Home » Eclipse Projects » Virgo » Cannot install GreenPages app on Virgo 3.6.0.release(Unable to satisfy dependencies of bundle 'greenpages-2.5.0.RELEASE-green pages.web' at version '2.5.0': A library with the name 'org.springframework.spring' and a version within the range '[3.0.0, 3.1)
Cannot install GreenPages app on Virgo 3.6.0.release [message #1008735] Wed, 13 February 2013 13:43 Go to next message
I have installed Virgo 3.6.0.release and built the greenpages example from documentation but I am getting the following exception.
[2013-02-13 11:25:14.066] startup-readiness            <KE0007I> Virgo ready. Started for 24.660s.
[2013-02-13 11:25:15.140] fs-watcher                   <HD0001I> Hot deployer processing 'INITIAL' event for file 'greenpages-2.5.0.
RELEASE.par'.
[2013-02-13 11:25:21.314] fs-watcher                   <DE0000I> Installing par 'greenpages' version '2.5.0.RELEASE'.
[2013-02-13 11:25:21.316] fs-watcher                   <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-com.springsource.org.h2
' version '1.0.71'.
[2013-02-13 11:25:21.319] fs-watcher                   <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.core' versio
n '2.5.0'.
[2013-02-13 11:25:21.321] fs-watcher                   <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.db' version
'2.5.0'.
[2013-02-13 11:25:21.323] fs-watcher                   <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.jpa' version
 '2.5.0'.
[2013-02-13 11:25:21.325] fs-watcher                   <DE0000I> Installing bundle 'greenpages-2.5.0.RELEASE-greenpages.web' version
 '2.5.0'.
[2013-02-13 11:25:21.377] fs-watcher                   <DE0002E> Installation of par 'greenpages' version '2.5.0.RELEASE' failed. or
g.eclipse.virgo.nano.deployer.api.core.DeploymentException: Unable to satisfy dependencies of bundle 'greenpages-2.5.0.RELEASE-green
pages.web' at version '2.5.0': A library with the name 'org.springframework.spring' and a version within the range '[3.0.0, 3.1.0)'
could not be found
        at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.expandImports(ImportExpandingTransformer.java:
116)
        at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.expandImportsOfBundlesInScopedPlan(ImportExpan
dingTransformer.java:89)
        at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer$ImportExpandingGraphVisitor.visit(ImportExpand
ingTransformer.java:76)
        at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visitInternal(ThreadSafeGraphNode.java:193)
        at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visit(ThreadSafeGraphNode.java:184)
        at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpandingTransformer.transform(ImportExpandingTransformer.java:58)
        at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessGraph(TransformationStage
.java:54)
        at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
        at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
        at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
        at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDep
loyer.java:359)
        at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:
185)
        at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:14
0)
        at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:253
        at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deploy(HotDeployerFileSystemListener.java:225)
        at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.deployIfNotDeployed(HotDeployerFileSystemListener.jav
a:237)
        at org.eclipse.virgo.nano.deployer.hot.HotDeploymentFileSystemListener.onChange(HotDeployerFileSystemListener.java:88)
        at org.eclipse.virgo.util.io.FileSystemChecker.notifyListeners(FileSystemChecker.java:373)
        at org.eclipse.virgo.util.io.FileSystemChecker.check(FileSystemChecker.java:282)
        at org.eclipse.virgo.nano.deployer.hot.WatchTask.run(WatchTask.java:48)
        at java.lang.Thread.run(Thread.java:722)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bun
dle 'greenpages-2.5.0.RELEASE-greenpages.web' at version '2.5.0': A library with the name 'org.springframework.spring' and a version
 within the range '[3.0.0, 3.1.0)' could not be found
        at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.createExceptionForMissingLibrary(Impo
rtExpansionHandler.java:185)
        at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.getLibraryPackageImports(ImportExpans
ionHandler.java:454)
        at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.getAdditionalPackageImports(ImportExp
ansionHandler.java:232)
        at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.expandImports(ImportExpansionHandler.
java:207)
        at org.eclipse.virgo.kernel.userregion.internal.importexpansion.ImportExpansionHandler.expandImportsIfNecessary(ImportExpans
ionHandler.java:175)
java:113)
        at sun.reflect.GeneratedMethodAccessor62.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Method.java:601)
        at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
        at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
        at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
        at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
        at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
        at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
        at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.j
ava:70)
        at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
        at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
        at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
        at $Proxy42.expandImports(Unknown Source)
107)
        ... 23 common frames omitted
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1008982 is a reply to message #1008735] Thu, 14 February 2013 03:48 Go to previous messageGo to next message
Referring to the excerpt "A library with the name 'org.springframework.spring' and a version within the range '[3.0.0, 3.1.0)' could not be found" it is obvious that range excludes version 3.1.0. However this is precisely the Spring version delivered with Virgo 3.6.0. Increase the version range maximum in Greenpages.
