Home » Archived » Visual Editor (VE) » shell close() stack overflow
shell close() stack overflow [message #100982] Mon, 01 August 2005 16:15 Go to next message
Running an SWT application (created in VE 1.1) on Windows causes a
StackOverflowError when running inside the Eclipse IDE. The shell event
listener listens for a close event. When closing the app via the "X" close
button in the upper right of the window, it continually loops on the
calling the shellClosed() listener method over and over, finally choking
on itself. Should I completely remove the call to sShell.close(). Why? See
the sample program below. Try it. Thanks for any responses!
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
public class testblah {
private Shell sShell = null;
Display display = Display.getDefault();
testblah thisClass = new testblah();
thisClass.createSShell();
thisClass.sShell.open();
while (!thisClass.sShell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private void createSShell() {
sShell = new Shell();
sShell.setText("Shell");
sShell.setSize(new Point(300, 200));
sShell.addShellListener(new org.eclipse.swt.events.ShellAdapter() {
public void shellClosed(org.eclipse.swt.events.ShellEvent e) {
sShell.close();
sShell.dispose();
Re: shell close() stack overflow [message #101258 is a reply to message #100982] Wed, 03 August 2005 11:02 Go to previous message
SWT Shell on a windows system is a native Windows Shell. When you close
the shell, all it does is provide a 'shellClosed' notification that it
is closing and then disposes itself. There is no need to do the closing
yourself.
Sri.
> close button in the upper right of the window, it continually loops on
> the calling the shellClosed() listener method over and over, finally
> choking on itself. Should I completely remove the call to
> sShell.close(). Why? See the sample program below. Try it. Thanks for
> any responses!
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> display.sleep();
> display.dispose();
> sShell.close();
> sShell.dispose();
Re: shell close() stack overflow [message #610135 is a reply to message #100982] Wed, 03 August 2005 11:02 Go to previous message
yourself.
Sri.
> any responses!
> display.sleep();
> display.dispose();
> sShell.close();
> sShell.dispose();
Previous Topic:VE1.1 wonŽt work
Next Topic:Jlabel border
Current Time: Sat Jul 19 01:27:04 EDT 2025
Powered by FUDForum. Page generated in 0.04036 seconds
