Home » Modeling » EMF » Xcore and FeatureMaps
Xcore and FeatureMaps [message #1011295] Tue, 19 February 2013 04:01 Go to next message
I am trying to get FeatureMaps to work with Xcore. Is this possible and if yes, how can this be done?
Jan
Re: Xcore and FeatureMaps [message #1011311 is a reply to message #1011295] Tue, 19 February 2013 04:35 Go to previous messageGo to next message
Jan,
I've not tried that. You might try exporting a *.genmodel for a *.ecore
model with feature maps to *.xcore and seeing how that looks. A feature
map is just a multi-valued EAttribute with FeatureMap.Entry data type so
it should just work if you use an attribute with type EFeatureMapEntry...
On 19/02/2013 10:01 AM, Jan Rosczak wrote:
> Thanks
> Jan
Re: Xcore and FeatureMaps [message #1011375 is a reply to message #1011311] Tue, 19 February 2013 07:46 Go to previous messageGo to next message
Hi Ed,
I (hopefully) did, as you suggested. But when I select my genmodel and click "Export model..." I get a NullPointerException. I am using the last EMF Milestone, Xcore version 1.1.0.
Jan
	at org.eclipse.emf.ecore.xcore.resource.XcoreResource$FragmentCache.<init>(XcoreResource.java:66)
	at org.eclipse.emf.ecore.xcore.resource.XcoreResource.getEObject(XcoreResource.java:157)
	at org.eclipse.emf.ecore.xcore.scoping.XcoreImportedNamespaceAwareScopeProvider$EClassifierScope$EcoreDataTypeAliasEObjectDescription.getElement(XcoreImportedNamespaceAwareScopeProvider.java:535)
	at org.eclipse.emf.ecore.xcore.scoping.XcoreImportedNamespaceAwareScopeProvider$EClassifierScope$EcoreDataTypeAliasEObjectDescription.getEObjectOrProxy(XcoreImportedNamespaceAwareScopeProvider.java:463)
	at org.eclipse.xtext.scoping.impl.AbstractScope$5.apply(AbstractScope.java:186)
	at org.eclipse.xtext.scoping.impl.AbstractScope$5.apply(AbstractScope.java:1)
	at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
	at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141)
	at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136)
	at com.google.common.collect.Iterators$5.hasNext(Iterators.java:539)
	at org.eclipse.xtext.scoping.impl.ImportScope.getAliasedElements(ImportScope.java:117)
	at org.eclipse.xtext.scoping.impl.ImportScope.getLocalElementsByEObject(ImportScope.java:97)
	at org.eclipse.xtext.scoping.impl.AbstractScope.getElements(AbstractScope.java:154)
	at org.eclipse.xtext.scoping.impl.FilteringScope.getElements(FilteringScope.java:41)
	at org.eclipse.xtext.scoping.impl.ScopeBasedSelectable.getExportedObjectsByObject(ScopeBasedSelectable.java:45)
	at org.eclipse.xtext.scoping.impl.ImportScope.getLocalElementsByEObject(ImportScope.java:96)
	at org.eclipse.xtext.scoping.impl.AbstractScope$3.get(AbstractScope.java:157)
	at org.eclipse.xtext.scoping.impl.AbstractScope$3.get(AbstractScope.java:1)
	at org.eclipse.xtext.scoping.impl.AbstractScope$ParentIterable.iterator(AbstractScope.java:59)
	at com.google.common.collect.Iterables$3.next(Iterables.java:505)
	at com.google.common.collect.Iterables$3.next(Iterables.java:498)
	at com.google.common.collect.Iterators$5.hasNext(Iterators.java:540)
	at com.google.common.collect.Iterators$7.computeNext(Iterators.java:643)
	at org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.getCrossReferenceNameFromScope(CrossReferenceSerializer.java:128)
	at org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.serializeCrossRef(CrossReferenceSerializer.java:120)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.getToken(SequenceFeeder.java:453)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:220)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:401)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:439)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:299)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:325)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:222)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:239)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:394)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:85)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:108)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:130)
	at org.eclipse.xtext.resource.XtextResource.doSave(XtextResource.java:316)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1441)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(ResourceImpl.java:1010)
	at org.eclipse.emf.ecore.xcore.exporter.XcoreExporter$3.run(XcoreExporter.java:394)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
