Home » Archived » BIRT » Chart - x-axis
Chart - x-axis [message #1009594] Fri, 15 February 2013 06:04 Go to next message
Hi all,
there is a possibility to put the x-axis on the top rather than in the bottom?
Re: Chart - x-axis [message #1009878 is a reply to message #1009594] Fri, 15 February 2013 17:57 Go to previous messageGo to next message
Sure. In the chart editor, go to the Format Chart tab. There, go to the x-axis section and you'll see a setting for "origin". By default it is min. Set it to max, instead. That should do it.
Re: Chart - x-axis [message #1010993 is a reply to message #1009878] Mon, 18 February 2013 11:11 Go to previous messageGo to next message
ok, works...thanks
Re: Chart - x-axis [message #1011131 is a reply to message #1010993] Mon, 18 February 2013 17:52 Go to previous message
You're welcome! Smile
Previous Topic:Add ScriptedDataSetEventAdapter into scripteddataset through DEAPI
Next Topic:Results preview - Total 500 records(s)
Current Time: Wed Aug 20 20:33:46 EDT 2025
Powered by FUDForum. Page generated in 0.02369 seconds