You can find detailed instruction in STEP 12 at Wordpress site "Greenpagesvirgo.wordpress.com".
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1009170 is a reply to message #1008982] Thu, 14 February 2013 10:25 Go to previous messageGo to next message
Thanks for the information it seems to get me past my original problem. Now I am faced with:
[2013-02-14 08:19:37.145] fs-watcher                   <DE0003E> Install failed for par 'greenpages' version '2.5.0.RELEASE'.
[2013-02-14 08:19:37.148] fs-watcher                   <DE0500E> Unable to install application from URI 'file:/C:/VIRGO-~1.REL/picku
p/greenpages-2.5.0.RELEASE.par'. Cannot satisfy constraints for bundle 'greenpages-2.5.0.RELEASE-greenpages.jpa' version '2.5.0'. Ca
nnot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
    Resolver report:
        An Import-Package could not be resolved. Resolver error data <Import-Package: org.eclipse.persistence.tools.schemaframework;
 version="0.0.0">. Caused by missing constraint in bundle <greenpages-2.5.0.RELEASE-greenpages.jpa_2.5.0>
             constraint: <Import-Package: org.eclipse.persistence.tools.schemaframework; version="0.0.0"> constrained to bundle <com
.springsource.org.eclipse.persistence> constrained bundle version range "[1.0.0,1.0.0]"
        An Import-Package could not be resolved. Resolver error data <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">. C
aused by missing constraint in bundle <com.springsource.org.eclipse.persistence_1.0.0>
             constraint: <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">
. org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundleDependenciesException: Unable to satisfy dependencies of bundle 'gree
npages-2.5.0.RELEASE-greenpages.jpa' at version '2.5.0': Cannot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
    Resolver report:
        at org.eclipse.virgo.kernel.install.pipeline.stage.resolve.internal.QuasiResolveStage.process(QuasiResolveStage.java:46)
loyer.java:359)
185)
0)
a:237)
[2013-02-14 08:19:37.176] fs-watcher                   <HD0002E> Hot deploy failed for file 'greenpages-2.5.0.RELEASE.par'. org.ecli
pse.virgo.nano.deployer.api.core.DeploymentException: Dependency satisfaction failed
loyer.java:362)
185)
0)
a:237)
dle 'greenpages-2.5.0.RELEASE-greenpages.jpa' at version '2.5.0': Cannot resolve: greenpages-2.5.0.RELEASE-greenpages.jpa
    Resolver report:
loyer.java:359)
        ... 10 common frames omitted
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1009326 is a reply to message #1008735] Thu, 14 February 2013 17:42 Go to previous messageGo to next message
Referring to excerpt "constraint: <Import-Package: javax.persistence; version="[1.0.0,2.0.0)">" reveals incompatibility with the Virgo's version of EclipseLink. Virgo 3.6.0 has been delivered with bundle javax.persistence-2.0.4.v201112161009.jar. Furthermore this bundle is compatible with other EclipseLink bundles of version 2.4.0. Upgrade Greenpages EclipseLink jars to the same level i.e. 2.4.0.
You can find more detailed instructions in STEP 6 and STEP 11 of my Wordpress blog "greenpagesvirgo.wordpress.com".
Re: Cannot install GreenPages app on Virgo 3.6.0.release [message #1015140 is a reply to message #1009326] Wed, 27 February 2013 09:51 Go to previous message
I have just posted a new collection of Virgo samples at version RC1. (Didn't go for release as I just know someone will find a bug).
It includes Greenpages along with several other samples. I have tested/developed them alongside Leo's great work on the new Tooling so please upgrade to the new Virgo IDE tooling as well.
http://www.eclipse.org/virgo/samples/
Chris.
Previous Topic:Virgo IDE 1.0.1.RELEASE
Next Topic:Virgo 3.6.1 Release
Current Time: Sat Jul 26 02:04:07 EDT 2025
Powered by FUDForum. Page generated in 0.05050 seconds
