Home » Modeling » EMF » [CDO] 4.2 and CDOElementProxy
[CDO] 4.2 and CDOElementProxy [message #968352] Fri, 02 November 2012 07:53 Go to next message
When I process a Resource, I sometimes convert the content, with a little piece of code like this:
public static class CollectionForObjects<T> {
		public List<T> collectionForObjects(List<EObject> objects) {
			List<T> typedList = Lists.transform(objects,
					new Function<EObject, T>() {
						@SuppressWarnings("unchecked")
						public T apply(EObject from) {
							return (T) from;
			return typedList;
This used to work fine in CDO 4.0, with 4.2 however I get this class cast exception below.
So a CDOElementProxy, can't be cast to an EObject, what could I do with it to get a collection of
target objects? What has changed? I mean, is there a bug describing this? +
Thanks/
java.lang.ClassCastException: org.eclipse.emf.cdo.internal.common.revision.CDOElementProxyImpl cannot be cast to org.eclipse.emf.ecore.EObject
at com.netxforge.netxstudio.common.model.ModelUtils$CollectionForObjects$1.apply(ModelUtils.java:1)
at com.google.common.collect.Lists$TransformingSequentialList$1.next(Lists.java:381)
at com.netxforge.netxstudio.common.model.ModelUtils.roleForUserWithName(ModelUtils.java:1959)
at com.netxforge.netxstudio.data.DataService.getCurrentRole(DataService.java:71)
at com.netxforge.netxstudio.ui.ApplicationWorkbenchAdvisor.resetWorkbenchIfRoleChanged(ApplicationWorkbenchAdvisor.java:69)
Re: [CDO] 4.2 and CDOElementProxy [message #968495 is a reply to message #968352] Fri, 02 November 2012 09:53 Go to previous messageGo to next message
Am 02.11.2012 12:53, schrieb Christophe Bouhier:
> return (T) from;
> return typedList;
> This used to work fine in CDO 4.0, with 4.2 however I get this class cast exception below. So a CDOElementProxy, can't
> be cast to an EObject, what could I do with it to get a collection of target objects? What has changed? I mean, is
Are you using partial collection loading explicietely, i.e., session.options().setCollectionLoadingPolicy(...) ?
Cheers
/Eike
http://www.esc-net.de
> Thanks/
> at
Re: [CDO] 4.2 and CDOElementProxy [message #969715 is a reply to message #968495] Sat, 03 November 2012 09:30 Go to previous messageGo to next message
Hi Eike,
No I am not explicitly setting a collection loading policy.
rgds Christophe
Re: [CDO] 4.2 and CDOElementProxy [message #969720 is a reply to message #969715] Sat, 03 November 2012 09:38 Go to previous messageGo to next message
Oh.... bummer. My initial search didn't reveal this line of code:
cdoSession.options().setCollectionLoadingPolicy(
CDOUtil.createCollectionLoadingPolicy(0, 300));
So, yes I do set a loading policy.
/ Christophe
Re: [CDO] 4.2 and CDOElementProxy [message #973767 is a reply to message #969720] Tue, 06 November 2012 10:54 Go to previous messageGo to next message
Eike, if you are there can you please explain how I should deal with partial collection loading and my problem here?
thank you,
Christophe
Re: [CDO] 4.2 and CDOElementProxy [message #973804 is a reply to message #973767] Tue, 06 November 2012 11:30 Go to previous messageGo to next message
Am 06.11.2012 16:54, schrieb Christophe Bouhier:
> thank you, Christophe
Oh, I thought you wanted to try without it first, now that you know that you were using it.
Cheers
/Eike
Re: [CDO] 4.2 and CDOElementProxy [message #974659 is a reply to message #973804] Wed, 07 November 2012 03:24 Go to previous messageGo to next message
ok, well I'd still like to keep it on. just wondering why it was working in 4.0 and not 4.2?
Something must have changed?
rgds Christophe
Re: [CDO] 4.2 and CDOElementProxy [message #974684 is a reply to message #974659] Wed, 07 November 2012 03:43 Go to previous messageGo to next message
Am 07.11.2012 09:24, schrieb Christophe Bouhier:
> ok, well I'd still like to keep it on. just wondering why it was working in 4.0 and not 4.2? Something must have changed?