  • Attachment: model.ecore
    (Size: 1.47KB, Downloaded 295 times)
Re: Xcore and FeatureMaps [message #1011378 is a reply to message #1011375] Tue, 19 February 2013 07:53 Go to previous messageGo to next message
Jan,
I tried that locally with the latest Xtext and the latest fixes in Xcore
needed for the latest Xtext and it produced this:
@Ecore(nsPrefix="mp", nsURI="http://model")
@GenModel(modelDirectory="/abc/src",
importerID="org.eclipse.emf.importer.ecore", complianceLevel="5.0")
package model
import org.eclipse.emf.ecore.EFeatureMapEntry
class Supplier
@ExtendedMetaData(kind="group")
unique EFeatureMapEntry [] orders
@ExtendedMetaData(group="#orders")
contains resolving transient volatile PurchaseOrder [] preferredOrders
contains resolving transient volatile PurchaseOrder [] standardOrders
class PurchaseOrder
On 19/02/2013 1:46 PM, Jan Rosczak wrote:
> Hi Ed,
> Thanks
> Jan
Re: Xcore and FeatureMaps [message #1011412 is a reply to message #1011378] Tue, 19 February 2013 09:33 Go to previous messageGo to next message
Hi Ed,
this does not work in milestone M5, as the type EFeatureMapEntry cannot be imported. But the following works:
package model
import org.eclipse.emf.ecore.util.FeatureMap$Entry
type EFeatureMapEntry wraps FeatureMap$Entry
class Supplier
	contains transient volatile PurchaseOrder [] preferredOrders
	contains transient volatile PurchaseOrder [] standardOrders
class PurchaseOrder
Alas, adding @GenModel(runtimePlatform="RCP", featureDelegation="Reflective") changes the generated code for "preferredOrders" and "standardOrders" to its reflective version. I would have expected these method bodies to not change at all.
Jan
Re: Xcore and FeatureMaps [message #1011463 is a reply to message #1011412] Tue, 19 February 2013 10:37 Go to previous messageGo to next message
Jan,
Comments below.
On 19/02/2013 3:33 PM, Jan Rosczak wrote:
> Hi Ed,
There was quite a bit of disruption in Xbase and it was hard to
synchronize all that...
> package model
> class Supplier
> class PurchaseOrder
Does that break anything?
> Thanks
> Jan
Re: Xcore and FeatureMaps [message #1011757 is a reply to message #1011463] Wed, 20 February 2013 02:56 Go to previous messageGo to next message
yes, the reflective feature delegation breaks feature maps.
Supplier supplier = ModelFactory.eINSTANCE.createSupplier();
PurchaseOrder preferredOrder = ModelFactory.eINSTANCE.createPurchaseOrder();
PurchaseOrder standardOrder = ModelFactory.eINSTANCE.createPurchaseOrder();
supplier.getOrders().add(ModelPackage.Literals.SUPPLIER__PREFERRED_ORDERS, preferredOrder);
supplier.getOrders().add(ModelPackage.Literals.SUPPLIER__STANDARD_ORDERS, standardOrder);
System.out.println(supplier.getOrders().size()); // prints 2
System.out.println(supplier.getPreferredOrders().size()); // prints 0
System.out.println(supplier.getStandardOrders().size()); // prints 0
If the feature map would still work, the last two lines should each print "1".
In the example you showed, the import of "org.eclipse.emf.ecore.EFeatureMapEntry" bothered me. In which plugin can this class be found (I looked in git repository with no result)? Thats why I changed it to:
That works.
Re: Xcore and FeatureMaps [message #1011763 is a reply to message #1011757] Wed, 20 February 2013 03:02 Go to previous messageGo to next message
Jan,
Please open a bugzilla with the details and the example. The import
"org.eclipse.emf.ecore.EFeatureMapEntry" refers to the EDataType in
Ecore.ecore; you won't find it in Java. In general Xcore's imports can
refer to EClassifiers or to Java types (or even to both, e.g., for
generated EClasses).
On 20/02/2013 8:56 AM, Jan Rosczak wrote:
> preferredOrder);
> standardOrder);
> print "1".
> That works.
Re: Xcore and FeatureMaps [message #1390945 is a reply to message #1011763] Mon, 30 June 2014 04:00 Go to previous messageGo to next message
Was there a bug created on this? Currently trying to get FeatureMaps running with XCore ... any updates? Thank you!
Re: Xcore and FeatureMaps [message #1391047 is a reply to message #1390945] Mon, 30 June 2014 07:18 Go to previous message
Marco,
I don't recall. If it's not working in the latest release (in the Luna
repo), please open a bugzilla.
Previous Topic:[CDO] Issues with uploading CLobs in non 1-byte encoding
Next Topic:EMF seems unable to read back what it wrote
Current Time: Wed Jul 23 14:14:17 EDT 2025
Powered by FUDForum. Page generated in 0.05289 seconds
