (my) model file. It gives the following error:
Could not open the editor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
Re: errors while exporting to Repository [message #1403428 is a reply to message #1403424] Wed, 23 July 2014 11:38 Go to previous messageGo to next message
Well, it works fine now.
Thanks to the answer of this question here: stackoverflow.com/questions/6436403/eclipse-editor-wont-open
I deleted all files in the new plugin's folder (under the .metadata) and opened eclipse again using the -clean parameter.
It worked. Smile
Re: errors while exporting to Repository [message #1403482 is a reply to message #1403428] Thu, 24 July 2014 02:12 Go to previous message
sorry for beeing so late:
The error-info may point to the JAVA preferences "Installed JRE" where nothing is entered.
Just went through that excercise with the new LUNA-DSL download.
Previous Topic:Reference scope
Next Topic:Validate with parameter?
Current Time: Sun Jul 27 14:27:53 EDT 2025
Powered by FUDForum. Page generated in 0.06686 seconds