It could be related to the optimizations we've applied in the meantime. Now a revision maintains a flag that tells
whether all lists are actually unchunked. That reduces the need to always iterate over all elements of all lists in
methods that need proxies resolved. It's possible that i overlooked some places that should impact the flag. Please
submit a bugzilla so that I can investigate.
Cheers
/Eike
Re: [CDO] 4.2 and CDOElementProxy [message #981304 is a reply to message #968352] Mon, 12 November 2012 05:12 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394076
Re: [CDO] 4.2 and CDOElementProxy [message #1011477 is a reply to message #974684] Tue, 19 February 2013 11:01 Go to previous messageGo to next message
I'm wondering if this means that the downcasting of CDO Proxy objects to EObject is broken, period?
I have recently experienced the exception that Christophe posted. Another manifestation of the issue might be in the following. If there is some proxying going on I just can't seem to make a copy of a CDOObject period now. The "from" object in the ECoreUtil.copy being performed below is a CDOObject. As I said I have had the result below and in another similar situation (using EcoreUtil.copy) I have had the exception Christophe posted rear its ugly head.
at org.eclipse.emf.ecore.util.DelegatingEcoreEList.resolveProxy(DelegatingEcoreEList.java:312)
at org.eclipse.emf.ecore.util.DelegatingEcoreEList.resolve(DelegatingEcoreEList.java:273)
at org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEList.java:230)
at org.eclipse.emf.common.util.AbstractEList$EIterator.doNext(AbstractEList.java:703)
at org.eclipse.emf.common.util.AbstractEList$EIterator.next(AbstractEList.java:690)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReference(EcoreUtil.java:717)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReferences(EcoreUtil.java:641)
at org.eclipse.emf.ecore.util.EcoreUtil.copy(EcoreUtil.java:356)
at com.src.ewir.nighthawk.cdointerface.handlers.LoadFromDatabaseHandler.openEditor(LoadFromDatabaseHandler.java:279)
at com.src.ewir.nighthawk.cdointerface.handlers.LoadFromDatabaseHandler.execute(LoadFromDatabaseHandler.java:139)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at com.src.ewir.nighthawk.platform.ui.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: [CDO] 4.2 and CDOElementProxy [message #1014606 is a reply to message #1011477] Tue, 26 February 2013 01:25 Go to previous messageGo to next message
Hi Andrew,
Sorry for the late reply. Busy time here.
I wonder if you or Christophe can reproduce this in our test bed, especially with our test models and without 3rd party
stuff such as Guava? A quick scan of our open bugzillas didn't bring up a related one. Please submit a new bugzilla and
replicate the infos given here. I'm currently fixing the CDOMergingConflictResolver for a customer, so please don't
expect that I work on this immediately.
Cheers
/Eike
Am 19.02.2013 17:01, schrieb Andrew Whelan:
> I'm wondering if this means that the downcasting of CDO Proxy objects to EObject is broken, period? I have recently
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Re: [CDO] 4.2 and CDOElementProxy [message #1014670 is a reply to message #1014606] Tue, 26 February 2013 03:52 Go to previous messageGo to next message
Removing this line of code solved the issue for me:
What is wrong with this bug BTW? Why create another one?
Cheers Christophe
Re: [CDO] 4.2 and CDOElementProxy [message #1014695 is a reply to message #1014670] Tue, 26 February 2013 04:42 Go to previous messageGo to next message
Am 26.02.2013 09:52, schrieb Christophe Bouhier:
Oh boy! Let me cite your second post in this thread: "No I am not explicitly setting a collection loading policy."
Probably nothing. I just scanned for "proxy" :P
Cheers
/Eike
Re: [CDO] 4.2 and CDOElementProxy [message #1014720 is a reply to message #1014695] Tue, 26 February 2013 05:44 Go to previous messageGo to next message
I think I corrected that statement in the thread :P
/ Christophe
Ok, working on a test case without Guava.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] 4.2 and CDOElementProxy [message #1014723 is a reply to message #1014720] Tue, 26 February 2013 05:48 Go to previous message
Am 26.02.2013 11:44, schrieb Christophe Bouhier:
Okay, okay. I apologize ;-)
Cheers
/Eike
> / Christophe
>> Cheers
>> /Eike
Previous Topic:[CDO] Can only retrieve current version
Next Topic:Exception thrown with EMF 2.9 and RAP 2.0
Current Time: Sat Jul 26 11:58:19 EDT 2025
Powered by FUDForum. Page generated in 0.07934 seconds
