Home » Eclipse Projects » Eclipse Platform » AntEditor - NoClassDefFoundError - debian packages
AntEditor - NoClassDefFoundError - debian packages [message #100642] Sat, 26 July 2003 19:06 Go to next message
Originally posted by: rlopes.ipb.pt
Hi!
When I try to edit an Ant build file (by double clicking on build.xml),
eclipse gives me an error related to a class which cannot be found:
Cannot open default editor on build.xml. Unable to instantiate editor:
org.eclipse.ui.externaltools.internal.ant.editor.AntEditor
java.lang.NoClassDefFoundError:
org/eclipse/ui/externaltools/internal/ant/editor/PlantySourc eViewerConfiguration
Moreover, when checking the Install/Update workspace, I saw that the
Eclipse Platform 2.1.1 is not properly configured. Should these be
related? How can I force it to correct the configuration?
When I try to use the Install/Upgrade, it tells me that the
/usr/share/eclipse directory is readonly and it does not allow me to
proceed...
I'm using the debian sid packages, for all that matter.
/rp
Re: AntEditor - NoClassDefFoundError - debian packages [message #100670 is a reply to message #100642] Sat, 26 July 2003 23:31 Go to previous messageGo to next message
Which build of eclipse are you using?
Darins
"Rui Pedro Lopes" <rlopes@ipb.pt> wrote in message
news:bfv1dt$tc5$1@eclipse.org...
> Hi!
tion
> proceed...
> Cheers,
> /rp
Re: AntEditor - NoClassDefFoundError - debian packages [message #100763 is a reply to message #100642] Sat, 26 July 2003 02:57 Go to previous messageGo to next message
Originally posted by: zabilcm.hathway.com
Rui Pedro Lopes wrote:
> Hi!
> proceed...
> Cheers,
> /rp
By default the planty editor does not come with eclipse. It seems that your
planty editor plugin is not configured properly
You can right click on the file and say "Run ant".
If you want to view the file then right click on the same and choose "Open
with" some other editor.
Also at the planty site i have read that there are some problems to get it
working along with xmlBuddy plugin.
Re: AntEditor - NoClassDefFoundError - debian packages [message #100794 is a reply to message #100670] Sun, 27 July 2003 05:46 Go to previous messageGo to next message
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Installed/Config-files/Unpacked/Failed-config/Hal f-installed
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err:
uppercase=bad)
||/ Name Version Description
pn eclipse <none> (no description available)
ii eclipse-javac 2.1.1-2 Eclipse Java compiler and ant plug-in
ii eclipse-jdt 2.1.1-2 Java Development Tools plug-ins for
Eclipse
pn eclipse-nls-sd <none> (no description available)
ii eclipse-pde 2.1.1-2 Plug-in Development Environment to
develop E
un eclipse-pde-ju <none> (no description available)
ii eclipse-platfo 2.1.1-2 Eclipse platform without plug-ins to
develop
ii eclipse-sdk 2.1.1-2 Extensible Tool Platform and Java IDE
ii eclipse-source 2.1.1-2 Eclipse source code plug-ins
pn eclipse-webdav <none> (no description available)
pn eclipse-xerces <none> (no description available)
un libeclipse-swt <none> (no description available)
I hope this helps... :)
Thanks and cheers,
/rp
Re: AntEditor - NoClassDefFoundError - debian packages [message #100806 is a reply to message #100763] Sun, 27 July 2003 06:04 Go to previous messageGo to next message
Are you sure? The message in planty web site says it "should" be already
included in the Eclipse distribution:
http://www.gebit.de/download/planty/about.html#Roadmap
I believe this is the issue here! When installing Eclipse, it does not
get configured properly. I saw that in the Install/Update workspace.
Now, how can I force it to configure itself?
I tried to use the update feature of the platform but when reaching the
configuration directory it says that /usr/share/eclipse is marked as
readonly, even as root!
Any ideia?
Thanks and cheers,
/rp
Re: AntEditor - NoClassDefFoundError - debian packages [message #100820 is a reply to message #100642] Sun, 27 July 2003 06:15 Go to previous messageGo to next message
> Hi!
I'm sorry to bother you all. I just found the cause:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=201422
Sorry...
/rp
Re: AntEditor - NoClassDefFoundError - debian packages [message #100887 is a reply to message #100763] Sun, 27 July 2003 11:50 Go to previous message
your
When making statements such as these always state which Eclipse version you
are talking about.
The planty source and planty editor plugin were contributed and integrated
into Eclipse during the 2.1 development.
Eclipse 2.1 and any further releases include the Planty (or Ant) editor
contents and functionality
Darins
Previous Topic:plugin classloader doesn't load 3rd party jars
Next Topic:Feature for 3.0...
Current Time: Sun Nov 09 08:38:08 EST 2025
Powered by FUDForum. Page generated in 0.03804 seconds
