PDF Page Numbers [message #1008780] |
Wed, 13 February 2013 15:55  |
Hello. I am having an issue with page numbers in BIRT 4.2. I need to have page numbers on my report when I output the report to a pdf. With every method that I have tried, the page number variable appears to increment only when there is a page break that I specified in the report design. When there are multiple pages because a table ended up being bigger than usual, both pages with have the same page number. I first tried putting <viewtime-value-of>pageNumber</viewtime-value-of> in the footer. I have also tried adding onCreate and onRender scripts to the footer to increment a global variable and then put it in the footer, but this has the same problem. Does anyone have a method for getting around this problem?
FUDForum. Page generated in 0.03113 seconds
