Cannot install GreenPages app on Virgo 3.6.0.release [message #1008735] |
Wed, 13 February 2013 13:43  |
I have installed Virgo 3.6.0.release and built the greenpages example from documentation but I am getting the following exception.
[2013-02-13 11:25:14.066] startup-readiness <KE0007I> Virgo ready. Started for 24.660s.
[2013-02-13 11:25:15.140] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'greenpages-2.5.0.
RELEASE.par'.
[2013-02-13 11:25:21.314] fs-watcher <DE0000I> Installing par 'greenpages' version '2.5.0.RELEASE'.
[2013-02-13 11:25:21.316] fs-watcher <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-com.springsource.org.h2
' version '1.0.71'.
[2013-02-13 11:25:21.319] fs-watcher <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.core' versio
n '2.5.0'.
[2013-02-13 11:25:21.321] fs-watcher <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.db' version
'2.5.0'.
[2013-02-13 11:25:21.323] fs-watcher <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.jpa' version
'2.5.0'.
[2013-02-13 11:25:21.325] fs-watcher <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.web' version
'2.5.0'.
[2013-02-13 11:25:21.377] fs-watcher <DE0002E> Installation of par 'greenpages' version '2.5.0.RELEASE' failed. or
g.eclipse.virgo.nano.deployer.api.core.DeploymentException: Unable to satisfy dependencies of bundle 'greenpages-2.5.0.RELEASE-green
pages.web' at version '2.5.0': A library with the name 'org.springframework.spring' and a version within the range '[3.0.0, 3.1.0)'
could not be found
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.expandImports(ImportExpandingTransformer.java:
116)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.expandImportsOfBundlesInScopedPlan(ImportExpan
dingTransformer.java:89)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer$ImportExpandingGraphVisitor.visit(ImportExpand
ingTransformer.java:76)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visitInternal(ThreadSafeGraphNode.java:193)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visit(ThreadSafeGraphNode.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.transform(ImportExpandingTransformer.java:58)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessGraph(TransformationStage
.java:54)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDep
loyer.java:359)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:
185)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:14
0)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:253
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:225)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeployerFileSystemListener.jav
a:237)
at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:88)
at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:373)
at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:282)
at org.eclipse.virgo.nano.deployer.hot.WatchTask.run(WatchTask.java:48)
at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bun
dle 'greenpages-2.5.0.RELEASE-greenpages.web' at version '2.5.0': A library with the name 'org.springframework.spring' and a version
within the range '[3.0.0, 3.1.0)' could not be found
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.createExceptionForMissingLibrary(Impo
rtExpansionHandler.java:185)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.getLibraryPackageImports(ImportExpans
ionHandler.java:454)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.getAdditionalPackageImports(ImportExp
ansionHandler.java:232)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.expandImports(ImportExpansionHandler.
java:207)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.expandImportsIfNecessary(ImportExpans
ionHandler.java:175)
java:113)
at sun.reflect.GeneratedMethodAccessor62.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.j
ava:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
at $Proxy42.expandImports(Unknown Source)
107)
... 23 common frames omitted
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1009170 is a reply to message #1008982] |
Thu, 14 February 2013 10:25   |
Thanks for the information it seems to get me past my original problem. Now I am faced with:
[2013-02-14 08:19:37.145] fs-watcher <DE0003E> Install failed for par 'greenpages' version '2.5.0.RELEASE'.
[2013-02-14 08:19:37.148] fs-watcher <DE0500E> Unable to install application from URI 'file:/C:/VIRGO-~1.REL/picku
p/greenpages-2.5.0.RELEASE.par'. Cannot satisfy constraints for bundle 'greenpages-2.5.0.RELEASE-greenpages.jpa' version '2.5.0'. Ca
nnot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
Resolver report:
An Import-Package could not be resolved. Resolver error data <Import-Package: org.eclipse.persistence.tools.schemaframework;
version="0.0.0">. Caused by missing constraint in bundle <greenpages-2.5.0.RELEASE-greenpages.jpa_2.5.0>
constraint: <Import-Package: org.eclipse.persistence.tools.schemaframework; version="0.0.0"> constrained to bundle <com
.springsource.org.eclipse.persistence> constrained bundle version range "[1.0.0,1.0.0]"
An Import-Package could not be resolved. Resolver error data <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">. C
aused by missing constraint in bundle <com.springsource.org.eclipse.persistence_1.0.0>
constraint: <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">
. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'gree
npages-2.5.0.RELEASE-greenpages.jpa' at version '2.5.0': Cannot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
Resolver report:
at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
loyer.java:359)
185)
0)
a:237)
[2013-02-14 08:19:37.176] fs-watcher <HD0002E> Hot deploy failed for file 'greenpages-2.5.0.RELEASE.par'. org.ecli
pse.virgo.nano.deployer.api.core.DeploymentException: Dependency satisfaction failed
loyer.java:362)
185)
0)
a:237)
dle 'greenpages-2.5.0.RELEASE-greenpages.jpa' at version '2.5.0': Cannot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
Resolver report:
loyer.java:359)
... 10 common frames omitted
FUDForum. Page generated in 0.06255 seconds
