Home » Archived » BIRT » source code of BIRT: A Field Guide (third edition)
source code of BIRT: A Field Guide (third edition) [message #1008811] Wed, 13 February 2013 17:33 Go to next message
Where can I find source code (or examples) of BIRT: A Field Guide (third edition)?
James
Re: source code of BIRT: A Field Guide (third edition) [message #1009208 is a reply to message #1008811] Thu, 14 February 2013 11:56 Go to previous messageGo to next message
James
Try:
http://www.actuate.com/products/resources/?articleid=22889
Jason
BIRT-Exchange
Re: source code of BIRT: A Field Guide (third edition) [message #1009255 is a reply to message #1009208] Thu, 14 February 2013 14:11 Go to previous messageGo to next message
For second or third edition you ca use this link:
http://www.actuate.com/birt/contributions
Re: source code of BIRT: A Field Guide (third edition) [message #1009306 is a reply to message #1009255] Thu, 14 February 2013 16:39 Go to previous messageGo to next message
I am looking for source code for BIRT: A Field Guide (third edition), not for extension and integration book.
I search the whole book and I can not find any clue where is the source code.
James
Re: source code of BIRT: A Field Guide (third edition) [message #1009467 is a reply to message #1009306] Fri, 15 February 2013 02:36 Go to previous messageGo to next message
James
Sorry about that. I will look into where the Field Guide examples are and post back.
Jason
Re: source code of BIRT: A Field Guide (third edition) [message #1064957 is a reply to message #1009467] Fri, 21 June 2013 17:26 Go to previous messageGo to next message
I was also looking for a link to the source code for the "BIRT: A field Guide" book. I googled and only found this forum thread, but no link to the example source code.
Did anyone ever find a link to where the source code to the book examples might be available?
Thanks!
Re: source code of BIRT: A Field Guide (third edition) [message #1065664 is a reply to message #1064957] Thu, 27 June 2013 01:18 Go to previous messageGo to next message
I'm not certain if this source is available like with the integrating book. I'll see what I can find out. What examples are you looking for specifically?
Re: source code of BIRT: A Field Guide (third edition) [message #1065856 is a reply to message #1065664] Thu, 27 June 2013 16:51 Go to previous messageGo to next message
Specifically, I was looking for the sub-report linking example from chapter 16.
I've been trying to build a report with two data sets where one data set contains summary statistics and the other data set contains detailed records to do a form of drill-down reporting. My use case sounds similar to the one in chapter 16 so I was hoping to compare my logic/steps with the ones in the book.
[Updated on: Thu, 27 June 2013 16:51] by Moderator
Re: source code of BIRT: A Field Guide (third edition) [message #1066882 is a reply to message #1065856] Fri, 05 July 2013 00:32 Go to previous message
Sorry for the delayed response. I'll have to take a look in the book to see what the example is you're talking about. Are you drilling down within the same design? Or do you have two separate designs? Also, what's your BIRT version?
Previous Topic:BIRT Server with Charts
Next Topic:Report Preview doesn't work
Current Time: Wed Jul 23 19:45:46 EDT 2025
Powered by FUDForum. Page generated in 0.07125 seconds
