Home » Archived » Riena » checkbox -> togglebutton(I want to see a single checkbox)
checkbox -> togglebutton [message #1008680] Wed, 13 February 2013 09:49 Go to next message
when creating a single Button with SWT.CHECK style set, quite surprisingly a toggle Button is rendered.
But I'd like to see a Checkbox.
Is this due to Riena standards?
I assume Riena is responsible for it, but it's just a guess.
Since i couldn't figure out where this happens i'd really appreciate some enlightenment on this topic. In best case a solution to get the checkbox.
Chris
Re: checkbox -> togglebutton [message #1009146 is a reply to message #1008680] Thu, 14 February 2013 09:49 Go to previous messageGo to next message
Hi Chris,
usually, Riena should not change the button style. How are you creating the button?
Check if these work for you:
UIControlsFactory.createButton(parent).setText("Push");
UIControlsFactory.createButtonCheck(parent).setText("Check");
UIControlsFactory.createButtonRadio(parent).setText("Radio");
UIControlsFactory.createButtonToggle(parent).setText("Toggle");
If the unexpected behavior persists, it is probably a bug you can file here. If possible provide a snippet and the information about your environment.
Jordan
Re: checkbox -> togglebutton [message #1009481 is a reply to message #1009146] Fri, 15 February 2013 03:10 Go to previous messageGo to next message
Hi Jordan,
I created it with UIControlsFactory.createButtonCheck(parent),
but i get same results when creating with new Button(parent, SWT.CHECK).
Strange imho. It could easily be from SWT, too.
I posted on this forum because if Riena was responsible I hoped for confirmation and hopefully a hint how to circumvent as well.
Cheers, Chris
Re: checkbox -> togglebutton [message #1011752 is a reply to message #1009481] Wed, 20 February 2013 02:43 Go to previous message
I finally found the code rendering a Button instead of the Checkbox (in our codebase =).
-> Neither Riena nor SWT issue
Previous Topic:Remote Services with EMF generated objects and TENEO
Next Topic:Eclipse package for Riena
Current Time: Sun Jul 27 00:35:56 EDT 2025
Powered by FUDForum. Page generated in 0.07191 seconds
