Home » Modeling » EMF » [CDO] Questions about CDO capabilities
[CDO] Questions about CDO capabilities [message #1009303] Thu, 14 February 2013 16:27 Go to next message
Hello CDO team!
After some time of experimentation, I have a few questions about CDO capabilities:
- is the workspace/project feature compatible with the security manager?
- when using CDO projects, is there an equivalent to team/synchronize?
- even if the CDO server is stopped using the osgi console and 'close' command, the database is detected as "crashed" during the next start. Am I doing something wrong?
- what about the robustness of CDO model repositories? When using XMI, it is not so difficult to fix anomalies by hand. But is it easy to fix a database that has been sabotaged by a rogue client, by a bug in CDO, in the database server or in anything else?
- is there a UI to tag a set of objects?
- is there a provision to "clean up" a repository from time to time, for example by removing non tagged versions of objects between 2 tagged versions?
Thanks for your answers!
Pierre
Re: [CDO] Questions about CDO capabilities [message #1009522 is a reply to message #1009303] Fri, 15 February 2013 04:16 Go to previous messageGo to next message
Am 14.02.2013 22:27, schrieb Pierre Gaufillet:
> Hello CDO team!
I've not tested it. I imagine that some extra thought needs to be put in on the RepositorySynchronizer.
I think that would be this API: org.eclipse.emf.cdo.workspace.CDOWorkspace.update(CDOMerger)
That shouldn't happen if you do everything right. I'd need to be able to reproduce that.
What would be easy? It all depends on the used IStore implementation. Often you can use the CDOServerExporter /
CDOServerImporter to analyze, change and re-import the complete contents as XML. The DBStore offers an optional
CDOServerBrowser that you can use to inspect the DB via a local web browser. Often you can also use arbitrary SQL front
ends to debug the data.
Not even an API, although it would be a nice thing to have. We're very reluctant, though, to introduce instances of what
I call "the partial evil" problem. If/when we implement the (already existing) CDOBranchTag interface then certainly not
in a way that it would support the tagging of an arbitrary (possibly inconsistent, not self-contained) subset of the
entire object graph.
No.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Questions about CDO capabilities [message #1009539 is a reply to message #1009522] Fri, 15 February 2013 04:42 Go to previous messageGo to next message
Just to add to point on DB maintenance.
>> Hello CDO team!
>> capabilities:
> reproduce that.
> Often you can use the CDOServerExporter / CDOServerImporter to analyze,
> optional CDOServerBrowser that you can use to inspect the DB via a local
> web browser. Often you can also use arbitrary SQL front ends to debug
> the data.
Unfortunately we were recently forced to fix anomalies what you describe
as caused by "sabotaged by rogue client",. In our case however, the
reason was a mal-configured MySQL user (Insufficient permissions) which
caused, some indexes not to be created, leading to
a DB state CDO is not built to deal with.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=396743
The trick to solve it, was to simply use a MySQL workbench, find these
anomalies and fix them.
We also have a strange case, that object are in the wrong CDOResource.
The application code didn't do that, so how did it happen? No clue to be
honest, but this also easily fixed.
Then there is the case of ObjectNotFoundException. I think that can be
considered 'normal' behaviour and has to do with consistency of the
object graph and managing references. But here also a tool to
directly peek and poke on the Objects comes in handy.
Just recently, we have done what Eike describes which is export, fix the
objects and import.. The challenge here is, it could be a multi-Gig XML
file as in our case, and you would need some tooling to check the
data offline. Perhaps an XSLT tool could execute some rules on the XML
and come up with an 'integrity' report. (We tried to do this on CDO
itself, but it's a looooooooooooong running operation).
My conclusion sofar, it's all very manageable, but some more tooling
, practice and documentation would come in handy. (Time to write them!).
BTW: CDOServerBrowser is new to me, will check that out!
Cheers Christophe
> reluctant, though, to introduce instances of what I call "the partial
> interface then certainly not in a way that it would support the tagging
> the entire object graph.
>> tagged versions?
> No.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: [CDO] Questions about CDO capabilities [message #1009560 is a reply to message #1009539] Fri, 15 February 2013 05:10 Go to previous messageGo to next message
Am 15.02.2013 10:42, schrieb Christophe Bouhier:
> Unfortunately we were recently forced to fix anomalies what you describe as caused by "sabotaged by rogue client",. In
> our case however, the reason was a mal-configured MySQL user (Insufficient permissions) which caused, some indexes not
> The trick to solve it, was to simply use a MySQL workbench, find these anomalies and fix them.
