Home » Modeling » EMF » Duplicate content parser registration
Duplicate content parser registration [message #1009089] Thu, 14 February 2013 07:07 Go to next message
Hi Ed
Since plugin.xml codegen merging was added (17-Oct-2012), I've been
having to manually delete a duplicate content_parser registration after
each regeneration.
Pre-existing, wanted declaration:
<extension point="org.eclipse.emf.ecore.content_parser">
<parser
contentTypeIdentifier="org.eclipse.ocl.examples.pivot"
class="org.eclipse.ocl.examples.pivot.utilities.PivotResourceFactoryImpl"/>
</extension>
Unwanted merged addition:
<!-- @generated Pivot.merged -->
<parser
class="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"/>
</extension>
This behaviour does not seem to affected by the generate bundle manifest
genmodel option, or by an @generated NOT.
Is there some new technique for suppressing the unwanted merged content,
or is it a bug?
Ed Willink
Re: Duplicate content parser registration [message #1009095 is a reply to message #1009089] Thu, 14 February 2013 07:26 Go to previous messageGo to next message
Ed,
You can turn off Update Classpath if you don't want things like the
plugin.xml and the MANIFEST.MF touched during regeneration at all.
Alternatively I think you can specify something like this to block
subsequent merging while allowing anything else new to be merged in later.
<!-- @generated Pivot.merged NOT -->
<parser
</extension
On 14/02/2013 1:07 PM, Ed Willink wrote:
> Hi Ed
> after each regeneration.
> <parser
> </extension>
> <parser
> </extension>
> manifest genmodel option, or by an @generated NOT.
> content, or is it a bug?
> Regards
> Ed Willink
Re: Duplicate content parser registration [message #1009157 is a reply to message #1009095] Thu, 14 February 2013 10:06 Go to previous message
Thanks for the clues. Your suggestion works but gives a warning message
about missing content. The following works.
<!-- @generated Pivot.merged NOT-->
<!--parser
class="org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl"/-->
<parser
</extension>
Ed Willink
On 14/02/2013 12:26, Ed Merks wrote:
> Ed,
> later.
> <parser
> </extension
>> Hi Ed
>> <parser
>> </extension>
>> <parser
>> </extension>
>> Regards
>> Ed Willink
Previous Topic:eAdapter is null
Next Topic:[Teneo] Not null constraint in JointTable when implementing Interface
Current Time: Wed Jul 23 11:57:05 EDT 2025
Powered by FUDForum. Page generated in 0.04353 seconds
