Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Virtual TableViewer sorting causes selection problems
Virtual TableViewer sorting causes selection problems [message #1011367] Tue, 19 February 2013 07:22 Go to next message
Our application is an RCP appliction and needs to display table of several thousands items. For this reason, we're using SWT.VIRTUAL in our TableViewer. That works pretty well except for selection.
We're having following issue :
- Our TableViewer support sorting and filtering. When we use a virtual tableviewer, changing the selection does not preserve the current selected item but the row currently selected.This leads to another item being selected.
e.g: If Item 'A' present at the 5th row is selected by user and sorting is performed, then after sorting the Item at the 5th row gets selected instead of the Item 'A'.
Using a non virtual TableViewer, everything works fine.
We tried to go into debug and found out that the cache from the AbstractTableViewer.VirtualManager class seems to be up to date with the model. Forcing the cache to be used in the AbstractTableViewer.virtualSetSelectionToWidget() can be a possible approach.
We have tried to implement a solution suggested in https://bugs.eclipse.org/bugs/show_bug.cgi?id=338696. However it didn't work.
Please suggest some pointers or alternative work around.
Thanks for the answers.
Uzma Pathan
Re: Virtual TableViewer sorting causes selection problems [message #1015715 is a reply to message #1011367] Fri, 01 March 2013 16:24 Go to previous message
You may get more response if you ask this on the jface newsgroup/forum,
since TableViewer is in JFace, not swt.
Grant
> being selected. e.g: If Item 'A' present at the 5th row is selected by
> approach.
> work.
> Uzma Pathan
Previous Topic:Eclipse Juno Reporting
Next Topic:Focus Issue
Current Time: Wed Jul 23 11:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.03951 seconds
