Applying mutliple same stereotype [message #1008665] |
Wed, 13 February 2013 09:15  |
I use Stereotype on Properties to generate C# Attributes
When a stereotype is already applied on Property we cannot add the same one multiple times ?
Why this a limitation ?
Thanks in advance,
Papyrus 0.9.0
Re: Applying mutliple same stereotype [message #1011338 is a reply to message #1008972] |
Tue, 19 February 2013 05:52  |
A stereotype in UML 2 is not a simple name-value pair as it was in UML 1.x.
Applying a stereotype to a metaclass means changing the metaclass to the
stereptype, i.e., a Class with <<requirement>> is considered to be a
requirement instead of class. So, adding the same stereotype would not make
sense at all.
HTH,
Marc-Florian
"E. TOSI" schrieb im Newsbeitrag news:kfi73a$emd$1@xxxxxxxxe.org...
Hi Christian,
Thanks for your response.
I will modify my Stereotypes to accept multiples values and satisfy this UML
specification.
Eric
FUDForum. Page generated in 0.08449 seconds
