[CDO] Problems with XML Import [message #1008172] |
Mon, 11 February 2013 04:13  |
I have a problem with the XML import into an empty repository (CDO 4.2, Build 1.2.2013). How the repository is created, see attached TestRepository.java.
If I import attached XML and then print out the names and types of the ResourceNodes I get the following output:
typesdescriptions : CDOResourceFolder@_FYh50HQfEeKp3LyXDhKQGQ
AtomicAttributeDatatypes : CDOResource@_FYjvAHQfEeKp3LyXDhKQGQ
What I would have expected is this:
typesdescriptions : CDOResourceFolder@_uBTJIHQoEeKF5ryXDhKQGQ
AtomicAttributeDatatypes : CDOResource@_uBU-UHQoEeKF5ryXDhKQGQ
fis : CDOResourceFolder@_uHvvYHQoEeKF5ryXDhKQGQ
I noticed that after I looked up an EObject after the XML import. The EObject has the path "/typesdescriptions/fis/transient/training/qi/1/iqi1Airport". I was able to find the EObject, but I got an error message when trying to access its resource, saying that the node "fis" could not be found.
In addition my method TestRepository.dropAllData does not seem to work, because after it is called and I check the child nodes of the root resource, it still has one child left: "typesdescriptions". I would have expected the root node to not have any children.
//Jan
Re: [CDO] Problems with XML Import [message #1009551 is a reply to message #1008172] |
Fri, 15 February 2013 04:52   |
Hi Jan,
Sorry for the late reply! Comments below...
Am 11.02.2013 10:13, schrieb Jan Rosczak:
> Hello,
Do you, by chance, know that the problem first occured with this particular build?
Yes, according to the relevant XML pieces:
<revision id="U_FYh50HQfEeKp3LyXDhKQGQ" class="http://www.eclipse.org/emf/CDO/Eresource/4.0.0#CDOResourceFolder"
version="2" time="1360568763513" resource="U_FVbigHQfEeKp3LyXDhKQGQ">
<feature name="name" value="typesdescriptions"/>
<feature name="nodes" type="Object" value="U_FYjvAHQfEeKp3LyXDhKQGQ"/>
<feature name="nodes" type="Object" value="U_FdsGoHQfEeKp3LyXDhKQGQ"/>
</revision>
<revision id="U_FYjvAHQfEeKp3LyXDhKQGQ" class="http://www.eclipse.org/emf/CDO/Eresource/4.0.0#CDOResource"
version="1" time="1360568762995" container="U_FYh50HQfEeKp3LyXDhKQGQ">
<feature name="name" value="AtomicAttributeDatatypes"/>
</revision>
<revision id="U_FdsGoHQfEeKp3LyXDhKQGQ" class="http://www.eclipse.org/emf/CDO/Eresource/4.0.0#CDOResourceFolder"
version="2" time="1360568765499" container="U_FYh50HQfEeKp3LyXDhKQGQ">
<feature name="name" value="fis"/>
</revision>
I hope that all this is not after you've tampered with the store's lifecycle in the way you outline below?
You should not cast to org.eclipse.emf.cdo.spi.server.Store in client code, use the InternalStore interface. And you
must not interfere with a store's lifecycle because it's controlled by the repository. IIRC it's not even expected to be
restartable. The DBStore respects isDropAllDataOnActivate() during doActivate(), though. You may be better off calling
DBUtil.dropAllTables(Connection, String) directly in tests. Follow the callers to find usage examples.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Problems with XML Import [message #1012755 is a reply to message #1010835] |
Fri, 22 February 2013 02:27  |
Am 18.02.2013 11:08, schrieb Jan Rosczak:
> Hi Eike,
> I guess it first happened with the 1.2.2013 build.
Just to be sure: You know exactly that it had worked before some build X and then started to fail with X? To know this X
would be good but it's more important for me to know whether it's a regression at all or not. In any case please submit
a bugzilla.
> Today I did the test again (build from 15.02.), same result.
Is it possible that you provide me with the code+data (possibly through private email) that I'd need to reproduce the
problem?
> I did not tamper with the store's lifecycle, just export, import and check if the object and its resource exist.
Regarding your dropAllTables(), please have a look at my first reply.
Cheers
/Eike
FUDForum. Page generated in 0.30581 seconds