> The application code didn't do that, so how did it happen? No clue to be honest, but this also easily fixed.
It would be good to track this down (if possible) when it happens again. I wonder if missing or wrong DB indices could
cause this?
> Then there is the case of ObjectNotFoundException. I think that can be considered 'normal' behaviour and has to do
> with consistency of the object graph and managing references. But here also a tool to
I think it depends on how/where exactly the exceptions occur. Of course you must not call, e.g., view.getObject(id) with
the id of a detached object, or expect an ObjectNotFoundException.
If you don't configure your repository with ensureReferentialIntegrity=true you must expect "problems" when
dereferencing EReferences to detached objects. You can control the behaviour in these cases with CDOStaleReferencePolicy
and CDOInvalidationPolicy:
org.eclipse.emf.cdo.view.CDOView.Options.setInvalidationPolicy(CDOInvalidationPolicy)
org.eclipse.emf.cdo.view.CDOView.Options.setStaleReferencePolicy(CDOStaleReferencePolicy)
> Just recently, we have done what Eike describes which is export, fix the objects and import.. The challenge here is,
> it could be a multi-Gig XML file as in our case, and you would need some tooling to check the
> and come up with an 'integrity' report. (We tried to do this on CDO itself, but it's a looooooooooooong running
> operation).
What is looong? The export, the import or something else? Maybe we can do something about it...
Yes, please! :P
Have a look at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart():
String port = OMPlatform.INSTANCE.getProperty(PROP_BROWSER_PORT);
if (port != null)
container.getElement("org.eclipse.emf.cdo.server.browsers", "default", port);
Cheers
/Eike
Re: [CDO] Questions about CDO capabilities [message #1009562 is a reply to message #1009560] Fri, 15 February 2013 05:19 Go to previous messageGo to next message
>> describe as caused by "sabotaged by rogue client",. In our case
>> permissions) which caused, some indexes not to be created, leading to
> I wonder if missing or wrong DB indices could cause this?
> you must not call, e.g., view.getObject(id) with the id of a detached
Yes, what I understand referential integrity comes at a (high?) cost.
so it's off in our case.
> behaviour in these cases with CDOStaleReferencePolicy and
Yes, the Relaxed policy solved many UI issues related to this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303868
(this bug is still marked *New* BTW :P)
>> the objects and import.. The challenge here is, it could be a
>> check the
> Yes, please! :P
> Have a look at
> if (port != null)
> "default", port);
> Cheers
> /Eike
Re: [CDO] Questions about CDO capabilities [message #1009596 is a reply to message #1009562] Fri, 15 February 2013 06:07 Go to previous messageGo to next message
Am 15.02.2013 11:19, schrieb Christophe Bouhier:
It requires SELECTs on multiple (possibly many) tables. The actual number of tables to consult is carefully optimized by
means of static model analysis, see XRefsQueryHandler.collectSourceCandidates(IView, Collection<EClass>, Map<EClass,
List<EReference>>).
In 4.2 they're the defaults:
public static final CDOStaleReferencePolicy DEFAULT = PROXY;
public static final CDOInvalidationPolicy DEFAULT = RELAXED;
I can't see any votes on this Platform UI bug ;-(
Cheers
/Eike
Re: [CDO] Questions about CDO capabilities [message #1009772 is a reply to message #1009596] Fri, 15 February 2013 12:16 Go to previous messageGo to next message
Finally found out that CDO server shall be stopped using 'cdo stop <repo>' and then 'close' :-/
'close' alone doesn't leave the repo in a stable state.
It works correctly now.
Re: [CDO] Questions about CDO capabilities [message #1009827 is a reply to message #1009772] Fri, 15 February 2013 14:52 Go to previous message
Am 15.02.2013 18:16, schrieb Pierre Gaufillet:
Oh, that's even new to me! Will play with it when I have time...
Good ;-)
Cheers
/Eike
Previous Topic:[CDO] Invalidation notification for certain object types
Next Topic:Copy between resources - Dangling References
Current Time: Wed Jul 23 06:42:35 EDT 2025
Powered by FUDForum. Page generated in 0.08670 seconds
