Home » Modeling » EMF » [CDO] How to register a Resource Opener
icon5.gif  [CDO] How to register a Resource Opener [message #1011422] Tue, 19 February 2013 09:52 Go to next message
I was debugging the plugin org.eclipse.emf.cdo.ui in order to know how CDO Sessions View works, and I realized than when you double click on a resource, it tries to get the corresponding Resource Opener associated to the extension of the resource. If no one is obtained, the CDO Editor is opened.
There are two methods that allows to register and unregister Resource Openers, but there are not any example about how to use them.
I try to use this methods outside this plugin, and there are a discouraged access because this class (CDOSessionsView) is contained into an internal package.
Which is the best way to register a Resource Opener? There exists any example?
Thanks a lot,
Marc
Re: [CDO] How to register a Resource Opener [message #1012619 is a reply to message #1011422] Thu, 21 February 2013 17:31 Go to previous messageGo to next message
Well, I understand that this is an implementation of a sample CDO View, so our customized Views should implement something similar of this register, so there is no problem.
Marc
Re: [CDO] How to register a Resource Opener [message #1014611 is a reply to message #1011422] Tue, 26 February 2013 01:39 Go to previous message
Am 19.02.2013 15:52, schrieb Marc Gil:
> to use them.
IIRC. this mechansim has been made internally for the Dawn editors. You can use it for your own purpose but we make no
guarantee that the mechanism will even survive.
We've reworked the "open editor" story completely in 4.2 and there's more to come when Ed has committed our work on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=384036 , which he says will be before EclipseCon.
Cheers
/Eike
http://www.esc-net.de
Previous Topic:[CDO] disable revisions when using branches
Next Topic:[CDO] Set up security manager
Current Time: Sat Jul 26 21:17:28 EDT 2025
Powered by FUDForum. Page generated in 0.04352 seconds
