Home » Modeling » TMF (Xtext) » Optional arguments
Optional arguments [message #1009506] Fri, 15 February 2013 03:47 Go to next message
in my grammar there is a definition Func which can hold 0 to n params.
Simplified xtext fragment:
Func: {Func} '(' ( params+=INT(',' params+=INT)* )? ')' ';';
This allows to edit code like:
Func(4, 5, 10);
Now I want some parameters to be optional to edit code like:
Func (7, , 15);
My question:
How can I change the grammar to omit single params? It then must be possible accessing the values where the omitted values keep some empty/null value like:
params[0] // value is 7
params[1] // value is empty/null
params[2] // value is 15
Therefore, I can not make the single params completely optional like
(params+=INT)? // this would not set an empty/null value to an omitted param
Any suggestions?
Thanks in advance,
Gaspar
Re: Optional arguments [message #1009585 is a reply to message #1009506] Fri, 15 February 2013 05:50 Go to previous messageGo to next message
(params+=INT)? makes the assignment optional, not only the text
params+=INT? should work
Alex
Re: Optional arguments [message #1009689 is a reply to message #1009585] Fri, 15 February 2013 09:28 Go to previous messageGo to next message
Hi Alexander,
first, thank you for the quick answer.
But unfortunately, when I define
Func: {Func} '(' ( params+=INT(',' params+=INT?)* )? ')' ';';
it is really possible editing
Func (7, , , 15);
but calling func.getParams() only holds the two values 7 and 15.
The size of func.getParams() is two.
But how can I find out at which position the arguments are located?
Gaspar
Re: Optional arguments [message #1009694 is a reply to message #1009689] Fri, 15 February 2013 09:37 Go to previous messageGo to next message
what about
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Func: {Func} '(' ( params+=INT( params+=OINT)* )? ')' ';';
OINT returns ecore::EInt: ',' INT?;
and a custom valueconverter that handles the "null/strip away the comma" problem
[Updated on: Fri, 15 February 2013 09:41] by Moderator
Re: Optional arguments [message #1010831 is a reply to message #1009694] Mon, 18 February 2013 05:04 Go to previous message
Hi Christian,
I've tested with the OINT and it works for me!
Thank you
Gaspar
Previous Topic:Problems with Cross-Reference resolving in standalone app
Next Topic:XText project from XSD
Current Time: Thu Jul 24 17:29:17 EDT 2025
Powered by FUDForum. Page generated in 0.04606 seconds
